VWVortex.com - How to Check if ECU Miles and Odometer Miles Match?
    Results 1 to 20 of 20
    Thread: How to Check if ECU Miles and Odometer Miles Match?
    1. Member aeffertz's Avatar
      Dec 6th, 2009
      Ladysmith, WI
      '84 Rabbit, 2012 GTI
      10-22-2012 12:26 PM #1
      Hey everyone,
      So apparently the car I purchased had the cluster swapped. The PO said the car has like 160,000 miles on it but the swapped cluster reads 220,000 miles. I've read that it's possible to check the ECU for rhe vehicle mileage but I'm unaware how.
      If they are indeed way off, is it possible to rollback the odometer to match the car? I've read a little bit about VAG-TACHO but that's over $400. Will VAG-COM/VCDS be able to read both mileages
      Any input? Thanks in advance!
      Alex
    2. Member mike4-vr6's Avatar
      Jun 11th, 2011
      TX
      MK4 Jetta VR6 / E46 M3
      10-22-2012 02:48 PM #2
      First off, if the cluster miles dont match actual miles it is highly illegal and it wont pass inspection.
      VAG-TACHO is the only thing that will adjust mileage and it will only roll it forward. Also, it is illegal to roll back mileage for any reason. Furthermore, the mileage on the ECU has to match the mileage on the cluster or it wont work.
      This is all information I got from the dealer.
    3. Member .:S's Avatar
      Sep 23rd, 2007
      The Palouse
      MK6 GTI, Two 8v's (sold), 300SEL W126
      10-22-2012 02:50 PM #3
      I don't think mk4s stored this information in the ECU. I have not able to get the mileage on any I have ever scanned, but can from other cars (B6+, MK5+).
      VCDS does have a mode for checking this information if it is available.
    4. Member .:S's Avatar
      Sep 23rd, 2007
      The Palouse
      10-22-2012 02:52 PM #4
      Quote Originally Posted by mike4-vr6 View Post
      When I got my new cluster, before I rolled it forward, it worked just fine despite having 5 miles.
    5. Member mike4-vr6's Avatar
      Jun 11th, 2011
      TX
      10-22-2012 02:54 PM #5
      Quote Originally Posted by .:S View Post
      I was told that the origional mileage is checked during inspection.
    6. Member mike4-vr6's Avatar
      Jun 11th, 2011
      TX
      10-22-2012 02:54 PM #6
      Was it new or used?
    7. Member Soundwave_vr6's Avatar
      Sep 30th, 2007
      Ontario
      3.6 4mo
      10-22-2012 02:58 PM #7
      cause the dealer knows best? all incorrect BTW
      vagtacho will do what ever you want.
      as for OP i don't think you can check one vs the other.
    8. Member mike4-vr6's Avatar
      Jun 11th, 2011
      TX
      10-22-2012 03:00 PM #8
      Quote Originally Posted by aeffertz View Post
      Hey everyone,
      Sounds sketchy though. Was it an R cluster or just to replace a broken one or what?
    9. Member mike4-vr6's Avatar
      Jun 11th, 2011
      TX
      10-22-2012 03:05 PM #9
      Quote Originally Posted by Soundwave_vr6 View Post
      So what besides VAG TACHO can you use to roll back mileage?
    10. Member Einkaufswagen's Avatar
      Oct 25th, 2009
      Michigan
      2001 Baltic Green Jetta GLX, 1982 Mk1 Caddy ABA, 2008 4.2 A8, 2005 6.0 F250
      10-22-2012 03:07 PM #10
      Congrats OP you just bought a car with 220,000 miles on it! The cluster is the only thing that keeps track of the milage, and as stated before you can only roll forward not back on the miles.
      So even if your car does actualy have 160,000, the cluster is the only thing that matters and your car will now be considered a 220,000 mile car.
