VWVortex.com - 2012 Jetta Cabin Filter
    Results 1 to 6 of 6
    Thread: 2012 Jetta Cabin Filter
      Sep 17th, 2007
      Texas, USA
      11-21-2012 07:03 PM #1
      Can somebody point me to where the cabin filter resides...in a 2012 Jetta TDi?
      I peeked under the front cowl on the passenger side and there does not appear to be anything there.
      Thanks
    2. Member Fixxxer's Avatar
      Nov 15th, 2002
      Canada Eh?
      2014 GLI E30
      11-21-2012 07:22 PM #2
      Its under the dash in the Passengers footwell. Remove the foam insulation that's under there and you will see the access panel.
      Sep 17th, 2007
      Texas, USA
      11-21-2012 11:58 PM #3
      Thank you
    4. Junior Member
      Oct 9th, 2012
      Bridge Creek Oklahoma, but presently in Casa Grande AZ
      2012 Jetta TDI, DSG, RNS 315 and most of the goodies
      11-25-2012 07:44 PM #4
      Anybody got pictures of the location and how to access the filter. I felt under there and even pulled down the foam (until a fastener stopped me) and did not find the filter.
      I am a bit disabled and have a hard time bending, so if it can be done upright (sorta)with the use of a mirror that would help.
      Thanks
      LC
      Sep 17th, 2007
      Texas, USA
      11-25-2012 09:18 PM #5
      Actually there are 2 fasteners holding the foam up.
      You need a flat blade screwdriver to unscrew the plastic fasteners, then pull the foam sheet out completely. After that if you look from the bottom up, there is a rectangle filter cover door that will slide and release the door cover, then pull the filter out and re-insert the new filter. Door cover goes back the opposite way of removal.
      Ps: its not possible to do this swap unless you are looking up at the underside of the dash, no way to reach it from a lesser angle with a mirror...imo
    6. Junior Member
      Oct 9th, 2012
      11-28-2012 11:59 PM #6
      Thanks, I'll give it a shot.
      LC
