VWVortex.com - so has anyone figured out how to get a proper tach signal?
    Results 1 to 14 of 14
    Thread: so has anyone figured out how to get a proper tach signal?
    1. Member halchka99's Avatar
      Apr 18th, 2002
      Porter Ranch
      Evo IX MR: Porsche Macan S
      01-26-2013 01:15 AM #1
      Many moons ago, it was at the ecu, then it was at the injectors bla bla none of those are accurate signals.
      Has any progress been made?
    2. Banned
      Jan 17th, 2013
      I own too many MK4's for my own good...
      01-26-2013 01:50 AM #2
      K-Line, Crank, coil, etc?
    3. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      01-26-2013 01:56 AM #3
      Really? Injectors aren't a good signal? What do they look like on the scope?
      Surely the crank would also work
      What is the method used by the standalone systems like vipec, and autronic?
      My Build
      Welcome to the world of racing! Budgets are ALWAYS exceeded, deadlines are never met, end-goals never reached, and wives always unhappy... it's all worth it though!
    4. Member Vegeta Gti's Avatar
      Feb 12th, 2003
      konoha village, hawaii
      1984 GLi 20v, '16 M3, '85 Golf, '03 BMP 20th AE
      01-26-2013 07:12 AM #4
      pin 9, orange connector. been working great for me since last June. solid as a rock.
      Sent from my SPH-D710 using Tapatalk 2
      :HOMEGROWN MOTORSPORTS:1:4.9 SuaSponte #13Dead Rabbits. Ungluck on IG. MKIforLife
      Quote Originally Posted by .Ant View Post
      What vegeta said.
    5. Forum Sponsor AL@PagParts.com's Avatar
      Oct 23rd, 2008
      NY
      07 AUDI 2.0T 07 VW GTI
      01-26-2013 09:45 AM #5
      Coil signal has always worked for me
      Pag Parts
      Turbocharger Systems, OEM Parts / Fabrication
      Garrett / PTE / BW / TiAL / Clutchmasters / Southbend / Brute Con Rods / Wiseco / CP Pistons / Supertech / Ferrea / CatCams / Walbro / EV14 Injectors / Eurodyne Software / Much More... Pag Parts Facebook
    6. Banned
      Jan 17th, 2013
      01-26-2013 10:06 AM #6
      Quote Originally Posted by AL@PagParts.com View Post
    7. Member Chickenman35's Avatar
      Jul 28th, 2006
      West Coast, Canada
      1998 Audi A4 QT , 1976 Datsun 280Z ( My Mid-Life Crisis )
      01-26-2013 01:34 PM #7
      Quote Originally Posted by halchka99 View Post
      Have you tried an MSD Tach Adapter? Model number 8913 should convert the ECU signal to something that an aftermarket Tach will accept. Some Tachs are more sensitive to the signal than others. An MSD Tach adapter should provide a clean and readable signal.
      http://www.msdignition.com/Products/...Ignitions.aspx
      MSD has several different Tach Adapters to solve different problems. Here is the link:
      http://www.msdignition.com/info.aspx...256&taxid2=267
      "...I recommend books. People who don't know what they're talking about are less likely to write a book about the subject...."
    8. Forum Sponsor pete@integrated's Avatar
      Jan 1st, 2009
      Salt Lake City, UT
      '92 Gti 20v, '96 M3, '10 Shop Van :)
      01-26-2013 04:32 PM #8
      Cam sensor has a 1 pulse per cylinder output if it's a DBW car- you still need an MSD box if whatever you are running is looking for a high voltage output.
      It's uneven, but you'll never see that in the data as almost all devices have some filtering or capacitance.
    9. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      01-28-2013 03:00 PM #9
      Added to the FAQ under electrical
      My Build
    10. Member Vegeta Gti's Avatar
      Feb 12th, 2003
      01-28-2013 04:09 PM #10
      if your going to stock cluster, use a tach adapter 8920 MSD
      if your going to an aftermarket liek i did..no need. that's why i pulled it off of the orange connector, it is the most solid signal i have gotten over the years.
      What vegeta said.
    11. Member l88m22vette's Avatar
      Mar 1st, 2006
      Chicagoland, IL
      2003 TTq coupe, 2005 Outback XT, 2004 A6 3.0
      01-28-2013 10:41 PM #11
      Ok, so now how do I wire in speedo and fuel? Screw cluster problems, no cluster = no problem You could easily fit 2-3 more gauges in the center, at least on a TT...
      Chicago Cubs, World Series Champions 2016, Holy Cow!
      Quote Originally Posted by hushypushy View Post
      Used manual GTI's are definitely rarer than DSG's. Get a brand new 6MT so you can be the first to dump the clutch and fart in the seats
    12. Member halchka99's Avatar
      Apr 18th, 2002
      Porter Ranch
      01-29-2013 12:21 AM #12
      Quote Originally Posted by Vegeta Gti View Post
      ive tried it all including the ecu, but its not a clean signal, tach is jumpy specially at idle. it may just be that my tach needs the msd box like pete mentioned
    13. Forum Sponsor pete@integrated's Avatar
      Jan 1st, 2009
      Salt Lake City, UT
      01-29-2013 12:33 AM #13
      For an OE mk2 tach you do need the msd 8920 and the "white wire" everyone says to tap does not work- gives jibberish.
    14. Member halchka99's Avatar
      Apr 18th, 2002
      Porter Ranch
      01-29-2013 12:49 AM #14
      ive got the mk4 cluster and of course the oem tach works just fine, its the aftermarket tach that isnt playing nice.