    11. Member mike4-vr6's Avatar
      Jun 11th, 2011
      TX
      10-22-2012 03:13 PM #11
      Quote Originally Posted by Einkaufswagen View Post
      Thought I was right. Everything I have researched confirms everything I said. I have an .:R cluster that is used that I have yet to install because I have tried all cheap easy ways to do it.
      From what I understand the only way to do it is to first send out cluster to have mileage moved forward or buy VAG-TACHO and then take the car to the dealer when the odometer on the stock cluster matches what the new cluster got rolled forward to and have key coded. (which is like 300 bucks or something).
      Also, there is no other way to install a different cluster unless it is a new one. If the replacement cluster he used was new, then that would put you at 220k mi. Sounds like you got screwed.
    12. Member Soundwave_vr6's Avatar
      Sep 30th, 2007
      Ontario
      3.6 4mo
      10-22-2012 03:19 PM #12
      i rolled back a gli cluster with 88000km on it down to 92km you can roll back no problem. (with vag tacho)
      there is a higher end one vag dash
      Edit : i have rolled back a cluster . swapped a cluster changed the hex coding for red needles
      i know what i'm fuking talking about. all the info is on these forums
      edit 2 : vagtacho is like 30 bucks on deal extreem
    13. Member mike4-vr6's Avatar
      Jun 11th, 2011
      TX
      10-22-2012 03:37 PM #13
      So you are telling me I can buy the $30 VAG TACHO, roll the mileage forward, then plug in the R cluster and the car will run? I wouldnt have to have a new key coded to the cluster?
    14. Member Einkaufswagen's Avatar
      Oct 25th, 2009
      Michigan
      10-22-2012 03:45 PM #14
      If your car is a 2000+ you will need the old clusters SKU in the new cluster to make the IMMO go away as far as I know.
    15. Member Soundwave_vr6's Avatar
      Sep 30th, 2007
      Ontario
      3.6 4mo
      10-22-2012 03:51 PM #15
      yes
      http://dx.com/p/vag-tacho-usb-2-5-fo...-126935?item=2
      http://forums.vwvortex.com/showthrea...ht=cluster+faq
      with vagtacho you can program your keys to the cluster.
      red needles
      get busy
    16. Member aeffertz's Avatar
      Dec 6th, 2009
      Ladysmith, WI
      10-22-2012 04:35 PM #16
      Well, shoot. I don't know what I was reading, then. Maybe it was for a Beetle or something...
      If the computer doesn't also store the mileage and there's no other way to determine/confirm the car's actual miles, than I'm not going to turn it back to what the dude said the car has on it. Lame.
      Also, the little center screen in the cluster displays nothing. Is that called the MFA?
    17. Member Soundwave_vr6's Avatar
      Sep 30th, 2007
      Ontario
      3.6 4mo
      10-22-2012 04:49 PM #17
      in Canada. well Ontario
      when ever you get new plate stickers/ sell the car ect you must state the mileage to the gov't. i know some states have inspections.
      do they record the millage?
      Edit: only early vr6's and gli/r32's had the mfa
    18. Member aeffertz's Avatar
      Dec 6th, 2009
      Ladysmith, WI
      10-22-2012 05:04 PM #18
      Right. You have to state the miles when you register the vehicle, but the guy I bought it from said he's only had it for a short period of time and the owner before him was the one that did all the work. We don't have vehicle inspections here.
      So, that display never displays anything? It's just a '00 2.0 Golf.
    19. Member 24Vjrod1.8T's Avatar
      Dec 23rd, 2009
      Winter Haven, FL
      2004 GTI VR6 2003 Jetta GLS 1.8t
      10-26-2012 09:43 AM #20
      Quote Originally Posted by K3ith View Post
      This has lasted tooo long.....the Vortex is WIDE OPEN
      Quote Originally Posted by ashley877 View Post
      well i am positive i dont, at least didn't i've gotten WAY better, but one time i kinda threw up on him so embarrassing can't believe i'm saying that on here
      Need VAG-com in central FL? PM me!
