VWVortex.com - What octane should I run with Jetta 2.5?
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 61
    Thread: What octane should I run with Jetta 2.5?
    1. Junior Member
      Feb 6th, 2013
      Berks County, Pennsylvania
      1999 Dodge Ram 1500 (Dead); 2013 Jetta TDI
      03-10-2013 09:39 PM #1
      Hello. My girlfriend just bought her first Volkswagen. She was able to manage to buy a leftover 2012 Jetta SE with convience and sunroof. I was wondering what octane fuel is best to run and if running 87 is horrible for it or not. And if anyone had any ideas to if running higher octane gives better MPG.
      Thanks
    2. Member LWW's Avatar
      Dec 18th, 2012
      Ohio
      2013 JETTA SE/1999 MAZDA MIATA/2001 GMC SIERRA Z71/1996 Z24/1967 HONDA 305 SCRAMBLER/1973 CHECKMATE
      03-10-2013 09:52 PM #2
      Quote Originally Posted by Zerdio View Post
      Thanks
      What has been proven is:
      - The car will not have drveabilty issue on 87 octane.
      - There is a few horsepower to be gained by running on 93 octane
      I have ran a few tank of both and the results have been 24.87 MPG on 93, 25.50 on 87, and 25.35 on 89.
      That's a very sall sampling on a new engine through winter ... but enough to suggest that there is no significant difference in MPG between the three.
    3. Member mvthree's Avatar
      Sep 23rd, 2012
      Long Island
      MKVI Jetta 2.5, B6 A4
      03-10-2013 09:54 PM #3
      Thanks
      Run 87. I've used 93 and it really doesn't change much the only way you'd really benefit is if you get the ecu programmed to run a higher grade. Typically high performance and turboed cars use higher grade fuel.
      Also for your cars in the future the recommended fuel is listed in the manual
    4. Member mattng06's Avatar
      Jan 20th, 2012
      Lake St Louis, MO
      2012 VW GLI DSG/ Tornado Red 2002 BMW 530I Sport
      03-10-2013 09:55 PM #4
      Thanks
      Do what the owners manual says.
      2012 GLI DSG- Neuspeed P-flow intake- H&R sport- BSH Torque Mount Insert- USP Traction Switch
      14.40@96.19
      Feb 3rd, 2011
      Chesapeake, VA
      '12 GLI Platinum Gray
      03-10-2013 10:01 PM #5
      Quote Originally Posted by mvthree View Post
      Run 87.
      This. The engineers didn't guess that 87 would be ok. They built the engine and ECU specs to support NA fuels. If it required a higher octane (again, please don't confuse fuel QUALITY with octane rating), they would specify PREMIUM/91+ like on the GLI.
      '12 Jetta GLI Platinum Gray
    6. Member crispy21's Avatar
      Mar 26th, 2012
      nj
      97 VW Golf 2.0
      03-10-2013 10:18 PM #6
      Quote Originally Posted by adamkramerusn View Post
      Quote Originally Posted by MikeMeachum View Post
      Will there be a Jetta/ GLI VII thread? I got one.
      Apr 7th, 2011
      Alberta
      03-10-2013 10:41 PM #7
      Quote Originally Posted by LWW View Post
      Good 2 know others had similar experience as I had. I continue to run 87.
      When I signal, I'm advising you that I'm about to change lanes, not asking for you to speed up and stop me!
    8. Member cute jetta's Avatar
      Jul 1st, 2012
      95 jetta, 01 Audi s4,95 corolla,12 jetta se
      03-10-2013 11:20 PM #8
      Regular all the time
      Sent from my iPhone 5 using Tapatalk
    9. Junior Member
      Feb 6th, 2013
      03-11-2013 06:09 AM #9
      Well the dealer never gave us the owners manual and I keep forgetting to ask but while I'm typing I am going to make a note of it ha. But I just wanted to see what everyone though if this subject. But I'm sure my girlfriend will be happy to know she can still buy cheap gas!!
    10. Member LWW's Avatar
      Dec 18th, 2012
      Ohio
      03-11-2013 06:12 AM #10
      Actually ... they used a knock sensor so that it could run on 87.
      Most, and probably all, cars tat run on 87 will pick up some power ith higher octane.
    11. Banned
      Nov 27th, 2012
      Palm Beach, FL
      MK6 2.5
      03-11-2013 01:56 PM #11
      I run 89 Octane in mine and always get my gas at reputable gas stations.. A car can benefit from a higher fuel octane, but this engine doesn't need the highest. It doesn't hurt to run mid-grade, that's for sure.. And if it hurts your wallet, you shouldn't be driving a brand new car to begin with.
    12. Member LWW's Avatar
      Dec 18th, 2012
      Ohio
      03-11-2013 03:19 PM #12
      Quote Originally Posted by dunndarryn View Post
      It depends on what you want ... if it's economy, brand name 87 will work well.
      If you want a relatively cheap power mod that won't cause warranty issues ... 93 will work.
