VWVortex.com - 2007 VW Rabbit: Brake lights stuck on, Cruise Control doesn't work
    Results 1 to 7 of 7
    Thread: 2007 VW Rabbit: Brake lights stuck on, Cruise Control doesn't work
      Mar 15th, 2004
      Houston, TX
      2007 Rabbit
      04-10-2013 07:33 PM #1
      I recently followed various Vortex DIYs for the installation of the following (with coding used):
      Since I completed the install and VAGCOM'ed, I have had the following symptoms:
      • EPC light on
      • Bulb out light on
      • Cruise Control doesn't work
      • Brake lights (including high stop) illuminated as long as key is at the accessory position or beyond
      One wiring mistake I made in wiring the rear fog:
      I temporarily installed the grey wire from B12 to C4 instead of C12 to B4 in my wiring change for the rear fog. I realized a day later so I drove a couple times like this. Don't know what B12 does, but that could be something. Anyone?
      Rear lights function as normal now as long as key is removed - including (no brake lights when car is off,) marker/parking illuminate, amber hazards blink, reverse illuminates, rear fog illuminates.
      Rear lights function almost normal when car is on or in acc - marker/parking illuminate, amber turn signals and hazards blink, reverse illuminates, rear fog illuminates, however the brake lights are always on.
      Here is post install VCDS scan:
      Friday,05,April,2013,19:34:11:52052
      VCDS Version: Release 11.11.5 (x64)
      Data version: 20121222
      Chassis Type: 1K0
      Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
      VIN: WVWAR71K47W177130 Mileage: 106960km/66461miles
      00-Steering Angle Sensor -- Status: OK 0000
      01-Engine -- Status: Malfunction 0010
      08-Auto HVAC -- Status: OK 0000
      09-Cent. Elect. -- Status: Malfunction 1010
      15-Airbags -- Status: Malfunction 0010
      16-Steering wheel -- Status: Malfunction 0010
      17-Instruments -- Status: Malfunction 0010
      19-CAN Gateway -- Status: Malfunction 0010
      25-Immobilizer -- Status: Malfunction 0010
      42-Door Elect, Driver -- Status: Malfunction 0010
      46-Central Conv. -- Status: Malfunction 0010
      52-Door Elect, Pass. -- Status: Malfunction 0010
      56-Radio -- Status: Malfunction 0010
      Address 01: Engine Labels: 06A-906-032-BGP.lbl
      Part No SW: 07K 906 032 T HW: 07K 906 032 Q
      Component: 2.5l R5/4V G 9653
      Revision: --H01--- Serial number: VWZ7Z0G8020009
      Coding: 0000001
      Shop #: WSC 01279 785 00200
      VCID: 3A55E1337594CDC82F8
      5 Faults Found:
      006481 - Radiator Fan 2 (V177)
      P1951 - 002 - Movement Restricted / Jammed - Intermittent
      Freeze Frame:
      Fault Status: 00100010
      Fault Priority: 0
      Fault Frequency: 254
      Mileage: 97912 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 22:00:01
      Freeze Frame:
      RPM: 1243 /min
      Load: 45.9 %
      Speed: 37.0 km/h
      Temperature: 86.0∞C
      Temperature: 51.0∞C
      Absolute Pres.: 1010.0 mbar
      Voltage: 14.097 V
      001152 - Coolant Fan Control Circuit 1
      P0480 - 004 - Electrical Malfunction - Intermittent
      Freeze Frame:
      Fault Status: 00100100
      Fault Priority: 0
      Mileage: 97912 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 23:01:20
      Freeze Frame:
      RPM: 833 /min
      Load: 19.6 %
      Speed: 12.0 km/h
      Temperature: 79.0∞C
      Temperature: 40.0∞C
      Absolute Pres.: 1000.0 mbar
      Voltage: 13.970 V
      006480 - Radiator Fan (V7)
      P1950 - 002 - Movement Restricted / Jammed - Intermittent
      Freeze Frame:
      Fault Priority: 0
      Fault Frequency: 211
      Mileage: 98109 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 09:53:31
      Freeze Frame:
      RPM: 1876 /min
      Load: 23.9 %
      Speed: 56.0 km/h
      Temperature: 85.0∞C
      Temperature: 49.0∞C
      Voltage: 13.970 V
      000768 - Random/Multiple Cylinder Misfire Detected
      P0300 - 008 - - Intermittent
      Freeze Frame:
      Fault Status: 00101000
      Fault Priority: 0
      Fault Frequency: 1
      Mileage: 105641 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 04:52:31
      Freeze Frame:
      RPM: 878 /min
      Load: 36.1 %
      Speed: 0.0 km/h
      Temperature: 15.0∞C
      Temperature: 17.0∞C
      Absolute Pres.: 1020.0 mbar
      Voltage: 14.224 V
      000772 - Cylinder 4
      P0304 - 008 - Misfire Detected - Intermittent
      Freeze Frame:
      Fault Priority: 0
      Fault Frequency: 1
      Mileage: 105641 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 04:53:29
      Freeze Frame:
      RPM: 844 /min
      Load: 29.4 %
      Speed: 1.0 km/h
      Temperature: 25.0∞C
      Temperature: 17.0∞C
      Voltage: 14.224 V
      Readiness: 0000 0000
      Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
      Part No: 1K0 907 379 P
      Component: ASR FRONT MK70 0105
      Coding: 0017025
      VCID: 3FA390276EB6E8E0186
      No fault code found.
