VWVortex.com - Strange radio issue.
    Results 1 to 11 of 11
    Thread: Strange radio issue.
    1. Member Rpc07's Avatar
      May 17th, 2010
      Long island
      Mkvi Gti, B5 passat wagon
      01-08-2013 10:16 PM #1
      Heres the deal when listening to the radio or pandora on my phone through the aux input I get a ton of static and interferance, when I play a cd the radio sounds perfect. I have a 2011 s with the stock radio/speakers and have never tampered with the audio system. Anyone have any clue how to solve this? Problem started maybe 2-3 days ago.
    2. 01-08-2013 10:32 PM #2
      Quote Originally Posted by Rpc07 View Post
      Same issues here when listening to AM radio.
      Oct 25th, 2011
      Seymour, CT
      2011 Jetta S
      01-08-2013 11:03 PM #3
      Is it static or just not very clear also is it all the time or only between tracks?
      You will get noise from the alternator in between tracks. Check the box in settings of pandora for high quality audio.
    4. Member azthegame's Avatar
      Oct 27th, 2011
      Arlington, TX
      2012 Jetta SEL, 2012 4DR Golf TDi
      01-08-2013 11:18 PM #4
      My brother's jetta does this only when charging his phone at the same time as playing via Aux. It does it only between tracks when there is silence, a high pitched whine that changes with RPM levels. It is a ground loop I believe. The power wires from the 12v socket are too close and interfering with the Aux connection. Is your S the same where both are next to each other on the front? My SEL didn't do this because the RNS-315 has the Aux built in to the headunit. And my golf doesn't do it because the Aux is by the armrest and not in the front by the 12v plug
      Oct 25th, 2011
      Seymour, CT
      2011 Jetta S
      01-08-2013 11:22 PM #5
      Quote Originally Posted by azthegame View Post
      Yeah it does it all the time. I was thinking about adding a ferrite but I dont know if that would help.
    6. Member Rpc07's Avatar
      May 17th, 2010
      Long island
      01-09-2013 12:18 AM #6
      The only time this does not happen is when im playing a cd. Even with am/fm radio this happens.
      Oct 25th, 2011
      Seymour, CT
      2011 Jetta S
      01-09-2013 12:31 AM #7
      If that is the case then you may have a faulty antenna or radio.
    8. Member Rpc07's Avatar
      May 17th, 2010
      Long island
      01-09-2013 12:39 AM #8
      Quote Originally Posted by Verebs1 View Post
      I just find it strange this happens with pandora through my phone also.
      Jul 30th, 2012
      Buffalo, NY
      MkVI 2.5 SE, RIP 1990 Jetta Wolfsburg
      01-09-2013 01:00 AM #9
      Put your phone on airplane mode and see if it goes away.
    10. Member Rpc07's Avatar
      May 17th, 2010
      Long island
      01-09-2013 01:43 AM #10
      Ill give it a shot. But i Cant see that making a difference when my phone isnt plugged in and im llistening to am/fm
    11. Junior Member
      Oct 8th, 2011
      mk6 GLI autobhan 6spd
      01-09-2013 11:17 AM #11
      My audio quality goes way down when i have my iphone plugged in but when its connected via bluetooth it sounds perfect. Its a huge difference in quality
