Ok! I posted this on another Audi web-site but looking for answers!
I changed the spark plugs after disc battery. I changed plugs.
Reconnected the battery..tried to start car and would turn over but not start.
Re-did the whole process again...tried to start again nothing.
I checked the fuel line and it was bone dry at the fuel rail...
I checked fuse to fuel pump on side panel with test light it was ok...
I checked the relay to fule pump under dash clicks on off when turning key ok...
I purchased new fule pump and installed..PITA!!!!
I reconnected everything and no power to the pump...? Why? WTF?
I get power everywhere but to the pump...I used test light to check connector no power?
Anyone?...Does the wire harness have anything to do with power to the fuel pump?:banghead:
I purchased a new wire Harness from ECS and the N75 and and temp sender connection differnet from my orig wire harness? AMU engine code 225Q 2001 coupe...? will be calling them...
Anyone with an answer? I will accecpt phone calls 561-662-2454 CoachV
Happy Turkey Day!
the only codes i'm throwing are o2 sensors,,mass air and secodary air pump..I have the diode Mod..no cat and no emmisions..
any answer on why still no power to the fuel pump..all relays and fuses check out ok...anyone..?
How about the oil pressure switch or relay..anyone with a location of those..I check side panel fuse box all ok..i checked all relays under drivers dash all click on off with key switch..
still no power to fuel pump..whats the deal..?:banghead::banghead:
Can you hear the the fuel pump prime when you open the door? Could be a crank sensor.
In vcds run output diagnostic test mode (function 03 in). The fuel pump should be running during this time and you can hear the hissing at the fuel rail.
If the fuel pump works then move on to display group 1 (function 08) and you should see about 250 rpms during cranking. If not the crank sensor could be bad so you will get no fuel/spark during cranking.
Before jumping into more expensive components, try to track down the voltage. Using a multimeter, check for the exact voltage (if any) at the fuel pump. If there is none there, go back to under the dash where the relay is. Tracing the voltage typically leads to the problem causing the voltage. Just because the relay clicks doesn't necessarily mean it's good or functioning properly. Always helps troubleshooting electronic components by either starting at the source and working toward the problem (i.e. Battery to relay and if it checks out then move on to: relay to pump) or in reverse order.
Well..I took it to my guy...He says the problem is in the ECU, because when he was able to get power to the pump the ecu turned it off...I asked about the crank position sensor..he said he will check..then I aked about the hall sender...then too the ECU...PITA...Do ECU's go bad?
Does anyone have the crank posion sensor part # I have a parts book but cannot find...
I had my guy go ahed and take out the ECU..I tried myself at his place gat to it but could not take out. I explained to him to take out and get the part number off the ECU...Hrs later he calls me and says its running..I asked and he says it was a ground wire or relay next too the ECU...
I asked for him to show me and he gave me an answer that it was behind the ECU...
No codes no grahp as too what he had done... Lose ground wire was his answer...
He can give me no proof of anything changed or repaired..He is asking $560.00
Althouhg he has power to the fuel pump...lose ground wire he says..!
Are you kidding me...I argued the fact that 5hrs was supposidly spent on gettting it running...
I take tha car drive a few hundred yards and it start misfireing...I take it to advanced auti..they hook up the OBD no codes...I disc the mass air flow..then take a reading again..shows code for bad mass air..ok I reconnect clear that code..but still have misfire with no codes...
I purchase one coil pack thats all the had...I replace cyl 1 through 4 changing on down the line...
still have bad misfire somewhere...can't figure it out...I will be changing the o2 sensors today front and rear...I purchased the crankshft positon sensor and will replace I purchased the Hall sender will replace that as well and I purchased the V-checker Pro from ECS..so
anything else someone may suggest?....PITA...:banghead:
I'm ready to get rid of thei TT...too many probl:banghead:ems...2001 157,000 miles....
That's what I assumed. All of those components share a common ground, more than likely (without having wiring schematics in my hand). Just as the rest of the guys are saying too.. I would look into replacing the harness. I know ECSTuning has a replacement harness for a decent price. I was thinking of doing the same thing as while I was replacing my clutch, I found quite a few "weathered" spots that could have caused problems had I not corrected them.
I changed the wire harness as far back as I could...
ECS did not have a complete wire harness the 225..only the 180 in stock..
I bought all for connectors and the wires are pretty long so I unwrapped the
old harness and yes amany cracks...re-wired the ground and each wire...
was not as hard as I thought it would be....time consuming....
I have the V-checker and still tells me misfire cyl 1 and 2 and random through all four
runs nasty...I chaanged all four coil packs..still same codes...
Battery re-chared..getting 1682 low voltage....
so..I gave up and its at the Stealership....will be big Money I'm sure....
Thanks guys that responded...
Well after several hundred bucks...Stealership...says the aftermarket coil packs I had were crap
and no good...he re-wired the harnes again..to make sure it was done correctly which it was but took the rewire all the way to the ecu..repaired AND RUNNING LIKE NEW..
ALL COMPRESSION TO ALL FOUR CYLINDERS ARE PERFECT..FOR 157,000 MILES
IT's NICE TOO HEAR... Yes! over paid them biut it runs like new...Braman Audi WPB...
thanks for all the help gentlemen..till the next hick-up...:wave:
Related Threads
Ask a question
Ask a question
VW Vortex - Volkswagen Forum
84.4M posts
1.5M members
Since 2001
