Results 1 to 2 of 2
Thread: 04 Gli drl problems need help!
  1. 10-13-2012 07:02 PM #1
    Hey guys I have an 04 Gli with a 1.8t I have an issue with my drl I turn them on and only one side works driver side btw and I tested the fuses and only one of the fuses for the drl is getting power so I found the relay and put my hand on it and I feel it click while I turn the drls on so I'm a little confused hope you guys can help me out. Is it possible that the relay is bad and only opperating one side? Thanks
  2. 10-14-2012 09:41 AM #2
    Definitely not the DRL relay. I assume that the low beam on that side doesn't work either?
