VWVortex.com - GOLF MK3 Water Drain Holes ?
    Results 1 to 10 of 10
    Thread: GOLF MK3 Water Drain Holes ?
    1. 01-17-2013 05:40 AM #1
      Find water in my passenger footwell of my GOLF MK3.
      Checked to find drain holes...I can't find....Anyone could help me ? Could you post any picture ?
      thanks
      FABIO
    2. 01-17-2013 09:58 AM #2
      Not sure what drain holes you're looking for, but my guess is it's a leaking heater core.
      96 GTI VR6.
    3. Member xxkoadyxx's Avatar
      Mar 18th, 2010
      Nova Scotia.. P.C
      93 golf TDI (sold..), 2003 passat 1.8T daily(sold), 95 cutleas (sold), 2013 jetta tdi (newcar)
      01-17-2013 10:07 AM #3
      if you cant find any drain holes..its prob been welded over..they usaslly rust there anyways.
      Vw mk6 Jetta TDI bagged! Daily
      Vw mk3 4dr golf stg 3 malone TDI- sold
      Vw b5.5 passat 1.8t- sold
      95 cutlass supreme- sold
      @stanceeast
    4. Member RoseBud68's Avatar
      Dec 13th, 2012
      PSL,FL
      97 GLX, AAA, '99 Jetta TDI 1.9 1Z
      01-17-2013 10:07 AM #4
      If you have a sunroof then the drain hose are in the front door jams.
    5. 01-17-2013 10:14 AM #5
      What drain holes?? Welded over?? Huh? This isn't a Jeep you know. The only drain holes I know of are for the sunroof, and they're in the door jamb, and they're little rubber tubes that hang out.
      96 GTI VR6.
    6. 01-17-2013 11:42 AM #6
      There is no sunroof on my GOLF MK3 ....The drain water holes....should be in the bottom of ther doors or nearby....but I can't find....
    7. Member BlitzCreager's Avatar
      Oct 12th, 2009
      Owensboro KY
      Mk4 VR Wagon, 94 Jetta GLS
      01-17-2013 12:20 PM #7
      Quote Originally Posted by LambertJohn View Post
      make sure you know what you are talking about before you try to correct someone.
      there are "drain" holes in the floors of Mk3's. When people fix the floors after they rust often times they weld them closed because they are more of a joke than they are useful.
      the other thinkg could be the rain tray. if the end "flap" is not lined up correctly all rain water will pour into the fresh water intake and come out from around the blower motor.
      VR Society /@Creager13
    8. 01-18-2013 04:23 AM #8
      In my old GOLF MK2 there were rubber tubes to drain water above the wheels, in my MK3 in can't find any RUBBER TUBES....I checked everywhere...above the wheels, in the door...I can't find....Someone has a picture of DRAINING HOLES for a Golf MK3 ?
    9. 01-18-2013 04:27 AM #9
      I know there are RUBBER CAPS in the floor...one for the driver and one for the passenger....
      I take off the one passenger side. So water can go out of the car. My problem is to avoid water to enter....in the vehicle...but I can't understand where it comes from....Probably may be drain holes not doing their job.
    10. Member csrgti's Avatar
      Aug 18th, 2009
      Central Florida
      past Scirocco, Gli16V, Scirocco16v, Cabriolet, present 84GTi,96GTi
      01-18-2013 09:08 AM #10
