with a diesel golf engine, 4 speed, sunroof. Odometer says 35K. LIkely 335 on body. I love this car but it needs some major body work-rusty spots, some dings, and needs a paint job, trim installed, new seals (have trim and 2 door seals) fussy doors. Underside is decent.
The bad: Needs body work, new window scraper trim, seats recovered, interior dash lights and speedometer do not work. Very slow radiator leak and small oil drip. Window washer fluid does not work.
The Good: intact headliner, carpets, mats, brand new fuse panel, fuses, heat works well. Always starts for me, some smoke when cold but just on start. Been running bio past 8 years, hoses swapped. Newer: rebuilt alt, battery, struts and shocks, tires, brakes, motor mounts, bearings, fuel pump in the last 2-4 years. Will need timing belt in next 15 K.
Honestly do not know what to price the car at- open to suggestions. thanks! would like to see the car go to someone who will restore- Ive had the car 10 years.
