VWVortex.com - I finished putting together my motor (Turbo Datsun content)
    The Car Lounge
    Page 1 of 32 1234511 ... LastLast
    Results 1 to 25 of 789
    Thread: I finished putting together my motor (Turbo Datsun content)
      Oct 6th, 2012
      Northern NY (Eastern Lake Ontario)
      240z, 260z, 280zx, R53 Mini, TJ Wrangler, E30
      01-21-2013 05:13 PM #1
      So long story short: I have just about finished converting my Datsun's motor to a turbocharged setup.
      Figured I'd post a couple pictures. Feel free to flame away if you want. Or any kind words are also greatly appreciated, as I do all of the work myself, save machining.
      And sorry, I didn't shoot these with a Leica M9.....Taken via my Droid. haha
      For more information on my actual build thread (hundreds of pictures) feel free to check out:
      http://forums.hybridz.org/topic/9718...l-my-problems/
      The car has made quite a change over the years, and is far from complete. It's a process.
    2. Member DasBaldGuy's Avatar
      Jan 12th, 2005
      Columbus Ohio
      2012 MINI Coupe` S, 1988 VW Fox Turbo Truck, 2015 Sonique
      01-21-2013 05:14 PM #2
      Looks awesome to me!
      MOAR pix of whole car please
    3. Member Cousin Eddie's Avatar
      Dec 17th, 2005
      Ontario, Canada
      1972 Condor II Autocross Spec with Dan in the passenger seat
      01-21-2013 05:14 PM #3
      As a fellow S30 owner I approve of this. Any pics of the entire car or is it still a work in progress?
    4. Member
      Oct 6th, 2012
      01-21-2013 05:20 PM #4
      Yeah it's definitely a work in progress still. Started out blue.
      It's kind of my winter ritual to take it all apart and change stuff.... Then I drive it each Spring until November-ish. Rinse and repeat til it's the way I want. Was carbed. Last year I fuel injected it. This year I turbocharge it. The plague continues....haha
      Last summer:
      And thanks for the kind words so far.
    5. Member .:Chr!sVR6's Avatar
      Dec 7th, 2009
      The sticks, NY
      08.5 Jetta Wolfsburg 2.0T DSG
      01-21-2013 05:21 PM #5
      Nice build...where in upstate ny are you, if you dont mind me asking?
      This is why Gen Y is really unhappy. Late 90s/Early 2000s small turbo motors. They're like crack and slightly more expensive.
      instagram: driver_found_
    6. Member
      Oct 6th, 2012
      01-21-2013 05:23 PM #6
      Quote Originally Posted by .:Chr!sVR6 View Post
      About an hour north of Syracuse. Right on Lake Ontario. The east coast that is. Small town named Henderson Harbor
    7. 01-21-2013 05:25 PM #7
      beautiful car. specs on motor/turbo setup?
    8. Member .:Chr!sVR6's Avatar
      Dec 7th, 2009
      The sticks, NY
      01-21-2013 05:26 PM #8
      Quote Originally Posted by OldAndyAndTheSea View Post
      gotcha, so way upstate. I live in Oneonta...near Cooperstown
    9. Member rq1trackaddict's Avatar
      Sep 21st, 2009
      Perkasie, Pa
      SV Race Bike
      01-21-2013 05:27 PM #9
      Nice work.....
    10. Member
      Dec 12th, 2005
      '03 white WRX Wagon
      01-21-2013 05:28 PM #10
      Did you powdercoat/paint the inside of the intake manifold? If so I'd suggest masking that next time. Engine and car looks great though!
    11. Member
      Oct 6th, 2012
      01-21-2013 05:34 PM #11
      Quote Originally Posted by Uberchad View Post
      It's only in the neck of the intake, and yeah, before I fire the motor I'm going to blast and clean the inside of the manifold. No need for paint in the combustion chamber...This is just a mock up.
