    Page 1 of 11 12345 ... LastLast
    Results 1 to 35 of 373
    Thread: FrankenTurbo F23 Project: FrankenTT is go!
    1. Banner Advertiser doug@frankenturbo.com's Avatar
      Jul 1st, 2009
      Westchester County, New York
      12-18-2012 03:53 PM #1
      NEW VORTEX LINK FOR ORIGINAL THREAD (per Anthony@VMG)
      Original Thread: http://www.vwvortex.com/FrankenTT/page1.htm
      [Anthony, 12/22/12]
      thank you!
      www.frankenturbo.com
      Let's Do This
    2. Banner Advertiser doug@frankenturbo.com's Avatar
      Jul 1st, 2009
      12-18-2012 03:54 PM #2
      All -- as you can see, I have re-created the FrankenTT thread and have every intention of restoring the old along with inflicting the new. Mistakes happen, and while the loss of the original thread was a disappointment, I have a lot of confidence that everyone's posts and input can be restored to this forum.
      My love for this 1.8T tech forum is strong. This week's headaches do little to impact that. Thanks to everyone who has contributed, cheered, joked and sniped. You have enriched my advertiser experience greatly.
      Yours
      Doug Harper
      FrankenTurbo
      Let's Do This
    3. Banner Advertiser doug@frankenturbo.com's Avatar
      Jul 1st, 2009
      12-18-2012 03:58 PM #3
      At the close of 2012, here is how the car is configured (in more-or-less chronological order)
      Eurodyne Maestro
      Eurodyne Boost Manager WMI and fuel pump control
      FrankenPump in-line fuel pump
      PumpTec 113C high-pressure WMI pump
      42 Draft Designs open-element intake
      42 Draft Designs 3" turbo-back exhaust
      Vertical flow front-mount intercooler
      235/35/19 tires front -- 265/30/19 tires rear
      PowerWheels Pro replica wheels
      Audi S4 MAF (3" ID measurement)
      FrankenTurbo F23 hybrid K04
      Relentless V3 exhaust manifold
      SEM intake manifold
      INA 3" throttle body
      USRT Genesis2 500cc injectors
      Eurospec adjustable fuel pump (set to 4bar)
      Mk6 coil packs
      42 Draft Designs catch can
      Haldex Blue controller
      ClutchMasters FX400 clutch
      OEM dual mass flywheel
      Prototype 2.0L "drop in" stroker engine
      Prototype RS4-inspired camshafts
      External 60-2 crankshaft speed sensor
      AEB head with Supertech valve train
      Supreme Technology Engineering Performance Parameters Display (PPD)
      That's a pretty comprehensive list. And documenting all those mods took up close to 40 pages (for a look at that, click HERE). But there's still much to tinker with. Firstly is performance on straight pump gas. How much loss will there be in power? How much gain in EGTs? Those are questions I'll have an answer for shortly.
      Let's Do This
    4. 12-18-2012 05:48 PM #4
      If it helps any, Doug: Backup
    5. Former Advertiser
      May 13th, 2009
      Mass
      Germans & Scandinavians
      12-18-2012 06:32 PM #5
      Glad to hear you were able to resurrect parts of the old thread Doug
    6. Member l88m22vette's Avatar
      Mar 1st, 2006
      Chicagoland, IL
      12-18-2012 08:28 PM #6
      Not gonna lie, that cache is impressive, quite a bit is there
      Audi TT mk1 FAQ zero Fuchs given
      Quote Originally Posted by deucestudios View Post
      Portland didn't like the Hellcat. Mr Farrah should have put a bird on it.
    7. Member flamtastix's Avatar
      Mar 8th, 2011
      Carroll Valley 17320
      Bagged awd GTI, B6 A4
      12-18-2012 10:42 PM #7
      Mad props for handling this whole situation like a pro, and not loosing your cool! Maybe it would be a good time to make a "mod list" of where the TT currently sits...I know I was getting a bit confused with the constant flow of parts and ideas.
      For a great contribution to the community and a great product!!