      That being said, I plan to do some additional tanks on all 3 in warmer weather, but the 89 has potential as the best compromise between the two concerns.
      I'm a heavy footed old school hot rodder ... but this is my adult car.
    13. Member jmchristian's Avatar
      Apr 7th, 2012
      Marysville, Ohio
      2015 GTI and 2013 Beetle Turbo
      03-11-2013 03:48 PM #13
      From everything that I have read or been told, your statement is wrong. An engine that is made to run on 87 octane will run the best on 87 octane.
    14. Member
      May 10th, 2010
      North Jersey
      2016 Tiguan SE 4Motion
      03-11-2013 04:38 PM #14
      Very little power is to be gained, but a lot more deposits in the combustion chamber from using higher octanes (even Top Tier). The ECU does not advance the timing enough to fully support higher octanes, especially 91+
      APR Stage 1/Morimoto 5500K D3S bulbs/Hella XY 9006 bulbs... keeping the mods light on this one...
    15. Member MK611's Avatar
      Sep 4th, 2011
      2011 VW Jetta SE w/ Conv.
      03-11-2013 05:26 PM #15
      Quote Originally Posted by BsickPassat View Post
      Can I get some advice to this? I've put regular Shell 87 in my 2.5 all the time ever since I picked up the car. The dealer even filled Shell since Day 1. A while back I decided to put Chevron (same price as I usually fill up with Shell) and noticed horrible gas MPG. Same full tank driving I did with the Shell fuel lasted me max a week. Same driving, full tank with Chevron, half a week.
      Any insight?
    16. Member itskohler's Avatar
      Jan 7th, 2011
      Jacksonville, FL/Dallas, TX
      2012 Jetta, 2008 Jetta RIP
      03-11-2013 05:40 PM #16
      I ran 93 with no problems at all in my mkv for 89k miles with absolutely no problems.
      On 15k in the vi and still zero issues. Idles smooth, drives great.
    17. Member LWW's Avatar
      Dec 18th, 2012
      Ohio
      03-11-2013 06:49 PM #17
      Quote Originally Posted by jmchristian View Post
      Magazine dyno testing has been done on this topic ... including the VW 2.5 ... and modern engines rated for 87 will produce more powet on highet octane.
      That's why knock sensors are used ... if the vehicle was designef to run optimally on 87 no knock sensor would be needed. The reality is they are designec to run minimally on 87.
    18. Member jmchristian's Avatar
      Apr 7th, 2012
      Marysville, Ohio
      03-11-2013 07:38 PM #18
      Why TOP TIER
      The intention of the TOP TIER Detergent Gasoline standards is to create a winning situation for gasoline retailers, auto manufacturers and drivers. Currently, many gasoline retailers provide fuels with lower-quality additive packages that can build up deposits on fuel injectors and on intake valves. Others can build up deposits in combustion chambers and may lead to intake valve sticking. These lower levels of additives can have negative impacts on engine performance and vehicle responsiveness.
      If you are worried about deposits it doesn't matter what grade of gas you use. But like I said before buying premium grade gas for the 2.5 engine is a total waste of money. The grade you should use for your VW is located on the inside of the fuel filler flap. But if you have a modified chip disregard everything.
    19. Member itskohler's Avatar
      Jan 7th, 2011
      03-11-2013 07:53 PM #19
      Why TOP TIER
      UM tuned.
    20. Member LWW's Avatar
      Dec 18th, 2012
      Ohio
      03-11-2013 07:58 PM #20
      Why TOP TIER
      +5 HP ... +12 LB/FT torque with 91 octane over 87 octane.
      http://www.europeancarweb.com/tech/p...n/viewall.html
    21. Member
      May 10th, 2010
      North Jersey
      03-11-2013 09:13 PM #21
      Quote Originally Posted by MK611 View Post
      Any insight?
      Could be a bad tank.
      Chevron.... they are the ones that invented the popular PBA detergent used in inferior gasolines.
      They also developed the PEA detergent used in many Top Tier gasolines.
      Combustion chamber Deposits with using higher octane... is a long term issue, where that over time, due to incomplete combustion, deposits will form, which will increase the compression ratio, and thus necessitate more aggressive cleaning additive.
    22. Member itskohler's Avatar
      Jan 7th, 2011
      03-11-2013 09:17 PM #22
      Correct me if im wrong, carbon build up is more prevalent in direct injection engines.
    23. Member crispy21's Avatar
      Mar 26th, 2012
      nj
      97 VW Golf 2.0
      03-11-2013 09:19 PM #23
      Quote Originally Posted by itskohler View Post
      You are correct
    24. Member
      May 10th, 2010
      North Jersey
      03-11-2013 09:20 PM #24
      it happens in port injection.
      unlike direct injection, it can be treated with gasoline additives, or use a good fuel that uses PEA detergent.
    25. Member
      Feb 3rd, 2011
      Chesapeake, VA
      03-11-2013 09:21 PM #25
      Correct, because there isn't fuel being sprayed on the backside of the valves in the air/fuel mixture as it enters the cylinders.
