send email about VR6 Alternator and Possible ABS Speed Sensor off the Jetta.![]()
#1
TEXT me at 360 820-3060 or email jhelm29@yahoo.com
1993 CORRADO SLC VR6:
pass side axle $30, driver side SOLD
stock vr flywheel $40
control arms - SOLD
K frame - SOLD
cable shifter assembly - SOLD
complete rear brakes - SOLD
VR6 engine "cover" - SOLD
clutch master cylinder - SOLD
Engine stuff:
obd1 lower intake mani $25
water pump with pulley $20.00
vr6 downpipe (with or without o2 sensor hole) $40
distributor engine ignition coil $30
p/s pump with pulley $25
oil filter housing $25.00
rear motor mount bracket $20
front motor mount bracket $40
combi valve $20
secondary air pump $30
EXTERIOR PARTS
oem Hella amber side marker lights $20
door latches $10 each
hood hinges $10 each
upper rad support with small dent $75
driver side door $100
rear hatch w/glass, has 2 small rust spots $50
rear hatch w/glass in perfect condition, comes with spoiler and spoiler motor attached $100
hatch spoiler $30
INTERIOR PARTS
driver door pull/mirror control $25
sunroof assembly $50
rear spoiler motor $50 - one side only goes up half way
auto seatbelt relays $20 each
rear seatbelts $30 each
ABS control module $50
sunvisors $10 each
sunroof motor $50.00
tan leather front door panels $15 each
automatic front seatbelt - PASS side only $60
tan leather rear seats, good shape $45/set
dash switches $20 each defrost, spoiler, headlights, fog lights, seat heater SOLD
hvac control cover plate $15
rear spoiler control module $30
alarm/door lock module $30
cruise control module $30
black dashboard $45
lots of wiring, pulled out and labeled by the general circuit - front end lighting, rear lighting, auto seatbelts, power sunroof, ABS, dash, etc...make an offer on the one you need
1998 JETTA GLX VR6:
MECHANICAL PARTS
auto transmission control module $50
radiator fan control module $30
ABS pump, complete unit with computer $50
subframe with motor mounts $75
upper/lower radiator hoses - automatic tranny hoses $20 each
auto shift box $50
tilt steering column with ignition $40
downpipe $40
AC system - condenser and all lines $60
EVAP system $40
EXTERIOR PARTS
rear license plate tub $20
driver rear door $45
pass front door $60
door handles $10 each
front bumper - skin and rebar $50
rear bumper metal rebar $20
lower radiator support $30
front crossmember $40
INTERIOR PARTS
steering wheel, no airbag $10
dash switches $15 each
ebrake handle with black leather boot $25
sunroof switch/panel $25
overhead lights $5 each
sunvisors $10 each
heater/ac blower motor $40
hvac control panel, only worked on speeds 1 and 2 $15
heated seat harness $30
heater box harness $25
rear harness $30
door harness (fusebox to all 4 doors) $30
dash harness' $10 each
auto tranny harness $50
silver face gauge cluster, 140mph,from automatic car, 160K on it $50
fuse/relay panel $40
2002 JETTA 1.8T
MECHANICAL PARTS
rear brakes w/hubs, stub axles, rotors $50
rear trailing arm brake lines, hard and rubber lines with banjo bolts $10 each
line from clutch master to slave $15
brake master cylinder $25
brake booster $25
clutch master cylinder $25
clutch slave cylinder $25
power steering fluid bottle/lines $20
wiper motor/arms $50
ebrake cables $20 each
heater core $20
EXTERIOR PARTS
roof antenna base with complete harness up to the deck $25
clear fender turn signals $20 perfect condition
front outer door handles $20 each
door latch/lock assemblies $25 each - driver door latch SOLD
windshield washer fluid bottle with pump $25
hood hinges $15 each
INTERIOR PARTS
oem headunit, non monsoon - $30
owners manual $20
front door inner handles $25 each
steering column clockspring $25
driver/pass seat airbag control modules $25 each
power window motors $40 each
sunroof assembly $65.00
dash switches $10.00 each - flasher, defrost, trunk popper - gas door popper, dimmer, ASR , heated seats SOLD
headlight switch $20
seatbelts $30 each, PASS REAR SOLD
Lots of vr6 and some 1.8t parts for sale
http://forums.vwvortex.com/showthrea...3-GLX-MK4-1.8T
#3
lots of a4 quattro parts for sale too![]()
#4
The corrado clutch master cyl, what kind of shape is it in? Not too nasty? A picture would be awesome, very interested in coming to snag it from you.
Buildin mah Corrado: http://forums.vwvortex.com/showthrea...uild-a-Corrado.
Or follow the build on the facetubes! https://www.facebook.com/BuildingMahCorrado
#5
I would take the rad support if it could be picked up in Portland
#6
Do you still have the rear bumper skin? I will be up your way tomorrow. Let me know!!!!
#7
sending u $22 now
Best way to get ahold of me is email....Eurosportgti@yahoo.com
http://www.spoonfedtuning.com/
http://www.centralctcoatings.com/index.html
contact me for all powdercoating/ceramic coating/thermal barrier/sandblasting and glass beading needs
#8
What car is the line from clutch master to slave, brake master cylinder, and clutch master cylinder from?
#9
#10
Damn. I need those from an mk3. thx anyway
#11
