been doing some more investigating and started fiddling with the fuses.
Took out 7 and 8, and they are getting power... at first 12 volts but now it's more like 3. Probably user error.
Found out that when those fuses are taken out, the rear right brake light stops working altogether.What the heck did some of my wires weld themselves together?! That's starting to sound like more of a possibility. Maybe i should take out that fuse block
). With my meter i've verified that the grounds are good, and 12 volts goes where it ought to go when the switch is toggled. However, when i go to the tail light backing plate, the meter can't find power anywhere when the switch is toggled. I'm not sure what wires are supposed to get power when you want the parking lights on but no wire back there seems to get power, except for the brake lights and one of the tail lights. I've found continuity with ground on all the wires back there so i think that means that they are all grounded as well?
) That's pretty much the reason why i suspected the switch itself not the ground
I havent even installed those lights yet! Oh, and i need to wire them up yet (i went a little snippy snippy when I took the hatch off for paint)