      [HOOLIGAN]
      304 Dips
      Pat's Speed Shop
      Airlift bags w/V2. Frankenturbo.
    8. Banner Advertiser doug@frankenturbo.com's Avatar
      Jul 1st, 2009
      12-18-2012 10:52 PM #8
      Picking up from where we left off, the car received its new rear "shoes" today. Out with the 235/35/19 Goodyears, in with the 265/30/19 Sumitomos. The tires were a very tight squeeze onto the 9" rims, but the guys at my local Mavis were persistent and got them mounted.
      John at 42Draft Designs came through with perfect 15mm spacer/adapters for the 112mm-bolt-pattern rims.
      The tires are approximately an inch wider, and to keep them from extending beyond the wheel wells, the offset was reduced by 10mm. But even tucked in an inch or so, the rubber still clears the interior.
      And the outside appearance is still fairly "stockish", which is what I wanted.
      With that done, the car can go about trying plain pump gas. It's been re-flashed to Eurodyne's off-the-shelf F21 file and logging is already underway. Will post a few pulls as boost is carefully ramped up.
      Let's Do This
    9. Member jedge1.8t's Avatar
      Jan 27th, 2012
      Rocklin
      2001 TTQ 225
      12-18-2012 10:59 PM #9
      thats one hideous shock absorber.
      sweet wheels doug.
      Tell me how my 01 Audi TT (with a smaller stock engine, and heavier curb weight) walks a 02 WRX wagon...?
      Cause its an Audi.
    10. 12-18-2012 11:21 PM #10
      Glad to see you're somewhat back on track. Perhaps post screenshots of the old thread?
      Quote Originally Posted by gdoggmoney View Post
      There's been too much butt sniffing before this dog fight.
      PagPartsTurbo www.speeding-g60.com INTEGRATEDengineering
    11. Banner Advertiser doug@frankenturbo.com's Avatar
      Jul 1st, 2009
      12-19-2012 12:44 AM #11
      User STOICH has some good ideas for restoring the entirety of that thread. If you click his link above he's already been able to post the whole thing on his own server. I'll work with Anthony about getting the document hosted in such a way that it's searchable here.
      As for the shock: I know, I know. This spring I will modify the car to Audi's "sport suspension" form, which will do away with the old parts and lower the car an inch or so. No more than that!!
      Let's Do This
    12. Member jedge1.8t's Avatar
      Jan 27th, 2012
      Rocklin
      2001 TTQ 225
      12-19-2012 01:46 AM #12
      I agree with flamstix, Definitly should put a MOD list in while were still on the first page of this new thread.
      Cause its an Audi.
    13. Junior Member
      May 24th, 2011
      Alberta Canada
      2001/Audi/225 TT
      12-19-2012 12:32 PM #13
      Quote Originally Posted by doug@frankenturbo.com View Post
      Hi Doug,
      Hmm that shock absorber looks very familiar.
      I think this has to go on the upgrade list as well.
      I am real happy that the Franken TT thread lives on.
    14. Member Big_Tom's Avatar
      Aug 19th, 2007
      Orlando, FL
      01 Jetta Wolfsburg Ed, 04 Jetta GLI 24v 6spd
      12-19-2012 09:40 PM #14
      My Thread Fk AK Coilovers, Full 3" Exhaust, Custom FMIC, Forge Evo14 BOV, Forge Unos MBC, Forge Throttle Body Hose, Prothane Dog Bone Mount, BFI STG 1 Eng/Trans Mounts, Sachs VR6 Clutch Kit, TT Short Shifter, Siemens 630s, Walbro 255, DBB Garrett 50 Trim Turbo Kit, Eurodyne 630cc MAFLESS PAGPARTS FTW -- STEVEBILT.COM -- Integrated Engineering -- FourSeasonTuning.com Don't Buy Anything From *ChunkyPeanuts*
    15. 12-20-2012 10:26 AM #15
      What happen?? I've been out of the country for a while.
