Results 1 to 11 of 11
Thread: Current State of Fuel in NY + APR ECU Tune = Recipe for Disaster???
    May 28th, 2012
    NYC
    2009 Stage 2 CC 6MT
    11-10-2012 08:25 PM #1
    A very good friend of mine asked the BP Attendant today on Horace Harding whether they had premium gas, and the attendant responded no premium since the hurricane, and most other stations won't have either. The few that do, are dumping another tanker of regular in to the premium reservoir and then overcharging customers.
    I JUST filled up at a BP this morning on "premium" (and over-charged), and with what I read here about fuel requirements on an APR tune - I am wondering:
    - what can happen if my current map is the 93 Octane Map, but the fuel is actually below 93 octane?
    - possible engine damage?
    - Should I revert to the "Stock" map until this tank is emptied out?
    HELP! If an APR rep reads this - pls provide a response if possible!
    '09 VW CC Sport; 6-speed MT; APR Stage 2; APR Carbonio CAI Stages 1 & 2; APR Down/Midpipes; TSW Nurburgring Matte Bronze Wheels
    Garden State Euros Motorsport Division, President
    CY Racing, Driver
  2. Member 84cabbydroptop's Avatar
    Aug 5th, 2003
    Long Island
    13' Tiguan SE
    11-11-2012 09:01 AM #2
    buy a can of octane boost, 1 or 2 tanks wont kill you
  3. Member ArcticFox's Avatar
    Nov 4th, 2005
    Rockaway, NJ
    11-11-2012 08:38 PM #3
    Revert to the stock map if you have that option.
    I can't even take my car out because the needle is on E and I'll blow up my poor motor with anything under 91 grade
  4. Member
    May 28th, 2012
    NYC
    2009 Stage 2 CC 6MT
    11-11-2012 09:12 PM #4
    Any preferred octane booster brand?
    CY Racing, Driver
  5. Member xk1llxy0urselfx's Avatar
    Jan 15th, 2007
    Clark NJ
    2007 BMP GTI, 2002 S10 Crew cab
    11-12-2012 12:56 AM #5
    STP is what I have always used in the past with my ye olde american V8s. The fuel is definitly screwed up I am sure. Lucky me I filled up before the storm and just did another tank out in PA near allentown last night. Im gonna try and stay away from getting premium in NJ for as long as I can now.
    My other other car has 2,000HP per axle.
  6. Member 84cabbydroptop's Avatar
    Aug 5th, 2003
    Long Island
    13' Tiguan SE
    11-12-2012 05:14 PM #6
    i use lucas, its about $10 a bottle. got good reviews and i never had an issue.
    Mar 4th, 2011
    Long Island/Northern VT
    2003 VW GTi VR6
    11-13-2012 07:59 PM #7
    Go to the hardware store and get yourself a gallon or two of toluene. Its octane rating is 114, so if you add it in a ratio of 1:5 you'll get a little less than 93 octane. It way cheaper than normal store bought octane booster and is easier to buy in large amounts.
    Quote Originally Posted by B518tko4 View Post
    Instead of driving a cheap rice burner you drive an expensive Jew burner.
    2003 VW GTI VR6 <<<clicky
    SHIFT HAPPENS
  8. Member ArcticFox's Avatar
    Nov 4th, 2005
    Rockaway, NJ
    11-14-2012 09:54 PM #8
    Quote Originally Posted by xk1llxy0urselfx View Post
    Most places are putting 87 in the 93 tanks and selling it as 93. Its really messed up atm.
  9. Member xk1llxy0urselfx's Avatar
    Jan 15th, 2007
    Clark NJ
    11-15-2012 12:38 AM #9
    Quote Originally Posted by ArcticFox View Post
    I was told thats illegal and it cant happen. I of course said whats going to stop these idiots from doing it. If you suspect this or know of it, call your local weights and measures. Esp if its in NJ. They can have that station shut down in just a few hours and some hefty fines.
  10. Member .:R32DBP's Avatar
    May 21st, 2006
    01 Jetta VR6. 04 .:R32, 03 Audi A4 1.8T (daily)
    11-18-2012 09:05 PM #10
    Wow I did not even know they were doing that. Luckily I only use my beater right now and that takes regular so I don't have to worry about that. How can you even tell if you're getting regular when paying for "premium"
  11. Member MissVeeDub's Avatar
    Sep 16th, 2002
    NYC & ATL
    had: '96 Golf GL, '90 Golf GL, '89 Cabriolet, '12 Jetta TDI, have: '02 GTI VR6 and '12 GTI TSI
    11-18-2012 11:13 PM #11
    As stated, switch to stock mode before filling up with 87.
    Even if you do a couple of tanks of 87 the timing will adapt and you won't have permanent damage from such a short time of running it with low grade fuel. (That's the answer I got from an APR rep directly)
    When you can get 93oct. run the car to almost empty with what's left of 87oct.
    Then fill up with 93 and run till empty still in stock mode. Timing adjusts.
    On the second tank of 93 feel free to switch it to 93 program.
    I did that, runs like a champ.
    Octane booster....you'll need many bottles for it to make much of a difference...Will end up being a lot of $ spent.
    Also, Westchester gas stations have 93 no prob. I've filled up several times by me and in Yonkers.
    Tania M. Santos
    fb · ig missveedub
    mk4 OEM+ · mk6 APR I+
    38WFC · eurothon 2013 · Ladies' Group 2013 info coming soon
