By popular request here it is.
Please **ONLY** post the information you have and **NOT** debate it within the thread. If you do I'll delete the posts in order to save the thread.
If you have a question about something in the FAQ please post in the forums and DO NOT post it in the FAQ or it will be deleted.
Please make sure the "Append signature to this post" box is NOT checked before posting.
----------------FYI Basics on car stuff Facts etc---------------------------
Tire Size Calculator
everyone wants to know about Octane Boosters!
Do you havea DE?
Drivers editions were made in 1997 only info
Vortex mythHeaders and exhaust systems 2.5" diameter and larger are NOT too big for properly tuned 2.0L 8v motors and do NOT take away your torque.
What's the difference between OBDI & OBDII
Do I have OBDI or OBDII?
Suspension TuningLiink
Another great MkIII/A3 resource Link
The Hidden TachLink
MKIII Display diagnostics how to...Link
Link
the differences in all models/trims/editions of jettasLinkLinkLinkLink
----------------Lighting and external electrics-----------------
The easiest way to remove DRL's (Daytime Running Lights)
*another way to eliminate DRLs (daytime running lights)
*Another way to disable DRLs
*The easiest way to disconnet the day time running lights
Enabling Rear Fog Light on US-Spec Mk3 Golf
Cheap tail light tinting or smoking
PIAA Ion Crystal and MaxGold bulbs are good yellow bulbs for fogs and headlights
Air Condition Light
European Headlights - est. time to complete: 3:00 hrs
wiring up MK4 look or e-codes
The best instructions for a installing the rear foglight on a golf:
How to add a jumper / bridge to enable high / low beams with fogs:Link
How to enable the rear fog light on a Jetta.Link
Bulb Types for Dual-Chambered Lights and FogsLink
Bulb Types for other headlamps/lightsLink
----------------Interior related how to's and modifications------------
mk4 cabrio (99+) guage cluster swap
My steering wheel is making a scratchy or gritty noise when I turn the wheel...what's going on?
Mk3 Cigarette Lighter fix
Programming Keyless Entry Remotes
How to fix your door-lock if you turn it and nothing happens, or it comes out...
FYI for Cutting/Shortening shifter
How to's on switchblade keys
removing door panels
2.0 Push-Button Start howto: (might be same on vr6)
Installing TT pedalsLink
How to install a Euro switchLink
One-Touch Sunroof Open (Back only, not up)LInkLink
How to take out the needles on the instrument clusterLinkLink
What Is The Thread Size for the Shifter On a 2.0?Link
Trunk Light for OBDI Cars Link
Trunk LightLink
Retrofit GloveboxLink
Remote Keyless EntryLink
MKIV Knob/Boot in a MKIII Link
----------------Brakes and Suspension------------------------------------
explanation of a Suspension Install
Mk3 VR6 spring and shock combos will fit 2.0L cars if you use the VR6 strut bearings and bushings
98+ Jettas have different front brakes
Canadian GTI Rear Strut Bar Polish modLink
----------------Bodywork, Painting, exteriors, wheels----------------
left hand door handles will work on the right of your car
how to take off your golf/gti rear glass spoiler
Fixing Your Non-clip-on Door Moldings
Debadging
Removing Factory Sideskirts (all models except Cabrio)
easiest, cheapest hood struts
Ghetto HoodliftsLink
another faded doorhandle solution
"Where do I get spacers/adapters to go from 4x100 to 5x100"
European bumpers – est. time to complete: 2:00-3:00 hrs (depending on how you choose to install rear rebar)
How to Polish ALL Aluminums..Link
My How-To for DIY Painted Door Handles Link
Fixing Your Non-clip-on Door MoldingsLink
(93-95) How to delete your passenger side keyholeLink
Blackend VW EmblemLink
How to add a Blue and White emblem to the back.Link
Painting parts of your engine bay.Link
How to clean wax and stuff off textured plastic.Link
"Help" on installing Euro VR6 Lip Link
Swapping in the rear Euro license plate frame/tub:Link
Installing the Bonrath Mono-wiper:Link
CL style plugged rear wiper for mk3 golf's and gti'sLink
VW accessory lower grille coversLink
Fuba InstallLink
How to paint your 2.0 inatake manifoldLink
SEAT Toledo Lip Spoiler InstallLink
----------------=Engine and Exhaust=------------------------------------------------
Performance:
GIAC (Garrett) chips is one of the best performing chips out there, dyno proven:
to swiss cheese your air box
CatBack Exhaust
VR6 Throttle body coolant line bypass,
Various manufacturers camshaft specs for 2.0L 8v motors:
Can I see an ABD Big-Bore Intake / or is it worth it?
What headers are available for the Mk3 2.0L 8v?
Modifying the air box for better performance as well as the real story about the Air Temperture Control system Link
Another Airbox Mod
Link
Maintenance or how-to:
Changing Spark Plugs on a 2.0
Timing Belt on a 2.0
Serpentine belt, Brake pads, Tinting Lights, Exhaust Install
Easy VR6 Upper Intake Manifold RemovalLink
--------------------=Transmission & Clutch=-----------------------------------------
How Do I Install my Short Shift Kit?Link
---------------=Other & Maintenance=------------------------------------------------
changing fuel filter
How Do I Hook-Up an Air Fuel Gauge?Link
How Do I Hook-Up an Oil Pressure Gauge?Link
Where Are the Intake Heatshield Instructions?Link
How to make a heat shield:Link
-----------------=European Mods or other----------------------------------------------
European Radiator Support - est. time to complete: 4:00 hrs
end of page
Link
Link
Link
Link
Have fun.
Modified by abtvento at 1:13 PM 11-19-2004
Modified by jhayesvw at 6:36 AM 10-17-2006
Do you havea DE?
The Hidden TachLink
Link
Air Condition Light
Trunk LightLink
Debadging
Fuba InstallLink
Performance:
CatBack Exhaust
Another Airbox Mod
Link
end of page
Link
Link
Link
Link
Have fun.
