VWVortex.com - Interior window fog
    The Car Lounge
    Results 1 to 20 of 20
    Thread: Interior window fog
    1. Member Nightfox's Avatar
      Nov 6th, 2003
      Hillsboro, OR, USA
      2009 VW Rabbit
      11-23-2012 02:06 AM #1
      I have a 2009 VW Rabbit, and lately (as the temperatures have gotten colder), the inside of the windows often fog up. Particularly, the front windshield tends to build up quite a lot of fog on it. Also, cleaning it seems to make it worse rather than help, as fog tends to build up where I clean it, and many cleaners leave smears on the glass. Sometimes, the fog on the inside of the front windshield is so thick that I can almost see droplets of water forming.
      A couple days ago, I bought some auto window cleaner, a microfiber window cloth, and Rain-X anti-fog. I cleaned the inside of the windows and then applied the anti-fog. The windows seemed nice and clean until tonight, when the windows fogged up on the inside again. The front windshield was pretty much totally covered with fog and smears from the glass cleaner.
      I'm not sure if I'm not cleaning the windows correctly or if there's a moisture leak or if there is moisture trapped inside my car. Are there any special techniques, cleaners, or towels I could use to help prevent interior fog buildup? Or could there be a more serious issue? I'd rather not leave my defrost & A/C on all the time to de-fog my windows.
    2. Member Swapped6n's Avatar
      Feb 11th, 2010
      Amsterdam
      Track ready, Supercharged R32+ Track-Ready Vw Polo 6N, with GTI motor.
      11-23-2012 02:47 AM #2
      It sounds to me that there is a source of moisture inside your car.
      i had this issue too when I had a mini leak of water getting in through my fresh air vent (long story haha)
      The moment I got rid of the water, I got rid of the issue you had.
      Check your carpets if there are anything soggy, first and then take it from there
      If youre able to leave your car in a garage overnight with the windows rolled down, that'd help as well.
      good luck!
    3. Member 330iZHP's Avatar
      Nov 14th, 2006
      E46 Touring and X5 M - FI FTW
      11-23-2012 05:15 AM #3
      AC is your friend
    4. Member mx5er's Avatar
      Apr 28th, 2001
      NY
      11-23-2012 06:16 AM #4
      Recirc constantly running in the closed position? If no then maybe it's stuck in the closed position.
    5. Member GRNWNV's Avatar
      Jul 24th, 2001
      Canada
      16 Toyota 4 Runner & 13 Abarth Cabrio
      11-23-2012 06:54 AM #5
      What's wrong with running A/C on until the fog dissipates? Foggy windows is pretty common is it not?
    6. Member
      Dec 8th, 2004
      Allendale, MI
      11-23-2012 06:56 AM #6
      Yeah, it's almost always water somewhere in the car that causes it. If you can't find an appreciable amount anywhere it may take some time to find the source. You can try keeping some damp-rid in the car to see if it controls the moisture. GL.
    7. Member Tuneman7's Avatar
      Jan 12th, 2010
      New York, NY
      '15 Audi S4, '93 Audi 80, '10 Triumph Daytona 675 SE
      11-23-2012 07:02 AM #7
      Our Audi is pretty bad with this. Damn thing fogs near instantly to the point where you need to pull over from not being able to see anything and the defroster on full blast does next to nothing towards lessening it.
    8. Senior Member feels_road's Avatar
      Jan 27th, 2005
      East Bay Area
      2016 MkVII e-Golf, 2017 MkVII Golf Alltrack, 2000 B5 4M Passat Wagon
      11-23-2012 07:12 AM #8
      OP, also check your hatch carpeting and spare tire well.
      If obvious water intrusion is not the problem, you can buy inexpensive desiccants (Calcium Chloride) at most drug stores (e.g., CVS; "Damp Check"). Get a refill package while you are at it. They work pretty slowly, so be patient. Also, make sure to secure the container so as to avoid spillage of the caustic fluids.
      In my Golf, on a damp and cold night, I can usually shut off the A/C portion of the defog setting after 5 minutes or so, and be fine with just the regular heat blowing at the windshield. YMMV.
      After incessant complaints from a to z, I am now calling all of my characters "special."