    16. 12-20-2012 02:29 PM #16
      Gotta love that Northeast rust
    17. Member carsluTT's Avatar
      Dec 31st, 2004
      riVersIde, cA
      12-20-2012 05:14 PM #17
      nice TT's are okay with a dirty side to them
      CNC plasma services, offering custom parts, tig welding, sheet metal work,boost tubes, cages made in house, paint/body VAG-COM. need parts made?
      exit0customs mk2 build
      TT-Build APR 225 TT stg3+ For Sale
      dCi-vW
    18. Member suffocatemymind's Avatar
      Dec 10th, 2007
      Boston/Providence
      2003 Jetta Wolfsburg 20vT, 1994 Dusty Mauve Jetta 8v (sold)
      12-21-2012 01:43 AM #18
      Very curious to see how those new tires help with traction...also excited to see this thread semi-back up and running
      APR 93 | ITG | MMEvoDV sin N249 | 034 Silicone Breathers + Catch Can + VC Heatshield | EuroSport 2.5" DP | BFI Stg 1 | BKR7EIX @ 0.032" | NewSouth | VCDS | Bentley
      Stock(ish)
      Been there, done that.
    19. Banner Advertiser doug@frankenturbo.com's Avatar
      Jul 1st, 2009
      12-22-2012 02:43 PM #19
      So with the PumpTec WMI pump out for warranty replacement, I've been experiencing "how the other half lives" on a plain ole 93oct car. And so far, I gotta say...I like it!
      Here are the logs taken as I gingerly raise boost levels. I'm being especially cautious between 3200-4200 where knock always seems to emerge.
      Even though boosting only around 18psi, the engine is flowing over 270 grams/second. That's a pretty big surprise. And contrary to my earlier belief that the power drops off above 260, the Time-To-Speed shows a much stronger finish.
      See how the 90% duty cycle line runs out of steam up top? Well, now it's not doing that. So why? Isn't that right where the WMI-enhanced timing advance should be strutting its stuff? Or is the WMI simply clogging up the (smallish) turbine housing?
      Very interesting. One other note: the exhaust sounds different. It's raw and angry. And a bit louder. In a word: badass.
      Let's Do This
    20. 12-23-2012 09:10 AM #20
      It's about time you tune this thing to its potential ON PUMP, how most will use it.
    21. Member Big_Tom's Avatar
      Aug 19th, 2007
      Orlando, FL
      12-23-2012 09:45 AM #21
      Quote Originally Posted by Rod Ratio View Post
      THIS. I personally am not interested in what people are doing with Race Fuels, W/M, E85, NOS, etc.... 93 octane pump is where it's @
    22. 12-23-2012 10:59 AM #22
      You guys must hate us brits with 99 octane and 102 on the continent :p
    23. Member Big_Tom's Avatar
      Aug 19th, 2007
      Orlando, FL
      12-23-2012 11:00 AM #23
      Quote Originally Posted by superkarl View Post
      no hate... your gas prices are not pretty
    24. 12-23-2012 11:21 AM #24
      It's to my understanding that your octane ratings are different than ours; hence the higher numbers. Your 102 is like our 94, etc
    25. 12-23-2012 11:47 AM #25
      im not entirely sure how it works, but something like that yes, ours are a tad higher though.
      I know that if you take a european car over there like my S3 it wouldnt run very well.
      To doug, is this the car you tested the N/A cams in?
    26. Member
      Sep 22nd, 2012
      Essex, England
      Audi S3 8L
      12-23-2012 11:52 AM #26
      Fancy seeing you on here
      As said above their octane ratings are different to ours
      Yes I believe it was the same car (frankenTT) that tested all the different cams
    27. 12-23-2012 11:57 AM #27
      Alright stacey!
      Yeh ive just read that your fuels are 4-5 points lower for the same fuel.
      Ours are measured in RON, US are measured as an average if RON + MON/2
    28. Banner Advertiser doug@frankenturbo.com's Avatar
      Jul 1st, 2009
      12-23-2012 02:12 PM #28
      Quote Originally Posted by Big_Tom View Post
      I completely agree. I cannot figure out why i didn't do this earlier. And I know it's not "technical" to say, but the car feels like...it is happier somehow.
