VWVortex.com - Hard Top Cabrio
    Page 1 of 4 1234 LastLast
    Results 1 to 25 of 81
    Thread: Hard Top Cabrio
    1. Member Moshua's Avatar
      Jul 20th, 2010
      Cincinnati OH
      1985 Vw Jetta Coupe 1.8t, 1990 Vw Golf Gls 8v, 1994 Dusty Mauve Jetta Aba
      12-14-2012 01:12 AM #1
      What I'm working with here is my mk3 cabrio, I've replaced the top once and have no leak issues but I want to take it a step further. I've seen the modular mk1 top and a few other failed attempts at hardtop but I think I've figured out the best and cheapest way to go about the removable hardtop.
      Bought an old frame with torn top and glass from a friend. I started stripping it down to bare frame.
      This joint will be welded solid
      Another joint I will make permanent so I can get the form correct
      All the moisture guard, headliner and various cables needed for up and down movement have been removed
      Bare frame
      Next I will put a light weight mesh over the frame and start laying some fiberglass down and removing some of the excess weight that is in all of the hinges that won't be needed and the the old heavy thick mounting brackets.
    2. Member tgibson's Avatar
      Sep 27th, 2010
      Westerly RI
      1979 Rabbit
      12-14-2012 01:20 AM #2
      for something different.
      May 29th, 2010
      Oakdale CT
      98 jetta vr6...95 jetta 2.0 (sold)...2000 civic si
      12-14-2012 01:40 AM #3
      Good ****!! im watching
    4. 12-14-2012 01:41 AM #4
      interesting
    5. Member Pineapplegti !'s Avatar
      Dec 17th, 2008
      Las Vegas NV
      2015 f150 2.7eco scsb.2014 brown/brown TDI t-reg .Berg Mk1.Turbo rail
      12-14-2012 02:02 AM #5
      So basically this is a thread about you stripping a junk cabrio top. I doubt this will go much further than this.. prove me wrong
      autocrats...
    6. Member justinarias's Avatar
      Sep 27th, 2009
      Long Beach, Ca
      12-14-2012 03:16 AM #6
    7. Member Moshua's Avatar
      Jul 20th, 2010
      Cincinnati OH
      12-14-2012 04:10 AM #7
      at this point yes it is just a stripped frame but it will be taking some real shape in the next few days. i've found the mesh i will use as a "rebar" so to speak for the fiberglass and foam i will use for rigidity and shape. first things first though, i need to get a shell made up so i can figure out exactly where it will set on the car. I'm also trying to keep the original soft top so this could be an add on or a very good solution for winters, when most soft tops can get damaged from cold and snow. Should seal in heat and air conditioning a bit better than most soft tops since its not exactly a sealed cabin with the soft top.
      Front mounting points will be the stock ones with same oem clamp mounts to front of top. Another notion came to me when setting this on my car. it could be a roof rack also with appropriate bars mounted (but thats another topic).
    8. Member Andrewrg's Avatar
      Sep 5th, 2010
      Littlestown Pennsylvania
      MKIII's in my heart, MKVI in real life
      12-14-2012 09:51 AM #8
      Nice project! Following this.
      Instagram: @_andrewrg_
    9. Member ralph lauren's Avatar
      Nov 3rd, 2012
      RHD 1997 Volkswagen GTI, 2001 Volkswagen Cabrio
      12-14-2012 11:08 AM #9
      Can't wait to see the finished product.....
    10. Member .T.o.n.y.'s Avatar
      Apr 3rd, 2003
      Hells heat AZ
      96' Jetta aba-t, 00' Audi A4, 01' Passat 30v
      12-14-2012 11:41 AM #10
      Stick with it man ive been thinking of this same thing for a while. I think a hard top cabrio would look awesome i'll for sure been keeping up with your progress. Good luck!
      I am a Vortex build addict, click the link below to check out my builds and join in on my addiction:
      http://forums.vwvortex.com/showthrea...0#post85285470
    11. Member Mr.Broke's Avatar
      Mar 29th, 2011
      860 CT
      mk3's
      12-14-2012 05:27 PM #11
      Subscribed
      Quote Originally Posted by mk2stutter View Post
      its a car forum not a my search dick is bigger than your search dick forum.
