VWVortex.com - 17700 - Map Controlled Engine Cooling Thermostat (F265) 1 fault found?
    Results 1 to 8 of 8
    Thread: 17700 - Map Controlled Engine Cooling Thermostat (F265) 1 fault found?
      May 2nd, 2001
      CNY
      2012 CW Golf R 4dr, 2017 SB GSW 4MO
      01-12-2013 01:12 PM #1
      From the scan below it appears to me either thermostat is bad, the wiring to it has a short, or both.
      Do you all agree?
      Saturday,12,January,2013,12:50:08:43668
      VCDS Version: Release 11.11.5 (x64)
      Data version: 20121222
      Chassis Type: 3B - VW Passat B5
      Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
      VIN: WVWLK63B84E298829 Mileage: 209900km/130425miles
      Address 01: Engine Labels: 07D-906-018-BDP.lbl
      Part No: 07D 906 018 AP
      Component: B5S-4.0L-HS-LEG 5204
      Coding: 00172
      Shop #: WSC 78644
      VCID: 74ED9E404411BBB8354
      WVWLK63B84E298829 VWZ7Z0C8211297
      1 Fault Found:
      P1292 - 35-00 - Open Circuit
      Readiness: 0000 0000
    2. Forum Sponsor Uwe's Avatar
      Jan 16th, 2000
      Lansdale, PA
      Too Many
      01-14-2013 06:08 PM #2
      Well, no. "Open Circuit" is not "A Short".
      -Uwe-
      VCDS® -- Satisfaction guaranteed or double your fault codes back!
      I reserve the right to be a prick if people make unreasonable demands.
      May 2nd, 2001
      CNY
      01-14-2013 08:53 PM #3
      What does open circuit mean then? Do you agree that the thermostat could still be at fault?
      Quote Originally Posted by Uwe View Post
      -Uwe-
    4. Member
      May 2nd, 2001
      CNY
      01-15-2013 09:12 PM #4
      Anyone?
      Mar 6th, 2002
      Morris Plains, NJ
      1998 GTI 2.0T
      01-16-2013 09:49 AM #5
      Open circuit is the opposite of a short.
      Probably a bad thermostat. You can verify if the heater is open with an ohmmeter.
      2012 Corolla
      1998 GTI 2.0T
      World Automotive
    6. 01-15-2017 11:48 PM #6
      Hi,
      How do I use the ohmmeter to check if the heater is one / open. to see if the thermostat is bad or no.
      because I have been given the fault codes as follows:
      1. Map controlled Engine cooling thermostat ( F265) : open circuit. code : 17700
      2. Main Relay ( J271) : Electrical Malfunction. code : 17925
      3. Engine coolant temp. sensor ( G62) : implausible signal. code 165500
      I have gotten these, and I don't know if they are a simple repair of either replacing a sensor switch, or something that Isn't too expensive like major electrical repair. as I'm a uni student... sigh.
      Any help is much appreciated, I'm not a mechanic or electrician, So I just to know what parts they are in the car and ways to repair them or which part to get so it can help me keep the cost for the repair.
      Nov 27th, 2011
      MD
      01-16-2017 12:55 PM #7
      17700/P1292/004754 - Map Controlled Engine Cooling Thermostat (F265): Open Circuit
      Possible Symptoms
      ## Malfunction Indicator Light (MIL) ON
      Possible Causes
      ## Fuse(s) faulty
      ## Wiring and/or Connector(s) from/to Map Controlled Engine Cooling Thermostat (F265) faulty
      ## Map Controlled Engine Cooling Thermostat (F265) faulty
      Possible Solutions
      ## Check Fuse(s)
      ## Check Wiring and/or Connector(s) from/to Map Controlled Engine Cooling Thermostat (F265)
      ## Check/Replace Map Controlled Engine Cooling Thermostat (F265)
      From http://wiki.ross-tech.com/wiki/index...0/P1292/004754
      Nov 27th, 2011
      MD
      01-16-2017 01:41 PM #8
      Quote Originally Posted by Meshel View Post
      Hi,
      http://wiki.ross-tech.com/wiki/index.php/17925/P1517
      3. Engine coolant temp. sensor ( G62) : implausible signal. code 16500
      http://wiki.ross-tech.com/wiki/index...0/P0116/000278
