VWVortex.com - Vr6 Tuning
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 30
    Thread: Vr6 Tuning
      Feb 20th, 2011
      Rhode Island...
      2001 1.8t Jetta, 2012 Hyundai Tucson
      12-08-2012 09:49 AM #1
      Can anyone shed some light on VR6 computer tuning? Is there software available that will allow you to tune the ecu at home.
      BooBoo2KGolf // Benjamin // IG: 20vChickCar
      Quote Originally Posted by SlayStation:
      I don't know about you but I don't ride a he. It's a she, I drive her. I'm in control, she's a skank, she's my b*tch.
      Feb 20th, 2011
      Rhode Island...
      12-08-2012 01:30 PM #2
      But then how do others do it? Unitronic, C2, Gonzo etc?
    3. Member ps2375's Avatar
      Aug 13th, 2003
      Meridian, ID
      80 Rabbit(DEAD), 94 Golf, '69 Type1 Sedan
      12-08-2012 01:36 PM #3
      with very expensive tools.
    4. Member Ultramagnus0001's Avatar
      Jun 21st, 2006
      Allentown, PA
      2001 Gti VR6
      12-08-2012 01:53 PM #4
      I had to take my ecu out and send it out, then they added their own tune by replacing the chip and made it removable. I have my factory if chip i want to put it back.
      You can get a smooth, quiet, floaty car and fall asleep waiting to get from point A to B, or enjoy getting there.
      To be good at racing, you have to change your name to Sebastien.
      Feb 20th, 2011
      Rhode Island...
      12-08-2012 05:40 PM #5
      So the challenge comes from replacing the stock PROM with another?
    6. Member
      Feb 18th, 2012
      Lehigh Valley, Pa
      92 Corrado SLC/2010 JSW TDI/2002 Jetta 1.8t
      12-08-2012 08:05 PM #6
      Depends on what ecu you have. Some have removable eproms, you can replace them with a tuned chip. Some are soldered in, they either have to be sent out or get an ecu that has removable eprom.
    7. Member ps2375's Avatar
      Aug 13th, 2003
      Meridian, ID
      12-09-2012 12:24 PM #7
      plus you have to be able to "crack the code" and know what and how to change in the program on the chip. It's not like it comes up in an easy to read table like in MS or something.
      Feb 20th, 2011
      Rhode Island...
      12-09-2012 04:59 PM #8
      So theres no other easy to find mask files for them..
    9. Member JohnStamos's Avatar
      Feb 3rd, 2010
      A4, A6, Mk3, Shelby, 650x
      12-11-2012 10:02 PM #9
      Quote Originally Posted by izzo View Post
      It is not possible because of the internal design of the motherboard in the ECU.
      I seriously don't even know where to start with this comment.
      Seriously guys, why do you even comment on this stuff with zero knowledge of the topic.
      Yes, you can.
      Are you OBD1 or 2?
      1 is pretty simple, 2 isn't so much. Both are doable at home for under $100 invested. Definitions for obd1 are out there, as well as a few halfassed template files. Even if you have no understanding of hex, and can't decompile it yourself, you can still do alot... just be prepared to spend ALOT of time reading, and learning. Scaling for injectors, moving limiters, getting rid of DTC checks, etc is all pretty easy and basic, after that it gets to be a lot more in depth, as there isn't a user friendly software that is dedicated to M5.9, so you have to do alot of legwork. It's all out there, just not in one package. You can't just open one program, load a rom, move some sliders, click some check boxes, have it auto scale for maf/injectors, auto calc checksum, etc like alot of other systems. You have to do it all manually.
      Someone could whip up some OBD1 5.9 specific software pretty easy, but everyone with the ability knows its easier to just get VW owners to pay $200 for a canned tune, sell hundreds/thousands of them, and make a killing, and who could blame them since 99% of the community efforts don't get past bolting on wheels.
    10. Member
      Feb 20th, 2011
      Rhode Island...
      12-12-2012 12:05 AM #10
      Thank you, now we may be getting somewhere.
      What about for OBDII? Thats where the real challenge is. Is tuning "possible" through the OBDII port in say a MK3 or 4?
    11. Member
      Dec 13th, 2009
      Southern MN
      1987 VW Cabriolet, 1982 VW Vanagon Westfalia
      12-12-2012 07:16 AM #11
      Quote Originally Posted by JohnStamos View Post
      Yes, you can.
      Are you OBD1 or 2?
      Very interested in this. You have any links or info to help get a guy started? Where can I find a chip reader?
      Feb 20th, 2011
      Rhode Island...
      12-12-2012 10:03 AM #12
      Ive only been ableto find OBD1 stuff =.
      Check out http://www.moates.net/ he makes a ton of cool products for tuning.
      Google "TunerPro" Freeware/shareware tuning software.
      But then the difficult part comes from the Mask files, which basically tell the software how to read the programing on the chip.
    13. Member
      Dec 13th, 2009
      Southern MN
      12-12-2012 01:01 PM #13
      Quote Originally Posted by booboo2kgolf View Post
      Thanks, mine is OBD 1 so I will check these out.
      Also found ECUCONNECTIONS.com
      A forum dedicated to this. Haven't had much time to explore it yet and you can't even look at the stuff without becoming a member.
    14. Former Advertiser
      May 13th, 2009
      Mass
      Germans & Scandinavians
      12-18-2012 09:43 PM #15
      I used Moates a few years back, and as stated earlier its not for the faint of heart. If you understand hex its not so bad, but definitions were not readily available and last I messed with it STILL were not. Its interesting for someone who has nothing better to do and wants to screw around with programming. For the majority of the community its simpler to purchase whats readily available.