      Let's Do This
    29. Member l88m22vette's Avatar
      Mar 1st, 2006
      Chicagoland, IL
      12-24-2012 06:27 PM #29
      Not really scientific either, but straight 93 is pure, and let's your engine/tune do its job. Any kind of "additive" (aside from specific gasoline octane) gives the engine something else to work on. I mean, if you think about it, at a given boost/RPM combustion will use a specific amount of intake air/fuel mixture - with w/m you can only have that present at the expense of a certain, very small amount of fuel; again at a specific combustion chamber volume. You're gaining a lot with w/m which should offset any theoretical issues you might have but still, less fuel with something else being burned. Yes you will make more power with w/m and really pushing the turbo, but at that point of modification the engine is nearing the bleeding edge of what it can really do on a given setup, and it might simply feel like that. You tune for it and it gives better numbers but sometimes small things make a big difference...
    30. 12-24-2012 09:59 PM #30
      I like diesel fuel personally.. Feels/smells manly
    31. Member 04VDubGLI's Avatar
      May 20th, 2005
      Pittsburgh, PA ish
      04.5 VW GLI 1.8T
      12-24-2012 11:41 PM #31
      Glad to see this guy is back... in for results.
    32. Member
      Apr 4th, 2005
      Georgia
      12-29-2012 08:55 AM #32
      Gwinnett Beat the Heat's Jetta GLI received its martindale cams courtesy of Doug Thursday and next week the V3 Manifold should be in as well from Rich over at XS Power. Props to them for helping out an awesome cause!! I will be starting to tear down the motor next week and get everything installed and hopefully in about a month or so I can start tuning it with my Injector Dynamics 725cc injectors and water meth setup.
      Doug I can't wait to start shooting you numbers and time slips once I start racing!!!
      Matte Black Drag GLI / Frankenturbo / INA Internals / EPG Atlanta / Stasis Engineering / ATP Turbo / PAG Parts
      http://www.inaengineering.com/
      http://www.bthgwinnett.org
    33. Banner Advertiser doug@frankenturbo.com's Avatar
      Jul 1st, 2009
      12-29-2012 12:16 PM #33
      The weather here in the NYC area has been pleasantly cool for the last few days. So when the roads are dry enough, the FrankenTT has been getting the boost ramped up.
      Here's a look at what the PPD is seeing from the manifold plenum:
      And here are the other parameters for the 93octane setup:
      So the intake temperatures are clearly a point of concern. But that can be remedied by the Garrett core which Ed at ForceFed has standing by for the car. So otherwise the data all look pretty good. even the Lambda is on the money despite ~90% duty cycles on the 500cc Genesis2 injectors. These newfangled injectors are touted for their high duty cycle flow accuracy, and given the logs I'd have to credit them for that. But what about that 280g/s airflow? Time was, I made the pronouncement that anything over ~260 would bottle up the hot side, hampering top end horsepower. So let's have a look at the ole Time-to-Speed graphs. Here is the latest revision, with higher boost, versus previous.
      Uh, oh. It looks as though the top end is starting to suffer a bit. The added 10g/s with this latest file is HURTING, not helping.
      For another comparison, here is what the top end at lower boost/airflow looks like:
      This configuration of stroked motor, Relentless V3 exhaust manifold, & cams is just not helped by airflows above a critical value. Why? While obviously good (and a screamer under the hood), maybe the manifold just isn't sufficient above that airmass. Regardless, the midrange feels terrific. So I'll duck the top-end boost duty down to 65% or so and focus on the middle part of the power band.
      Let's Do This
    34. 12-29-2012 12:22 PM #34
      What rail pressure are you running on the 500 cc genesis II's?
    35. Banner Advertiser doug@frankenturbo.com's Avatar
      Jul 1st, 2009
      12-29-2012 12:53 PM #35
      (only) 4bar. When the car dynoed ~320whp early this year, they were running 5bar pressure.
      Let's Do This
