VWVortex.com - idel jumping up and down on a 90 corrado help plz
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 33
    Thread: idel jumping up and down on a 90 corrado help plz
    1. Junior Member dinho10's Avatar
      Mar 20th, 2013
      san jose ca
      1990 vw corrado g60
      03-20-2013 11:24 PM #1
      i need some help with my 90 corrado
    2. Member crazynorweegian's Avatar
      May 8th, 2006
      Portland, OR
      1990 Corrado 1.9L G60-ST5 Black, 01 stage 3 allroad 6MT
      03-21-2013 12:03 AM #2
      Quote Originally Posted by dinho10 View Post
      Cool.
      Stephen
      Portland, OR
      Black 1990 1.9L Stage 5 G60 - keeper
      Corrados decay in a way that can only be measured using quantum physics
      http://sites.google.com/site/corradoproject/
    3. Member ozzy1317's Avatar
      Feb 5th, 2010
      Houston, Texas
      7/89 Volkswagen Corrado G60
      03-21-2013 12:36 AM #3
      Quote Originally Posted by crazynorweegian View Post
      Cool.
      LOL
    4. Junior Member dinho10's Avatar
      Mar 20th, 2013
      san jose ca
      1990 vw corrado g60
      03-21-2013 12:52 AM #4
      Idle is up and down and wen it does that my screen in the insides goes 0's ( u kno the one that gives u the time and oil pressure) and there's a clicking in or by the fuse box, I just rebuilt my engine and it wasn't doing that... At times the car runs super smooth but then if I turn in off for a wile or for the next day it starts but the idle jumping up and down or it stays at 2000 for I bit then ill come down again.
    5. Member vdubCorrado's Avatar
      Nov 8th, 2001
      Baltimore MD
      15 Ram 1500 - 91 Corrado - 97 Cobra
      03-21-2013 01:21 AM #5
      you probably forgot to reconnect the ground on the driver side of the head. it grounds your
      ECU along multiple other things... make sure that's put back, cleaned and with a clean surface on the head... if it is then you may want to consider regrounding that plate with an extra wire from it to the head, a valve cover nut worked fine on my 91 years ago
    6. Junior Member dinho10's Avatar
      Mar 20th, 2013
      san jose ca
      1990 vw corrado g60
      03-21-2013 01:32 AM #6
      R u talking about the ground that goes from the corner of the valve cover to the coil? That I did and I also re ground it and nothing....
    7. Member vdubCorrado's Avatar
      Nov 8th, 2001
      Baltimore MD
      03-21-2013 01:35 AM #7
      ECU, Coil and uhh... one other thing ground to this little bracket and then the bracket bolts to the back side of the head. if you dont have 3 grounds here then that is your problem. your ECU is not getting a proper ground causing the piss poor fueling and the loss of signal to the gauges.
      cant help you with picks as i no longer own a G60. if you have a Bentley i would star digging for diagrams around the cylinder head sections
    8. Junior Member dinho10's Avatar
      Mar 20th, 2013
      san jose ca
      1990 vw corrado g60
      03-21-2013 01:44 AM #8
      I have the ground from the back of the head there, that goes to the coil right? I don't kno wat u mean wen u say I should have 3 grounds there... And am new to this I also don't kno wat Bentley is...
    9. Junior Member
      Jul 4th, 2012
      OC California
      1990 Corrado g60
      03-21-2013 05:30 AM #9
      Bentley manual .... should have been the first thing you bought...
    10. Member mateok's Avatar
      Mar 14th, 2001
      Atlanta, GA
      90 G60 (since new) 93+VR 13 GTI
      03-21-2013 08:23 AM #10
      The ECU grounds from pin 13 straight to the battery negative post. The car won't even start if that's disconnected. You have four B/W ground wires going to the coolant flange on the head. Hall sensor, idle switch, CTS, and CO Pot.
      Idle issues on a G60 are so common, there's a half a billion threads out there covering it. If your idle is jumping up and down, that's usually the ISV or unmetered air getting in somehow.
    11. Junior Member dinho10's Avatar
      Mar 20th, 2013
      san jose ca
      1990 vw corrado g60
      03-22-2013 01:14 AM #11
      So I looked and looked and I kno it's not a ground issue and I changed the ISV so it's not, the car stays stable but at times it drops from 2000 to 1000 wile driving but it goes back to normal... Today I was driving it, it was good but as soon as I was on a red light the idle would start jumping up and down from 1000 to 1800 and back to normal...