    15. Member JohnStamos's Avatar
      Feb 3rd, 2010
      12-18-2012 09:59 PM #16
      Quote Originally Posted by Phil@VerdictMotorsports View Post
      And this mentality right here is exactly why templates and definitions aren't readily available like other communities.
      Noone want's to do ANYTHING in this community. They want everything handed to them. If it requires ACTUAL effort and, GASP, learning something, it is "too much work".
      There ARE definition files out there. Motronic 5 isn't that complicated. I had ZERO coding/programming experience beyond light C++ before messing with any of this, and I was able to figure it out in no time.
      99.9% of people have ZERO clue on what to touch for desired results even if there was a fool proof template provided, so the hurdle of figuring out the coding aspect is EASY in comparison to ACTUALLY tuning.
      If anyone has doubts in themselves, think: If Gonzo, who has near ZERO understanding of what he is doing, can make half decent tunes and sell them to the masses, you can manage it on your own vehicle.
    16. Member
      May 12th, 2010
      95 VrT, 04 R32
      12-19-2012 07:41 AM #17
      Jacking with a semi closed system seems like abstraction to me, but then I do stuff like that all the time, so who's to say.
    17. Member Einkaufswagen's Avatar
      Oct 25th, 2009
      Michigan
      2001 Baltic Green Jetta GLX, 1982 Mk1 Caddy ABA, 2008 4.2 A8, 2005 6.0 F250
      12-20-2012 03:46 PM #18
      For OBD II cars there is a program called Lemiwinks that you can use to tweak the ECU within its allowed tolerances.
      See here:
      http://forums.vwvortex.com/showthrea...inks-The-guide
      If your changeing cams or doing any crazy work this program will not work. It also wont work if your ecu is already chiped or whatever Stock OBD2 ECU's only.
      It worked well for me when i had 268 cams and i dident want to buy a chip because i knew i was going turbo in a year or 2 so i used it to dial my ecu in to run a little better with the 268 while i waited for the turbo and my real tune from whoever.
    18. Member DBL_TKE's Avatar
      Sep 2nd, 2010
      Aloha, OR
      '04 R32, '91 Chevy Camaro Z28
      02-02-2013 06:15 AM #19
      This is exciting. I'm familiar with TunerPro RT for tuning my Camaro. Now I just need to find the stock definition files and masks for an OB1 VR6. Is there anywhere I can find these?
      '92 GTI | 12v VR6 | FK Highsport coilovers | 16x8.5" Corvette Salad Shooters | 205/40/16 | full MK3 front subframe/rear beam | Zimmerman front/rear rotors | TT chip | TT exhaust
      My MK2 VR6 build thread
    19. Member
      Jul 9th, 2009
      Dirty jerz
      97 jetta GLX
      02-02-2013 08:02 AM #20
      what software/program does gonzo use then for obdII? does anyone know
      "You see, i'm from Jersey."
      That'll cover about anything.
      VRalliance #6
      1992 VW Golf - Supercharged VR6 - 11.66 @ 117
    20. Member
      Jan 18th, 2009
      Windermere, Fl
      2011 mazdaspeed3 tech package, 2010 mitsubishi outlander xls tech package
      02-03-2013 11:29 PM #21
      I was just thinking about doing this with a vr6 to get better fuel mileage. Something like a fuel economy tun. Mess with the timing and try to feed the car as little fuel as possible to get better mpgs. Have it running on 4 cylinders lol and when you want your power pack to have it preloaded to your other settings.It works for guys on the ecomodding sites so don't see why it won't work here. I just have to get a vr6 again so I can tinker.
    21. 02-03-2013 11:43 PM #22
      Why don't you put your money where your mouth is? If you think I don't have a clue of what I'm doing, let's meet at a dyno and see who can get the most out of a car.
      Better yet, let's see who can come up with the BEST features on these ECU's.
      Launch control based on clutch pedal:
      Adjustable 2-step:
      And just so you see what goes behind the scenes, behind the maps, in the actual assembly code:
      Assembling code with Keil compiler
      Analyzing differences between files
      Come at me "JohnStamos". I want to see what YOU have done with these cars, if anything at all
    22. Member JohnStamos's Avatar
      Feb 3rd, 2010
      02-04-2013 02:24 AM #23
      Quote Originally Posted by RecycleBin View Post
      Adjustable 2-step:
      Remember the thread where you posted your POS car misfiring with your "gonzo tuning" Chinese sourced "ko4 hybrid" and you trying to tout it off as being "a great new turbo design I had made for the 1.8t community that builds 20psi in neutral with no antilag!!!"
      Yeah, I'll never waste my time on you. You just have the threads blackholed and delete you posts when you get torn apart, so whats the point?
      Why the new name? You get banned AGAIN? Maybe some of the companies out there finally got sick of you disassembling their files and copying them as your own.
    23. 02-04-2013 09:44 AM #24
      Yawn. All I hear is "bla bla bla I'm not gonna answer the question because I know I'm a pussy and I'm not on his level"
      Grow a pair. If you talk the talk you must be able to walk the walk.
    24. Member DBL_TKE's Avatar
      Sep 2nd, 2010
      Aloha, OR
      02-04-2013 09:50 AM #25
      .bin and .xdf files... Does anyone know where I can locate the stock stuff?
