VWVortex.com - Diverter valve
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 26
    Thread: Diverter valve
    1. 02-25-2013 05:22 PM #1
      Anyone with a '13 GLI know if we have a 06h 145 710 c or 06h 145 710 d??
      I have the ~2200-2700 RPM hiccup with light throttle (usually in 2nd gear)
      I have read countless thread about how much more worse this issue becomes after a stage 1 tune (something i plan to do in the near future)
      Any help ??
      additionally...
      is the Forger DV really worth the extra cash?
      Jun 20th, 2012
      Maryland
      2013 VW Jetta GLI
      02-25-2013 05:48 PM #2
      i would like to know the same thing
    3. Member AaronRedGTi's Avatar
      Aug 2nd, 2011
      Philadelphia Area
      2011 GTI (RIP) -- Candy White 2013 GLI w/nav
      02-25-2013 06:01 PM #3
      My 2013 gli came with the rev C.. I never had any issue with it. I did replace it with the revision D just to be sure. As for the forge dv it really isnt nesessary... Most people just run the rev D
      2013 Candy White GLI w/Nav
      Mods: APR Carbonio Stg 1+2, Eurojet Downpipe, Eurojet Intercooler, AWE Touring Cat-Back Exhaust, Southbend Stage 3 Drop-in Clutch, S3 Short Shifter, AWE Boost Gauge, 42 Draft Shifter Bushings, BFI Torque Mount, Turbo Outlet Pipe & Throttle Body Piping, Koni Coilovers, 17mm Spacers (Front), 15mm Spacers (Rear), Gloss Black Vinyl Roof, Vag-Com Tweaks
    4. Junior Member Jamseyqk's Avatar
      Apr 27th, 2012
      2012/VW/GLI Autobahn w/Nav
      02-26-2013 12:16 AM #4
      OP, if you don't have a tune, why don't you get this fixed under warranty? I can't feel the hiccup in stock mode at all. If you can, you should go to the dealership and have them fix this problem. I wish that was my case. Only noticed a problem after APR stage 1. Can't get them to fix a problem that wouldn't exist without my tune. Please keep us posted.
      Sent from my iPad using Tapatalk HD
      May 10th, 2010
      North Jersey
      2016 Tiguan SE 4Motion
      02-26-2013 09:17 AM #5
      Quote Originally Posted by zrmarci View Post
      06H 145 710 C and 06H 145 710 D are both piston DV's. THe "D" version has a cage around the piston and the "C" does not.
      Any help ??
      The issue is with diaphram valves, from the "06F" family of DV's.... 06F 145 710 C & 06F 145 710 G
      additionally...
      No. It is a heavier duty diaphram valve that requires maintenance (cleaning & lubing the internal body and spring).
      Imo... though AWE-Tuning's DV is a great upgrade. It is also a diaphram valve, but, unlike the Forge DV, it is a lot simpler. It removes the ECU control of the DV for a simple intake manifold pressure/vacuum based operation.
      Forge DV really worth the extra cash?
    6. 02-26-2013 10:42 AM #6
      Quote Originally Posted by BsickPassat View Post
      additionally...
      Forge seems to be overdoing it a bit.
      Perhaps you should order from the "06H" family instead and get the "D" version with the mechanical piston...
      http://www.ecstuning.com/Search/06H_145_710_D/ES263879/
      Just saying you should check it out
      Also... http://www.youtube.com/watch?v=H7F7OPUtyjU
      Thanks for the info in the "F" family hierachy tho
      Dec 9th, 2012
      Ohio, USA
      2013 Jetta GLI DSG
      02-26-2013 10:48 AM #7
      So, is this compatible with a tune? I was under the impression that the DV is how the ECU controls boost pressure, and if the ECU doesn't control that anymore, the majority of the gains from a tune would go away, since the majority is based on boost control, is it not?
    8. 02-26-2013 10:50 AM #8
      Quote Originally Posted by AaronRedGTi View Post
      Thanks for the response! Made the purchase much easier not having to lift the car last night and do the leg work myself
      Props.
    9. Junior Member
      Mar 13th, 2012
      2012 Volkswagen GLI
      02-26-2013 11:18 AM #9
      Recomending forge DV
      '12 GLI AB. APR stage2 APR 3" doenpipe. borla exchaust. VWR windtake. Forge BOV
    10. Member King Schwab's Avatar
      Jul 7th, 2012
      Beaumont, TX
      2012 VW GLI
      02-26-2013 11:20 AM #10
      Just purchased rev D. What's the scoop with the forge blow off adapter? I just like that sound
      John Handcock
    11. 02-26-2013 11:33 AM #11
      Quote Originally Posted by Tomekmrowa View Post
      Oh do ya.... for 3.5x less of what Forge costs it just not worth it. If only we were pull 500+ whp and 30+ psi
      This is an old video and the DV design may have been slightly updated since, but heres what the 06H145710D looks like (similar to) on the inside
      http://www.youtube.com/watch?v=b3F26gmk4j8
    12. 02-26-2013 11:34 AM #12
      Quote Originally Posted by King Schwab View Post
      They say its not good for the TSI engine, but they also didnt say it wasnt all that bad for it neither...