    12. 03-22-2013 02:41 AM #12
      Check for vacuum leaks. I am having the same trouble and am in process of renewing my vacuum hoses.
    13. Member crazynorweegian's Avatar
      May 8th, 2006
      Portland, OR
      03-22-2013 03:45 AM #13
      Quote Originally Posted by etomori View Post
      It is another case of the usual suspects on this. Your Bentley will help tremendously on this and you haven't mentioned having one so I assume you don't; shame on you.
      How exactly have you determined it is not a ground issue?
      Check the ground wire(s) that should be going to the side coolant flange on the head (not the ground straps on the hood and valve cover). Check this first, put on a new connector, clean up the wires, and spray some kind of cleaner/ protector on it.
      Other options:
      TEST and adjust your ISV, don't just replace it and assume it works.
      Blue coolant temp sensor (or wiring)
      o2 sensor (or wiring)
      Fuel pump(s) (or wiring)
      FPR
      ECU relay
      Fuel pump relay
      Ignition timing
      Clean injectors and inspect/ replace injector wiring loom
      ECU vacuum line
      Vacuum leak (test vacuum per the Bentley for leak)
      Super terrible boost leak (use DIY boost leak test from VWvortex)
      Good luck
      Stephen
      Portland, OR
    14. Junior Member dinho10's Avatar
      Mar 20th, 2013
      san jose ca
      1990 vw corrado g60
      03-22-2013 01:06 PM #14
      How can i test or adjust my ISV?
    15. Junior Member dinho10's Avatar
      Mar 20th, 2013
      san jose ca
      1990 vw corrado g60
      03-22-2013 01:08 PM #15
      And were can i grt this Bentley?
    16. 03-22-2013 03:48 PM #16
      amazon, half.com, google, ebay, craigslist...
    17. Member mateok's Avatar
      Mar 14th, 2001
      Atlanta, GA
      03-22-2013 06:40 PM #17
    18. Banner Advertiser CarNut84GTi's Avatar
      Oct 2nd, 2002
      84 GTI, 09 A3 2.0T Quattro
      03-22-2013 08:52 PM #18
      Bentley Service Manual: http://wrdusa.com/mm5/merchant.mvc?S...radog60manuals
      Will make your life a lot easier
      www.VDubWarehouse.com Contact: 775-342-9591
      Follow us on Facebook: www.facebook.com/vdubwarehouse
      Great Deals on WRD, Koni, H&R, Neuspeed, APR, SPEC, Techtonics Tuning, Eurospec Sport, and more!
      My 09 A3 Quattro Build
    19. Junior Member dinho10's Avatar
      Mar 20th, 2013
      san jose ca
      1990 vw corrado g60
      03-22-2013 08:54 PM #19
      Did that. And my car still the same... Wen I turn the car on idle goes up and down. And the inside screen were it gives u the time turns off and on every time going to MFA2 0:00 I already got the fuel pump relay and still the same
    20. Junior Member dinho10's Avatar
      Mar 20th, 2013
      san jose ca
      1990 vw corrado g60
      03-22-2013 08:59 PM #20
      And thank ill try to get the Bentley ASAP
    21. Member mateok's Avatar
      Mar 14th, 2001
      Atlanta, GA
      03-22-2013 09:15 PM #21
      Is the clock going blank and then coming back on? It gets it's power from circuit 30, Y3 connector, straight from the battery. There's a few other things on that track, as well. Cigarette lighter, pretty much all the switch lighting. Are those things acting stupid, too?
    22. Junior Member dinho10's Avatar
      Mar 20th, 2013
      san jose ca
      1990 vw corrado g60
      03-22-2013 10:37 PM #22
      No only the clock goes blank and back on everythionly thing als is good...only the clock blinks off and on
    23. Junior Member dinho10's Avatar
      Mar 20th, 2013
      san jose ca
      1990 vw corrado g60
      03-22-2013 11:54 PM #23
      Only the clock goes blank and on. And web it does there's a clicking sound by or in the fuse box. Everything alls is good just the clock goes blank and back on
    24. Member mateok's Avatar
      Mar 14th, 2001
      Atlanta, GA
      03-23-2013 08:57 AM #24
      Pull fuse S21 (15a) and go for a drive. See if the problem goes away.
    25. Junior Member dinho10's Avatar
      Mar 20th, 2013
      san jose ca
      1990 vw corrado g60
      03-23-2013 11:13 AM #25
      I will do that today were is it located. And this morning my car was throwing smoke like a withe smoke
