VWVortex.com - How much does it cost to repair (rear) window regulator? Passat 99
    Results 1 to 4 of 4
    Thread: How much does it cost to repair (rear) window regulator? Passat 99
      Nov 1st, 2007
      Pasadena, California
      Owns: 1999/Passat
      03-27-2013 08:03 PM #1
      Hi everyone,
      Both sides of the rear passenger windows don't go down when I press the window switch. I "broke" the left side by slamming the door very hard a few years back. The right one just randomly stopped working. It was working fine a few days ago. I can hear both motors functioning, but both window glasses don't go down.
      I suspect it is a regulator problem...how much does it cost to repair the window? I asked a window-tech and he said he found 2 used window regulators and can repair both windows for $360. I wonder if it's better off repairing with new parts or used parts. Any suggestions/comments are appreciated!!!
      I drive 99 1.8t passat
    2. Awaiting Email Confirmation TheMoneyPit's Avatar
      Jun 2nd, 2003
      unSAFE NY
      03-28-2013 01:50 PM #2
      Due to the common problems associated with window regulators I would recommend getting brand new ones.
      Whats to say the used ones aren't on their way out as well? The most common issue is a pulley on the regulator cable gets brittle and snaps or the cable gets chewed up by the motor.
      Completely up to you but I'd say invest in some brand new Genuine brand regulators.
      http://www.germanautoparts.com/Volks...sat/Body/247/3
      $354 in parts and then probably 1.5 hours each for labor.
      Dec 5th, 2003
      Cleveland, Ohio
      2002 Passat GLX Wagon (2.8L V6 "ATQ")
      03-28-2013 05:06 PM #3
      Last year I had to replace the window regulator on the driver's door on my 2002 Passat wagon. The new regulator (without a new motor) was less than $80 and that was pre-mounted to a new metal plate. The installation was fairly straight forward, but time consuming to take the innards of the door apart.
      I don't know why, but the rear regulators seem to be much more expensive ($200).
    4. Member Steve in Chicago's Avatar
      Dec 13th, 2008
      Chicago, Illinois
      1999 Volkswagen Passat GLS
      03-29-2013 09:43 AM #4
      I have a B5 Passat sedan rear passenger door regulator (used) with motor. $50 plus shipping if you're interested.
      A science of vague assumptions based on debatable figures taken from inconclusive experiments and performed with instruments of problematic accuracy by persons of doubtful reliability and questionable mentality