      Thanks for the comments! Didn't think it would go this well.....haha
    12. Member tip's Avatar
      Aug 7th, 2008
      South Puget Sound
      Junk
      01-21-2013 05:34 PM #12
      awesome
    13. Member lojasmo's Avatar
      Dec 23rd, 2002
      SE MN
      2006 Vue, 2012 Chevy Cruze LT2, 2004 Allroad
      01-21-2013 05:47 PM #13
      Wonderful.
    14. Member
      Oct 6th, 2012
      01-21-2013 05:56 PM #14
      Quote Originally Posted by Saves View Post
      I don't wish to exceed 275 whp, as the car is fairly light.
      So in order to do this...
      Currently the motor is
      1976 L28 (n42 block n42 head for those that care)
      Running 8.3:1 static compression. Has 1500 N/A miles on the latest rebuild.
      87mm Ross Pistons
      ARP head studs
      N/A cam (brings out around 500 more rpms)
      High Volume oil pump
      Bolt on specs:
      Shaved non EGR intake manifold (ported to 60mm)
      240sx 60mm Throttle body
      Stock 280zx exhaust manifold (wrapped)
      Stock 280zxt T3 Turbocharger (Heat wrapped)
      270cc injectors (for initial tune)
      Turbo 280zx Oil pan
      Custom Aluminum Fuel Rail
      2.5" Downpipe (wrapped)
      3" Mandrel Bent exhaust (fabbed myself)
      3" Dynomax Ultraflo muffler
      21x8x3 Intercooler
      2.25" intercooler piping
      Datsun 2+2 240mm Flywheel
      ACT 240mm Street Performance clutch/pressure plate etc..
      And LOTS of little things in between.
      My "To buy" list consists of the following
      Megasquirt V3
      LC-1 Wideband 02 sensor
      Oil Cooler
      3 Row aluminum radiator (with puller electric fans)
      Greddy Type RZ blow off valve
      The list goes on....ugh.
    15. Member
      Oct 6th, 2012
      02-15-2013 09:59 PM #15
      So between my last post and now I...
      Repainted the engine bay, eliminating anything unused in the process...
      Dropped my old 4 speed, and proceeded to clean and paint the transmission tunnel...
      Installed my ACT clutch kit, and 240mm flywheel...
      Then, I tossed the motor in the car.
      I've got most of the bolt on parts buttoned up, and I'm now waiting on stuff in the mail.
      And, I am in the process of sourcing some sort of 5 speed. Until then, there is no transmission in the car.
      Here are a few random pictures, ending with where I am, as of today.
      Or you can always visit my build thread to see all of the pictures.
      And now I am currently adjusting the intercooler piping to assure for a good fit. I need to shorten the pipes between the intercooler and the radiator support, but I'm going to wait for my radiator to come first.
      Lots of little things left, but I'm enjoying all of it!
    16. Member Shmi's Avatar
      Mar 25th, 2009
      Fairfax, VA
      2014 Fiesta ST, 2004 Accord EX, 2003 LS430
      02-15-2013 10:17 PM #16
      This is fantastic. You say you work on it every winter, what are your future plans? I love the blue and good job cleaning up that engine bay.
      Quote Originally Posted by Dpaul04 View Post
      Dude, Im posting in TCL.. If I didn't know everything I wouldn't be here.
      Quote Originally Posted by Nubbin View Post
      Saying the P1 doesn't excite you because of hybrid is like saying you find Scarlett Johansson repulsive because she shares the same gender as Rosie O'Donnell.
    17. Geriatric Member BRealistic's Avatar
      Dec 16th, 2005
      East-10EC
      88 F150, 04 RX8, 96 T&C LXi
      02-15-2013 10:22 PM #17
      Did these Datsuns have NISSAN on the valve covers back then?
      Hmm. Never owned a Datsun era Nissan, so I don't know.
      "Sometimes, I have a sudden urge to fart on this chair."
    18. Member
      Oct 6th, 2012
      02-15-2013 10:25 PM #18
      Quote Originally Posted by Shmi View Post
      Hey thanks! And yeah, every winter, er...well it has been this way for the passed 4 winters or so.
      Future plans:
      Once the motor is up and running again, with a 5 speed and r200 rear end..