      I was looking at it myself
    13. Member
      May 10th, 2010
      North Jersey
      02-26-2013 11:50 AM #13
      Quote Originally Posted by araemo View Post
      The DV does play an influence in controlling boost, as it can, as needed work with the wastegate.
      then AWE DV works fine with tunes.
      the Forge DV works similar to that of the 1.8T DV system.
    14. Member jstewart204's Avatar
      Sep 27th, 2010
      Concord, NH
      2013 Jetta GLI Autobahn, 91 Jetta GLI ABA Swap BBM S/C, 2006 GMC Sierra Denali
      02-26-2013 12:29 PM #14
      Does the 06H "C" revision suffer from failure as well? even though it uses a piston.
    15. Member
      Dec 9th, 2012
      Ohio, USA
      2013 Jetta GLI DSG
      02-26-2013 12:31 PM #15
      Work with the wastegate? I wasn't aware we had a wastegate, I thought the diverter valve served that purpose on the TSI engine. I guess I was misinformed.. but it still seems less than ideal to remove ECU control of this valve.
    16. Member
      May 10th, 2010
      North Jersey
      02-26-2013 12:37 PM #16
      Quote Originally Posted by jstewart204 View Post
      yes... but extremely rare where the piston tip cracks.
    17. Member Daniel_M's Avatar
      Jan 27th, 2013
      Phoenix, AZ
      2013 VW GLI
      02-26-2013 01:05 PM #17
      I believe all turbo cars have a wastegate. It is what controls the pressure that goes into the turbine. We have DV in lieu of a BOV though.
      -Dan
      2013 Candy White Jetta GLI: APR Stage 2, AWE Turbo Outlet Pipe, SPM Downpipe, Magnaflow Cat-back, Godspeeds (eBay) "Twintercooler" knockoff, Vogtland 1.6" drop springs, ECS Tuning boost guage
    18. Member
      Dec 9th, 2012
      Ohio, USA
      2013 Jetta GLI DSG
      02-26-2013 01:29 PM #18
      Quote Originally Posted by Daniel_M View Post
      -Dan
      Ah, as usual, some searching and reading answered my question..
      DV or BOV = intake side pressure regulation.
      Wastegate = exhaust side pressure regulation.
      I'm still confused why you'd want to switch from computer-controlled, DV to a 'dumb' one that activates at a specific pressure only?
    19. Member Daniel_M's Avatar
      Jan 27th, 2013
      Phoenix, AZ
      2013 VW GLI
      02-26-2013 01:40 PM #19
      Probably because it will be more consistent. You can always rely on it releasing at a certain PSI. Whereas an ECU controlled one has more variables involved and may alter the boost according to ECU readings. If something is going wrong with the car the ECU can erroneously tell the DV to do something it shouldn’t.
      That may be the thought process behind it. I don’t know though…
      -Dan
    20. 02-26-2013 02:02 PM #20
      -Dan
      Yess....Interesting
      Speaking in theoretic's, lets say the car is chipped...
      Wouldnt we be better off to let the ECU control the 'smart' DV?
      It is designed to draw the most from the entire engine, from intake hose out to turbo exhaust
      or Perhaps its just erroneous
    21. Member
      May 10th, 2010
      North Jersey
      02-26-2013 02:20 PM #21
      -Dan
      Not all have a wastegate. The ones that use a Variable Nozzle Turbo, ie TDI's, Chrysler 2.2L turbos... Porsche 997 turbo... don't.
      They use a series of nozzles/vanes that direct exhaust gas to the turbine or goes around the turbine
      Nozzles closed
      nozzles open
    22. Member
      Apr 18th, 2011
      Corpus Christi, TX
      2012 VW Jetta GLI
      02-26-2013 02:36 PM #22
      Yess....Interesting
      The benefit I see in running the "dumb" dv is that because it runs straight off the actuall vaccum and boost created by the engine and turbo, you know it will always be closed during boost and open during vaccum. I think that at times the ecu may keep the "smart" valve closed during shifts and that at times, depending on the situation, it may bleed boost.
      Now does this mean more power or anything like that, no. It just comes down to preference. There are lots people running either valve with no real issues.
      2012 candy white Jetta GLI
    23. Member
      Apr 18th, 2011
      Corpus Christi, TX
      2012 VW Jetta GLI
      02-26-2013 02:38 PM #23
      Nozzles closed
      nozzles open
      Yea, this is bassically how almost all modern diesel turbos work. The new turbo Mercedes AMG engines use VGT turbos also.
    24. Member
      Dec 9th, 2012
      Ohio, USA
      2013 Jetta GLI DSG
      02-26-2013 02:48 PM #24
      Quote Originally Posted by TC4Tay View Post
      I'm a little surprised that's enough to avoid the need for a wastegate, but I guess, if it's effective enough in letting air bypass, it would functionally be similar. I was honestly a little surprised the TSI doesn't use that style of turbo, but I do prefer reliability over having the latest tech, so I wasn't that concerned.
    25. Member
      May 10th, 2010
      North Jersey
      02-26-2013 02:53 PM #25
      the technology on gasoline engines has been around since 1989, about 10 years prior to VW using it on a TDI
