VWVortex.com - Unknown Vibration After Front Axle Replacement?
    Results 1 to 19 of 19
    Thread: Unknown Vibration After Front Axle Replacement?
    1. Member turbowagon22's Avatar
      Jun 25th, 2011
      seattle
      2000 a6 avant Q, MK2 Golf GT
      10-16-2012 01:19 PM #1
      I have a 2oo1 b5.5 passat sedan i recently picked up for cheap. The car was on cut springs and blown struts. I just installed JOM blue Line coilovers on it to solve the suspension problem. While i was doing this i realized both the cv boots were torn and needed replacing. I replaced the axles. The passat is a 1.8t with tip tronic trans. After i did the axles when i put the car in drive and let it idle i get a fairly noticeable vibration through out the car. It does not happen while driving or while in neutral. This did not happen before i did the axles. It doesnt make much sense to me? Any thoughts?
    2. Member turbowagon22's Avatar
      Jun 25th, 2011
      seattle
      10-17-2012 06:15 PM #2
      no ideas?
    3. Member scotts13's Avatar
      Feb 15th, 2007
      Lehigh County, Pa.
      2004 GLS 1.8T
      10-17-2012 06:31 PM #3
      I assume aftermarket axles? Fairly common to get vibration in these cars if you use aftermarket axles. The originals are hollow and vibration tuned, the aftermarket ones are solid steel sticks. It seems paradoxic that the vibration could occur at idle, but enough people have reported it that I have no doubts.
      Pull them and get new or rebuilt VW originals.
    4. 10-18-2012 03:08 AM #4
      Quote Originally Posted by scotts13 View Post
      X2 i work at a VW dealer and we do not sell the aftermarket shafts in the Passat's due to vibrations
    5. Member sdavis872's Avatar
      Aug 20th, 2009
      Omaha, NE
      2003 VW Passat W8 6 speed
      10-18-2012 09:26 AM #5
      Put in a GSP Axle (aftermarket) and it vibrated horribly for 2 weeks, until it blew apart just casually driving through an intersection.
      \\_\__\___http://lowdownlabs.com/ ___/__/_//
      Passat W8 Sport 6 speed manual
      BC Racing Coilovers | Avant Garde M550 19x9.5 | Delinte Thunder D7 245 35 19 | COAM
      SpeedTuning USA Stage 2 | B6 S4 calipers | S5 rotors | Stop Tech Pads
    6. Member turbowagon22's Avatar
      Jun 25th, 2011
      seattle
      10-21-2012 09:10 PM #6
      Thanks guys. This is what i feared. I will have to pull them and grab some stock oem axles. Should have done this from the start.
    7. Member turbowagon22's Avatar
      Jun 25th, 2011
      seattle
      10-21-2012 09:10 PM #7
      Anyone had good luck with raxle axles?
    8. Member scotts13's Avatar
      Feb 15th, 2007
      Lehigh County, Pa.
      2004 GLS 1.8T
      10-21-2012 11:06 PM #8
      Quote Originally Posted by turbowagon22 View Post
      Yes, everyone. Probably better than new VW axles. Buy them.
    9. Member sdavis872's Avatar
      Aug 20th, 2009
      Omaha, NE
      10-22-2012 01:32 AM #9
      I've never heard anything bad about them.Only great things.
    10. Member turbowagon22's Avatar
      Jun 25th, 2011
      seattle
      10-23-2012 02:30 PM #10
      alright done deal. End thread. THANKS
    11. Member
      Nov 14th, 2010
      02 passat variant, 92 cabriolet, 01 a6 4.2, 95 sidekick, 03 tahoe lt
      10-24-2012 04:40 PM #11
      why would you get vibrations at idle because of the axle? and not while driving which is what he's saying unless i'm reading it wrong?
      euro switch, stubby antenna
    12. Member 18t papa's Avatar
      Dec 28th, 2009
      Orange County, NY
      '91 Passat 16V Variant, MK3 Supra Turbo, 1977 Jawa 350
      10-24-2012 04:54 PM #12
      Quote Originally Posted by a4edwin View Post
      Good call there is no reason why the axles would cause vibration if the car isn't even moving, I'm willing to bet that the axles aren't the problem.
      Long live the SCüMWAGON!
      IG: @captain_scum
    13. Member
      Nov 14th, 2010
      10-24-2012 06:01 PM #13
      seems like a bad mount. maybe you notice it more because the suspension is stiffer now.
    14. Member scotts13's Avatar
      Feb 15th, 2007
      Lehigh County, Pa.
      2004 GLS 1.8T
      10-24-2012 08:30 PM #14
      Quote Originally Posted by 18t papa View Post
      I agree that it doesn't seem to make sense, However, as stated above, MANY people here and on other forums report that bad axles caused vibration, even at idle. I'm inclined to believe it.
    15. Member 18t papa's Avatar
      Dec 28th, 2009
      Orange County, NY
      10-24-2012 10:05 PM #15
      I guess it could have to do with the car being in park but I still doubt that an axle would cause a vibration at idle and not in drive or neutral or when driving but I guess anythings possible. I'll stick with my manual tranny
      IG: @captain_scum
    16. Member koidragon1980's Avatar
      Jul 8th, 2011
      Poughkeepsie, NY
      B5 Audi A4 1.8T Quattro, MkVI Jetta 1.8T
      10-25-2012 10:45 AM #16
      start planning on getting the engine mounts (2), transmission mounts (2) and snub mount (1) replaced soon. sounds like you've got several issues going on at the same time. the old suspension was probably hiding a lot of the vibrations that you are now feeling. raxles will help, but if you're still getting too much vibrations at idle, i'd supect the various engine mounts.
      a good test is to pop the hood and have someone sit in the car while it's running. watch the engine for too much movement while changing gears. put it in drive, and with your foot on the brakes, give it a little bit of gas to put the engine under load. excessive bouncing or movement will indicate bad mounts.
      the mounts aren't too expensive but the labor isn't the most fun job as it requires the engine to be jacked up a bit in order to relieve the pressure of the engine sitting on them. the snub requires the front to be put into service position. some have been able to do the snub without this, but it's much easier to work within the small space where the snub is if you at least loosen and move the front bumper and radiator supports back a bit.
      Somebody gave me a stack of dicks back in the mid 90s...
      God bless the homicidal maniacs... they make life worthwhile. - George Carlin
    17. Member turbowagon22's Avatar
      Jun 25th, 2011
      seattle
      10-30-2012 08:15 PM #17
      Ok so i replaced the ****ty auto zone axles with OEM volkswagen Passat axles. The vibration is gone completely. I guess i learned my lesson on taking the cheap way out. Dont do it. I also think it is time for new motor mounts as well. This car was pretty abused by the PO and i have spent the majority of the time ive owned it making it right. Anyway glad the P is happy again. Thanks for all your feed back.
    18. Member turbowagon22's Avatar
      Jun 25th, 2011
      seattle
      10-30-2012 08:18 PM #18
      here she is
    19. Member turbowagon22's Avatar
      Jun 25th, 2011
      seattle
      10-30-2012 08:23 PM #19
