VWVortex.com - 2003 Jetta 24v VR6 Oil in spark plug chamber
    Results 1 to 5 of 5
    Thread: 2003 Jetta 24v VR6 Oil in spark plug chamber
    1. 01-07-2013 01:28 AM #1
      Hello all!
      Tonight I decided to change the spark plugs on my 2003 VW Jetta 24v VR6.
      All was going smoothly until I got to the 4th spark plug, and when I pulled out the coil pack it was dripping oil. I called my dad and he said use a paper towel and soak up as much as you can and go ahead and change out the all of the plugs. I used my air compressor to blow out a lot of the oil and used towels to soak most of it up.
      I replaced all the spark plugs started the car, and let it run for about five minutes. I don't hear any missing cylinders so I guess it was mission success.
      • My question is how soon do I need to really worry about oil leaking into the spark plug chamber?
      • Does anyone have any idea how much it will cost to fix?
      • Is this a problem that anyone else has had in the forums?
      I did a search and didn't see anything, that is why I am posting this thread.
      to anyone who replies
      // 2003 Jetta GLI // 24v VR6 //
    2. Member marko.f's Avatar
      Dec 28th, 2010
      Toronto
      MKV GLI
      01-07-2013 01:48 AM #2
      I think its your valve cover gasket and its cheap to fix
      http://www.ecstuning.com/Volkswagen-...anical/ES3441/
    3. Member fancyTHIS's Avatar
      Sep 30th, 2007
      Calgary, Alberta
      2004.5 GLI
      01-07-2013 02:09 AM #3
      What kind of retardation is happening on this forum???? Seriously.
      Your valve cover gasket is leaking.
    4. Member BolideVW's Avatar
      Aug 11th, 2011
      Calgary, AB
      2006 Audi A4 Avant
      01-07-2013 02:56 AM #4
      Quote Originally Posted by fancyTHIS View Post
      Now Now Colin...at least he did it himself. Guy who bought my 24V paid someone a couple hundred bucks to change three of the plugs.
      Instagram: dmanchant
      Past :
      2005 Volkswagen GLI. GTX3071r .63ar, CTS t3 manifold & DP, Tial 38mm, FMIC, Forge 004, Maestro 630cc (@4bar) mafless file, 144x19 IE Rods
      May 8th, 2011
      Silverdale Washington
      2003/GTI/VR6 24v
      07-01-2015 05:27 AM #5
      I just discovered this issue when changing my coils. Lots of oil in last plug hole. Look like its not going to be cheap to have mechanic do it with all that has to be done (pull intake, bumper cover, slide radiator out a bit, etc.) And a time consuming job to do yourself.