      Adjustable coilovers this summer, camber plates, tokico illumina struts
      Then I do some wheel hunting
      I drive it and work on it all at the same time, so I can enjoy the process. Winter is my time for big changes.
      And there are 4 different valve covers offered for the L series Nissan motors.
      One states: Nissan 2400, Nissan OHC, Nissan, or Nissan TURBO
      the first found on early Datsun 240zs only, the second is found on 71-78 240-280zs, the third is found on Nissan 280zx's, and the later on the turbo 280zx's
    19. Member BattleRabbit's Avatar
      Jun 28th, 2007
      Albany, NY
      DKW Munga
      02-15-2013 10:30 PM #19
      Wow, other than the seats* I love it! Seriously, that's a fantastic Z with a great looking motor. Any idea on how much power it'll make when it's all buttoned up?
      *They look comfortable and supportive, just a little too modern. I'd have gone with something more along the lines of an old 911 seat. It's your car and your butt going in them though
      What else has been done with the car? What sort of brakes/suspension are you using?
      2005 Subaru Forester X/1980 Honda CM400E/1987 Porsche 944S
      BattleRabbit takes Pictures!
    20. Member
      Oct 6th, 2012
      02-15-2013 10:40 PM #20
      Quote Originally Posted by BattleRabbit View Post
      Haha thanks! Yeah I have a pair of awesome era buckets in my 260z. Black with white vertical pin stripes in the center. LOVE EM. But for this car, I wanted a modern interior, with subtle classic reminders.
      As for the motor, when I start it up the first time, I expect to be around the 230-240whp range (which will be around a 100hp gain, immediately). The stock injectors really only support around 275 whp at 100% duty cycle, so until I tune, and upgrade I won't see much more than 250.
      Engine management will be Megasquirt II V3.0
      As for suspension.
      This summer the suspension will be entirely gone through. But as of now, I have drilled and slotted rotors in the front, with carbon ceramic pads. The car has brand new drum brakes on the back, but I also have a set of 280zx drilled and slotted rotors, and calipers waiting to go on the car, when I change out the struts.
    21. Member esrballa's Avatar
      Oct 8th, 2008
      Los Angeles, CA
      98 BMW M3
      02-15-2013 11:06 PM #21
      Nice Smurf engine. I always wanted to do a swap like this, maybe one day. Great job.
    22. Member unimogken's Avatar
      Jan 19th, 2005
      South of Jazzydub, WA
      6 Tap Kegerator
      02-16-2013 01:27 AM #22
      Thanks for posting this here!
      The link didn't load for me.
      Reminds me of the Z car that I learned how to drive that was manual and had a 327 in it.
      I really wish everyone would update their location in their profile!
      Someone buy my car already!!
      Always looking for free firewood to feed my hungry wood stove!
    23. Member aussie88's Avatar
      Dec 13th, 2010
      ɐıןɐɹʇsnɐ
      1988 Mercedes-Benz 190e, 1970 VW Lowlight pickup, 2007 Honda Accord Euro
      02-16-2013 02:29 AM #23
      ಠ_ಠ
    24. Member 71DubBugBug's Avatar
      Dec 3rd, 2006
      Chicago
      91 Audi D11 V8, 71 Super, 07 E320 Bluetec, 05.5 Jetta 2.5
      02-16-2013 07:19 AM #24
      Quote Originally Posted by aussie88 View Post
      lol funny pic, but i agree
      op, nice to see you building the car, and then going looking for wheels, and not doing all your suspension work around a set of wheels
    25. Member
      Oct 6th, 2012
      02-16-2013 09:34 AM #25
      Thanks for the kind words! They mean a lot.
      Seeing as it appears I have some interest in the build, I'll start using this thread as my Datsun progress/build thread.
      And yeah, one of my pet peeves in regards to doing a project like this, is when the first purchase is usually some set of wheels, worth (at the time) more than the vehicle, which is no more than a rolling chassis. Building suspension is a good first step, but wheels, those can wait for now, despite my severely under filled fender flares currently.
      But of course, time and money dictate the pace of the project.
      Thanks for the Support!
      More to come.
