    Results 1 to 6 of 6
    Thread: KONI /Bilstein Shock help Please/
    1. Member flyinglizard's Avatar
      Aug 6th, 2006
      Spring Hill, FL. USA
      FSP. ITB,wide body,Chumpcar
      02-12-2013 03:14 PM #1
      I am looking for the Billy for the A 1 VW. that uses a short strut body. Does the Sport use the cut housing?
      Also. What is the part # for the Koni that uses the cut housing..VW- A1.
      TIA. MM
      The http://www.fwdracingguide.com/ Money back guarantee!, You can go 100$ faster with this 20$ guide
      Mike and Michael Ogren, Protech Racing,25 yrs of Racing VWs. mogren@tampabay.rr.com[/email], 352.428/8983
    2. Member eurotrashrabbit's Avatar
      Oct 24th, 2001
      Sterling,VA
      65 sunbeam tiger, 76 Rabbit, 89 cabriolet, 95 s6 avant, 03 mazda protege 5
      02-12-2013 09:23 PM #2
      Not sure what you are asking.
    3. Member flyinglizard's Avatar
      Aug 6th, 2006
      02-14-2013 12:04 PM #3
      For A1 VW; 1) Is there a Billy that uses a shorten strut housing??
      A 1 VW, Koni, What is the right part # for the short VW strut housing?
    4. Member bugsinmyteeth's Avatar
      Feb 7th, 2006
      Rockville, Md
      2012 TDI Sportwagen, 93 Corrado SLC original owner, 83 GTI SCCA H Production
      02-21-2013 01:03 PM #4
      I thought BSI used to push the short MkIs Konis using a modified MkII housing and insert. I would think the same would be the short option for for Bilsteins. I think you can only get the HD not the Sport from Bilstein as an insert, so you would use Sport housing assembley. Is the knuckle flange wider on the MkII so you need a shim?
    5. Member flyinglizard's Avatar
      Aug 6th, 2006
      02-21-2013 08:57 PM #5
      I need the part # for the Koni.
      I have short Mk 1 strut housings.
      TIA, MM
    6. Member bugsinmyteeth's Avatar
      Feb 7th, 2006
      Rockville, Md
      02-22-2013 03:28 PM #6
      I think it is whatever Koni lists for the front of a MkII. You can call Lee Grimes at Koni Technical. He loves helping racers with questions like this. BSI might still have an old parts list that has what they sold.
