VWVortex.com - What does the diverter valve do?
    Results 1 to 10 of 10
    Thread: What does the diverter valve do?
    1. Junior Member
      Oct 10th, 2012
      Central California
      2012 CC R-line, 1962 TR4, 1963 TR4, 1960 TR3, 3/4T GMC Suburban, 2003 GL1800, 1999 VT1100C
      01-02-2013 10:34 AM #1
      Howdy All,
      Just wondering what the diverter valve does and what does the upgrade do?
      I’ve seen a couple of posts about upgrading the diverter valve just want to know what the benefits are. But first would like to know what is does…
      Regards,
      John
      2012 CC R-line - Eibach Springs, Tinted Windows, APR Cool Air Box, APR PCV Adapter, Boost Gauge, MagnaFlow "CAT" Back Exhaust System, LED DRLs, Painting/shadowing of lower front valance, EBC slotted brake rotors, Headlight DRLs off...
    2. Member airmax1's Avatar
      Dec 7th, 2008
      Atlanta
      2012 VW CC 2.0T DSG
      01-02-2013 11:12 AM #2
      Quote Originally Posted by johnflovin View Post
      Howdy All,
      Regards,
      John
      You don't need upgrade DV because you don't have any tune. If you where tuned the electronic DV tend to leek boost, that's why i upgrade it.
      |APR KO4 v3.1-DP-FMIC-STGII DSG-MOBILE-CARBONIO I|IE Springs-Titanium|NEUSPEED TOP&TD|BORLA CT|R8CP&NGK-BKR8EIX|USPTBC|BFISTG1TM+EM|BSHTMI-CatchCan|STCoils|StopTechDR-R|HawkHPS-R|Hotchkis27mmRSB|HartmannHTT-256-GA:M|MichelinPSS245-35-19|USPHID|BBK VWR65G5BLA|ECS SS lines|Projector Headlights w/S5 style LED|SPM26mmFSB|CTSintake|
    3. Member Gradysmith's Avatar
      Feb 17th, 2012
      Charlotte, NC
      2012 VW CC R-line
      01-02-2013 12:20 PM #3
      Quote Originally Posted by airmax1 View Post
      Even if you get tuned, check what you have. My 2012 K04 tuned holds the boost just fine with the stock rev C. Rev C and D are the good OEM ones. Forge is a good aftermarket.
      The diverter valve is a pressure release system, that "diverts" un-used pressure back into the system. Like when you let off the gas, or in between shifts. Prevents compressor surge.
      APR K04 v3.1 | APR Carbonio Stage I & II CAI | APR downpipe | APR intercooler | APR DSG Stage II| 40% tint | VWR sport springs | Hotchkis 27mm RSB | Aquamist HFS-4
    4. Member
      May 25th, 2012
      San Tan Valley, AZ
      CC
      01-02-2013 12:46 PM #4
      Where is the DV and what do I look for to see which type I have?
    5. Junior Member
      Oct 10th, 2012
      Central California
      01-02-2013 01:04 PM #5
      Thanks for all the information, sounds like I can keep an eye on my boost gauge and as long as it is not low I should be ok...
      Regards,
      John
    6. Member Gradysmith's Avatar
      Feb 17th, 2012
      Charlotte, NC
      2012 VW CC R-line
      01-02-2013 04:18 PM #6
      Quote Originally Posted by AZ_CC View Post
      The other forums have a lot more info on the matter. But the DV is located on the side of the turbo. Jack up the car, follow the exhaust up the downpipe, see the turbo, then look between the turbo and the firewall. You should be able to read it. I think rev. G are the diagraph types known to tear. Rev C and D are piston types.
      You can start here: http://forums.vwvortex.com/showthrea...Valve-Question
    7. Member 1VR62NV's Avatar
      Sep 13th, 2003
      Toronto
      '99 Mk3 GTi VR6, '12 CC (Pre-Facelift)
      01-02-2013 04:44 PM #7
      Just get a DV spacer, upgrading the DV on a stock setup isn't really worth it IMO
      http://forums.vwvortex.com/showthrea...r-Valve-Spacer
      Eurotuner 02/10
      @1vr62nv
      May 25th, 2012
      San Tan Valley, AZ
      CC
      01-02-2013 06:13 PM #8
      Quote Originally Posted by Gradysmith View Post
      Ok cool Thx, ill check this wknd
      Dec 1st, 2009
      2012 CC DSG, 2017 Corvette Grand Sport 7MT, 2010 Audi S4 6MT
      01-02-2013 07:41 PM #9
      The DV reduces the time lag of the turbo coming back up to boost pressure after you momentarily let-off the throttle during shifts (it really only benefits manual trans cars)
    10. Member
      Dec 11th, 2009
      Clifton Park, NY
      2006 VW BT Passat
      01-02-2013 08:01 PM #10
      Quote Originally Posted by CC'ed View Post
      A dv is used to release the boost pressure when the throttle body closes. If it were not there the boost pressure would shock the turbo. It also assists in lag but with the small size of the stock turbo lag is a very small issue.
      A dv is needed on both manual and automatic transmissions. The recirculating of the air is what helps manual tranny cars
      Sent from my Galaxy SIII
      Unitronic Stage III w/ PT5558BB Turbo Unitronic.ca, IE HPFP, 3in B&B TBE, BSH throttle pipe/27mm RSB/Endlinks , Forge 007 DV , RalcoRC/Forge SS, 42Draft Design CNC Shifter bushings, BFI stage 2 motor/tranny mounts, 034 Dogbone, KW V2 coilovers, Nuespeed 25mm FSB, Whiteline Anti-lift kit/Front control arm bushings, 18x8.5 VMR VB3s, JBL stereo, CTS Turbo 2.0t FSI Big turbo kit!
