VWVortex.com - Cigarette lighter fuse
    Results 1 to 13 of 13
    Thread: Cigarette lighter fuse
    1. Member Project_617's Avatar
      May 6th, 2006
      malden, Massachusetts
      Daily 2014 Tiguan 4 Motion Bagged
      12-16-2012 09:36 PM #1
      okay so my fiance some how manages to blow the fuse to my cig lighter socket , i checked on the drivers side panel and all the fuses look good, ive been searching for info ppl say its in a diffrent location , #28 the #42 and blah blah same FUSE is still good, im going crazy here cuz i cant fint the right info for my car...its a 08 gti dsg so sun roof or leather seats, stock crapy radio not the Nav. if any one can help i will glady appriciate it , going on a long trip soon so i need this figured out
    2. Member Project_617's Avatar
      May 6th, 2006
      12-16-2012 11:48 PM #2
      any one?
      Jun 17th, 2008
      Bronx NY
      06 MKV GLI & 07 Fahrenheit
      12-17-2012 02:04 AM #3
      going throught the same problem. The charger in the trunk should work. not great help but good enough for ur trip hopefully.
      I have Vag-Com NYC
      Instagram Arismkv
    4. 12-17-2012 02:13 AM #4
      omg is this a mkv glitch? both my interior cig lighters light up but dont get any power either, but the trunk plug works perfectly fine.... all my fuses are fine as well
      formerly TVarmy04 & DUBMANG
      SAPPERS LEAD THE WAY
      Quote Originally Posted by jspirate View Post
      Now, having unprotected sex... thats a whole different beast. There are some crazy hotties out there... whew!
      Jun 17th, 2008
      Bronx NY
      12-17-2012 02:18 AM #5
      Quote Originally Posted by DUB_MANGv2 View Post
      Has also happened to my brothers 07 passat b6, and sisters 06 passat b6. Dealer fixed my sisters with a fuse change. But that fuse is in a different location from my brothers 07.
      I have Vag-Com NYC
      Instagram Arismkv
    6. 12-17-2012 02:28 AM #6
      I recently changed mine on my jetta...not sure if it would be the same
      the manual says there are multiple fuses - i also noticed that there were separate ones for "power outlet" and "cigarette lighter"
      hope this helps
    7. 12-17-2012 03:11 AM #7
      well can u guys list all your locations and ill go through them on my car. i have a 2006 jetta 2.0t. wolfsburg i think. power everything
    8. Senior Member christofambrosch's Avatar
      Jul 4th, 2011
      Pennsylvania
      2015 Audi A4
      12-17-2012 01:02 PM #8
      Check inside the outlet(s) for loose change.
      Sep 12th, 2010
      2008 GLI FSI, 1977 VW Bus, 1967 Karmann Ghia
      12-17-2012 01:14 PM #9
      Check every fuse with a volt meter. They may look good but are blown.
      Quote Originally Posted by genjy View Post
      Yes, there is a high chance that the tractor trailer was the one going 160MPH, not the Porsche GT2 RS.
    10. Member kern417's Avatar
      Jul 31st, 2011
      Louisville, KY
      2009 GLI
      12-17-2012 01:18 PM #10
      i've found the fuse diagrams to be pretty useless. there are so many different versions on the mkv. the manual that came with my car doens't match my fuse panel at all.
      There's a little bit of rice in all of us.
      MK5 COMPLETE PARTOUT
    11. Member JetTurbo's Avatar
      Sep 17th, 2001
      Cincinnati, OH USA
      2012 Golf R, 2008 b6 Passat 4-Motion
      12-17-2012 01:35 PM #11
      Quote Originally Posted by kern417 View Post
      You are right, the fuse charts in the owners manuals are close to useless.
      Probably the only way to obtain a reasonably accurate fuse chart is from the
      Bentley Publishers - VW Repair / Service Manual that covers your model mk5.
      The fuse charts provided there are grouped by build date (placard on drivers door jamb).
      For example, my '06 a5g is covered by either a DVD-ROM version or a paper version.
      2102 US Golf R, 2008 US b6 Passat 4-motion - sold 2006 US Mk V bmp GTI mt (230,000 miles/ 7 yrs)
    12. n00b FOM GLI's Avatar
      Dec 16th, 2012
      Orlando
      2006 Jetta GLI
      12-17-2012 02:59 PM #12
      The ones in my 2006 GLI were blown as well. Both 25 amp fuses. Believe they were #s 24 and 25. HTH.
    13. Member EnvyMyMKV's Avatar
      Apr 8th, 2011
      Toronto, ON
      MKV Jetta
      12-17-2012 04:12 PM #13
      Might as well add to the list
      2010 Jetta, my front 12v never worked since in got the car 2 years ago, haven't checked the others though and never needed it badly enough to fix it (or try to), but now that its on my mind i'll have a look.
      Instagram: @_ratedPG