    12. Member jeuro's Avatar
      Mar 6th, 2008
      Wa
      '99 Silver Arrow '01 B5 A4
      01-20-2013 08:55 PM #12
      update?
      SFSC
      Kiss the ground
      Car Whore.
    13. Member Willey007's Avatar
      Aug 6th, 2004
      Delaware
      1999 VW GLX
      01-20-2013 09:00 PM #13
      Quote Originally Posted by jeuro View Post
      update?
      yea, this looks promising!
      MK<3
      IG: @willey007 #vento007
    14. Member that_guy_bry's Avatar
      Jan 14th, 2006
      Pennsyltucky
      2 of them in red
      01-20-2013 09:47 PM #14
      Best idea yet , watching this for sure !
      Is it going to be quick release and when the top is off will you have some cover to cover the area where the mechanical parts were hidden ?
    15. Member Moshua's Avatar
      Jul 20th, 2010
      Cincinnati OH
      01-20-2013 09:59 PM #15
      Quote Originally Posted by that_guy_bry View Post
      there will be no mechanical parts. the stock cover will cover all holes and areas that were there. i'm working on the skin currently, i should have a rough top together by end of the month
    16. Member DannyMK3's Avatar
      Feb 14th, 2012
      FL
      96 VW Golf 4DR
      01-21-2013 12:03 AM #16
      Subscribed.
    17. Member mk3_vws's Avatar
      Oct 23rd, 2007
      Chambersburg PA
      03 Jetta, 96 summer beater Cabrio, 97 2.0T garage queen Jetta
      01-21-2013 12:11 AM #17
      Quote Originally Posted by Pineapplegti ! View Post
      exactly ....i always see an awesome build that starts off then just disappears to nothing
      Fender roller for rent! pm me for more info (sorry not willing to ship out)
    18. Member
      Nov 8th, 2011
      98-VR6 96-tdi 05-Impreza 04-Tundra
      01-21-2013 12:21 AM #18
      cool idea,
      won't happen.
      Quote Originally Posted by germancarnut51 View Post
      Harbor Freight makes some decent tools
      Quote Originally Posted by VT-MKJett View Post
      I would question if that is a productive goal to have.
    19. Member Moshua's Avatar
      Jul 20th, 2010
      Cincinnati OH
      01-21-2013 10:20 AM #19
      Quote Originally Posted by Svën Höek View Post
      cool idea,
      won't happen.
      It'll happen, it's happening. Just been a little cold this month and I haven't had a lot of time
      Sent from my HTC One X using Tapatalk 2
    20. Member riceslayer's Avatar
      Feb 15th, 2012
      17202 PA
      soot machine
      01-21-2013 10:23 AM #20
      subbbbbbb'd
      Quote Originally Posted by 90dub View Post
      these pics make me wanna punch baby monkeys
    21. Member
      Aug 31st, 2010
      monroe, ny
      97 jetta 1.8t, 91 jetta awd vr, 84 rabbit RHD
      01-21-2013 11:17 AM #21
      im interested to see how this turns out
    22. Member .T.o.n.y.'s Avatar
      Apr 3rd, 2003
      Hells heat AZ
      01-21-2013 12:59 PM #22
      Give the guy a break he's in Ohio, im sure its freaking cold there right now. OP.... ignore the bull for doing something different.
    23. Banned the mad conductor's Avatar
      Nov 11th, 2009
      mesa az
      corrado
      01-21-2013 01:48 PM #23
      i know what you mean about the cold, **** sucks. do work son, do work
    24. Member MKVmyfast's Avatar
      Sep 15th, 2008
      Danbury, CT
      06 VW GTI 2.0T FSi BMP 06 Subaru Impreza 1998 VW Jetta VR6 Artic White 1998 Ginster GTI
      01-21-2013 02:04 PM #24
      Subscribed
      Sent from my HTC Sensation 4G using Tapatalk 2
    25. Member
      Oct 7th, 2004
      findlay, ohio
      97 Ram 1500
      01-21-2013 02:55 PM #25
      I hope this turns out good.
      Keep Calm & Chive On
      FKA gti_r_done