    9. Member mraguilar's Avatar
      Sep 27th, 2004
      01 Neon (sold), 07 Caliber MTX, 07 Quest S
      11-23-2012 09:40 AM #9
      dont leave the car parked overnight wiht the AC on the windshield defroster position, the condesation will flow from outside right into your windshield, switch the knob to the vents, and that way you dont get condensation in the morning
    10. Member
      Dec 31st, 2005
      SoCal
      Corvette & SV650
      11-23-2012 10:26 AM #10
      Moisture comes out of your mouth and your skin. The windows are really cold. Of course there's going to be fogging unless you get rid of the moisture. Many people prefer to run the A/C to make the moisture fog more on the A/C evaporator and less on the windows.
      Quote Originally Posted by apizzaparty View Post
      never thought once to use my lefty for the brake. sorry in my opinion it is dumb.
    11. Member sbarrett4's Avatar
      Feb 4th, 2011
      Philly burbs, PA
      87 Fox GL, 90 Audi 90 Quattro, 93 Passat VR6, 97 Jetta GT, 07 Passat 2.0T, 16 GTI
      11-23-2012 03:36 PM #11
      I've had this issues with my past few VW's. Seems to be pretty common. If you don't want to run the A/C defroster combo, try popping the sunroof or cracking the two front windows. It will clear the fog pretty quick if you haven't allowed it to really build up.
    12. 11-23-2012 03:44 PM #12
      There is excess moisture in your car. Get a package of Damp Rid Closet Bags (Home Depot/Target/Walmart/Super market) usually about $3 for $10; hang one up and your problem will go away in a day or two.
      22691
      "I'm trying to live vicariously through jrod here and my vicarious
      life would be better if he had a twin turbo. Or a ****ing pirate
      ship." nm+
    13. Member someguy123's Avatar
      Sep 30th, 2005
      The Financial Lounge
      Handed in my car enthusiast 'card'.
      11-23-2012 03:50 PM #13
      Quote Originally Posted by Nightfox View Post
      Then enjoy your window fog.
    14. 11-23-2012 04:26 PM #14
      I always leave the A/C on if the windows are rolled up. Between rain, passengers etc, humidity will rise in the cabin if you dont get rid of it. Also to note , most VW/Audi cars will not allow the A/C compressor to cycle if the outside air temp drops below 40, so even if you did push the button it wont come on.
    15. Member
      Feb 16th, 1999
      Falls Church, VA
      F31 M Sport Dinan
      11-23-2012 04:26 PM #15
      why not
    16. Member 1985Jetta's Avatar
      Mar 11th, 2012
      1985 Jetta GL 5MT, 1991 Jetta GL 3AT, 1973 Gran Torino station wagon
      11-23-2012 04:31 PM #16
      We have this on the inside of our "white van", but I don't think it's what you're talking about.
    17. Member barry2952's Avatar
      Jun 13th, 2007
      Farmington Hills, MI
      11-23-2012 04:31 PM #17
      Your a/c drain could be plugged. Does your car have a cowl vent? They have drains that can plug up.
    18. Member jettagli1991's Avatar
      Sep 4th, 2002
      Orchard Park, NY
      '91 Jetta GLI, '68 Beetle 'vert, '65 Rambler Classic, '08 Outback
      11-23-2012 07:11 PM #18
      My brother's '97 Civic has this problem. Not just fog- the inside of the windshield actually ices over every day in the winter. There isn't any water in the car, besides the normal melted snow. They've used damp-rid and that made it a little better but didn't solve it. He's ready to sell the car because of it. I've never had any car do it that bad, and I've owned all kinds of decrepit winter beaters with bad weatherstripping, like my Buick with a rear floor that looked like an ice rink.
    19. Member JCT's Avatar
      Feb 1st, 2012
      indianapolis
      '05 scion xA, '68 chrysler newport custom
      11-23-2012 07:26 PM #19
      Quote Originally Posted by leaftye View Post
      this!!!
      i always have to crack open my windows for a few minutes while driving down the road to get rid of fogging problem
    20. Junior Member
      Apr 28th, 2002
      Gatineau, QC
      2007 Golf GTI
      11-23-2012 09:31 PM #20
      I had the same issue last fall (I have a 2007 GTI). It turned out to be the recirc flap motor that had burned out. This doesn't throw any error codes in VCDS.
      My motor had failed with the flap in recirc mode, so the HVAC was always pulling air from inside the car. Check this first:
      1) Open the glove box, and check the right-hand hole at the back of the manual shelf. You'll see the recirc flap
      Fresh Air position
      Recirc position
      2) With the car ON, press the recirc button and see if the flap moves. If not, then your motor's dead.
