VWVortex.com - FS: Brand New OEM VW Rear View Backup Camera Kit
    Page 1 of 5 12345 LastLast
    Results 1 to 25 of 109
    Thread: FS: Brand New OEM VW Rear View Backup Camera Kit
    1. Former Advertiser
      Aug 20th, 2012
      Greater Chicago Area
      2012 Golf R CW 4Dr
      12-24-2012 04:13 PM #1
      Hello everyone:
      Finally in stock!!!
      Brand New Genuine OEM VW Emblem Rear View Camera Kit with first in the market full Plug N Play Wire Harness (Does not require cutting or adding connectors), and OEM VW Drain Tube.
      Fits All MKVI 2010-2013 Golf/Gti/R Hatchbacks. Requires Either RCD-510 with Video In (Not all of the RCD-510's have this option) or
      RNS-315 or RNS-510 (Both Navigation units are fully compatible. RNS-510 has much larger screen).
      Kit comes ready to install. Picture shows Protective foil, which is used from the manufacturer to protect the chrome finish of the emblem. I have peeled back the foil to show true shiny part of the emblem.
      Price for each kit is $537.00 + Shipping
      Shipping costs:
      USA - $10.00
      Canada - $21.00
      Cheers,
    2. Member VW_König's Avatar
      Jun 27th, 2011
      2013 Golf R
      12-24-2012 11:18 PM #2
      What is the price for this with RNS-510?
    3. Former Advertiser
      Aug 20th, 2012
      2012 Golf R CW 4Dr
      12-26-2012 01:20 PM #3
      All PM's replied.
      Thanks for your orders!!!!
    4. Member
      Oct 28th, 2004
      Wstchstr Cnty, NY
      2012 Golf R DBM
      01-27-2013 08:57 PM #4
    5. Member roshlioBG's Avatar
      Nov 4th, 2004
      NNJ
      Top Secret
      01-27-2013 09:21 PM #5
      Installation instructions preview? Email me or PM. I'll buy a set, just need to see what the install is about. Thanks
    6. Former Advertiser
      Aug 20th, 2012
      2012 Golf R CW 4Dr
      01-28-2013 09:20 AM #6
      PM's replied.
      Cheers,
      Peter
      Feb 4th, 2003
      Massachusetts
      2013 CC R-Line, 2008 Passat B6 2.0T
      02-03-2013 02:43 PM #7
      Will this work on a 2013 CC?
      Sent from my iPad using Tapatalk HD
      Apr 21st, 2012
      New York
      '13 Golf R, '08 .:R32 #133 traded in
      02-07-2013 09:04 PM #8
      still have the backup camera and the OEM LED's ? and how much for the LED's?
      Apr 5th, 2012
      Hellertown, PA
      2012 RB Golf R
      02-07-2013 10:21 PM #9
      Quote Originally Posted by Sonic32 View Post
      Peter is on vacation until the 17th, but I know he just got a shipment of RVCs just before he left, so when he gets back he should be able to hook you up
    10. 02-08-2013 04:02 AM #10
      What would shipping be to Canada?
    11. Member
      Feb 4th, 2003
      Massachusetts
      02-09-2013 08:50 PM #11
      Has anyone installed this yet? Do you get the yellow lines to guide you?
    12. Member EvoKnvl's Avatar
      Jan 23rd, 2012
      Bay Area
      Current: BMW VO 1M / Sold: VW RB 4Dr Golf R Stg 3
      02-09-2013 10:15 PM #12
      Quote Originally Posted by faroodi View Post
      Just installed it yesterday. You get the yellow lines
    13. Member
      Feb 4th, 2003
      Massachusetts
      02-09-2013 11:10 PM #13
      Quote Originally Posted by EvoKnvl View Post
      Tx
    14. Member roshlioBG's Avatar
      Nov 4th, 2004
      NNJ
      Top Secret
      02-10-2013 07:49 PM #14
      I got mine before he left for vacation. Haven't installed yet. Thanks Peter.
    15. 02-13-2013 08:39 PM #15
      Will this camera fit a mkv r32 ?
    16. Former Advertiser
      Aug 20th, 2012
      2012 Golf R CW 4Dr
      02-15-2013 08:17 AM #16
      Quote Originally Posted by R32_red View Post
      With some modification it will work just fine.
      The rear wiper has to be modified from the inside to allow larger emblem to fit. But nothing too complicated.
      It has been done few times.
      -Cheers,
    17. 02-18-2013 09:08 PM #17
      Is there anyway that i can get my hand on the harness itself i only need that have the camera
    18. Former Advertiser
      Aug 20th, 2012
      2012 Golf R CW 4Dr
      02-18-2013 11:35 PM #18
      Quote Originally Posted by MK3Jeta View Post
      I have plenty of harnesses in stock.
      $120.00 Shipped anywhere in USA $130.00 Shipped to Canada.
      Cheers,
      Peter
    19. Member
      Feb 16th, 2013
      HTX
      13 VW GTI CW
      02-23-2013 12:35 AM #19
      Quote Originally Posted by Peter@ExtremeNetwork View Post
      Cheers,
      Peter
      how can I tell if my rns510 will work with this? when I put my shifter down and into reverse the rns510 screen goes black like it has a feed for it.
      how easy is this to install? and do I run a line to the rns510?
    20. Member EvoKnvl's Avatar
      Jan 23rd, 2012
      Bay Area
      02-23-2013 02:08 AM #20
      Quote Originally Posted by caffeineTX View Post
      It's easy, but time consuming and you need to be careful with the plastics. You'll pretty much need to remove all the plastic on the hatch, the driver side C pillar, and the lower side. The harness is really nice as it's Plug N Play for everything but the Reverse light. You'll run the Coaxial video feed from the HU to the rear of the car. At the same time, you'll run the constant power from the rear to the front. I used an Add-a-Fuse to add in the Constant 12V+. Hardest part is getting the 2 wires through the rubber protector between the rear and the hatch. Once you remove that rubber piece from the hatch, make sure you protect the wiring from the hatch as it's sharp metal. I would advise wrapping the wires and covering the opening with tape so it doesn't rub against the sharp edge as you try to work the 2 wires through it.
    21. 02-24-2013 01:26 PM #21
      Where do yellow and black wires should go? I got the red one to the fuse box. I feel so dumb, even with diy guide I have no idea
    22. Former Advertiser
      Aug 20th, 2012
      2012 Golf R CW 4Dr
      02-24-2013 05:36 PM #22
      Quote Originally Posted by qkrwotls0 View Post
      Yellow is Reverse trigger wire. (Pin #3 on the inner tail light)
      Black is ground. (Top of hatch, under the grounding screw)
    23. 02-25-2013 08:16 PM #23
      thanks, I finished installation, it was a hard job for noob like me.
      I wish the camera closes faster, but very satisfied.. now i need to save up for rns510.
      thanks Peter.
    24. Global Moderator iThread's Avatar
      Sep 27th, 2005
      Portland, Or
      67 Bug, 92 Miata, 12 Golf R, 15 eGolf
      03-02-2013 11:37 PM #24
      I installed mine today and it looks great on the RNS-510! Install was simple and straightforward.
    25. Member
      Feb 4th, 2003
      Massachusetts
      03-03-2013 12:57 AM #25
      How long did it take u?