      Address 08: Auto HVAC Labels: 1K0-820-047.lbl
      Part No: 1K0 820 047 FP
      Component: Climatic PQ35 120 0606
      Shop #: WSC 00000 000 00000
      VCID: 77D33807060610A0106
      Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
      Part No SW: 3C0 937 049 AA HW: 3C0 937 049 AA
      Component: Bordnetz-SG H45 1402
      Revision: 00H45000 Serial number: 00000002292445
      Coding: 018D0F2700041500470A00000F000000000955035C0001
      Shop #: WSC 08277 444 57840
      VCID: 68F16B7B5BB88F5889C
      Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
      Component: Wischer 050107 020 0501
      Coding: 00038805
      Shop #: WSC 08277
      10 Faults Found:
      00984 - Left Tail Light (M4)
      012 - Electrical Fault in Circuit
      Freeze Frame:
      Fault Status: 01101100
      Fault Priority: 2
      Fault Frequency: 1
      Reset counter: 103
      Mileage: 106966 km
      Time Indication: 0
      Freeze Frame:
      ON
      Voltage: 14.05 V
      ON
      ON
      OFF
      OFF
      OFF
      00985 - Right Tail Light (M2)
      Freeze Frame:
      Fault Priority: 2
      Fault Frequency: 1
      Reset counter: 103
      Mileage: 106966 km
      Time Indication: 0
      Freeze Frame:
      ON
      Voltage: 14.05 V
      ON
      ON
      OFF
      OFF
      OFF
      00906 - Horn (H1)
      009 - Open or Short to Ground - Intermittent
      Freeze Frame:
      Fault Status: 00101001
      Fault Priority: 2
      Fault Frequency: 1
      Reset counter: 142
      Mileage: 0 km
      Time Indication: 0
      Freeze Frame:
      OFF
      Voltage: 5.00 V
      OFF
      OFF
      OFF
      OFF
      OFF
      00924 - Relay for Headlamp Cleaning System (J39)
      Freeze Frame:
      Fault Status: 01101001
      Fault Priority: 4
      Fault Frequency: 1
      Reset counter: 103
      Mileage: 0 km
      Time Indication: 0
      Freeze Frame:
      OFF
      Voltage: 5.00 V
      OFF
      OFF
      OFF
      OFF
      OFF
      01800 - Light Switch (E1)
      008 - Implausible Signal - Intermittent
      Freeze Frame:
      Fault Priority: 3
      Fault Frequency: 5
      Reset counter: 142
      Mileage: 0 km
      Time Indication: 0
      Freeze Frame:
      OFF
      Voltage: 5.00 V
      OFF
      OFF
      OFF
      OFF
      OFF
      02071 - Local Databus
      004 - No Signal/Communication - Intermittent
      Freeze Frame:
      Fault Priority: 2
      Fault Frequency: 1
      Reset counter: 142
      Mileage: 0 km
      Time Indication: 0
      Freeze Frame:
      OFF
      Voltage: 5.00 V
      OFF
      OFF
      OFF
      OFF
      OFF
      01049 - Supply Voltage Term 50
      012 - Electrical Fault in Circuit - Intermittent
      Freeze Frame:
      Fault Status: 00101100
      Fault Priority: 1
      Fault Frequency: 1
      Reset counter: 142
      Mileage: 160702 km
      Time Indication: 0
      Freeze Frame:
      ON
      Voltage: 12.00 V
      OFF
      ON
      ON
      OFF
      OFF
      00526 - Brake Light Switch-F
      Freeze Frame:
      Fault Status: 01101000
      Fault Priority: 2
      Fault Frequency: 1
      Reset counter: 103
      Mileage: 106966 km
      Time Indication: 0
      Freeze Frame:
      ON
      Voltage: 12.10 V
      ON
      ON
      OFF
      OFF
      OFF
      00153 - Windshield Wiper Motor; Driver Side (V216)
      Freeze Frame:
      Fault Priority: 2
      Fault Frequency: 1
      Reset counter: 142
      Mileage: 0 km
      Time Indication: 0
      Freeze Frame:
      OFF
      Voltage: 5.00 V
      OFF
      OFF
      OFF
      OFF
      OFF
      00979 - Lamp for Low Beam; Right (M31)
      007 - Short to Ground - Intermittent
      Freeze Frame:
      Fault Status: 00100111
      Fault Priority: 1
      Fault Frequency: 1
      Reset counter: 142
      Mileage: 160702 km
      Time Indication: 0
      Freeze Frame:
      ON
      Voltage: 11.75 V
      ON
      ON
      OFF
      OFF
      OFF
      Address 15: Airbags Labels: 1K0-909-605.lbl
      Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
      Component: 5L AIRBAG VW8R 034 8000
      Revision: 05034000 Serial number: 003B6D07TXFV
      Coding: 0013644
      Shop #: WSC 01269 785 00200
      VCID: 6CF9176B4F40A378ED4
      Part No: 1K0 959 339 G
      Component: BF-Gewichtsens. 007 0007
      1 Fault Found:
      02513 - Belt Force Sensor for Seat Occupied Recognition (G453)
      003 - Mechanical Failure - Intermittent
      Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
      Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
      Component: Lenks‰ulenmodul 636 0070
      Coding: 0000022
      VCID: 76CD3503010C69A80B0
      1 Fault Found:
      00883 - Ignition Switch (D) Terminal S
      Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
      Part No SW: 1K0 920 953 P HW: 1K0 920 953 P
      Component: KOMBIINSTRUMENT VDD 1610
      Revision: V0003000 Serial number: VWZ7Z0G8020009
      Coding: 0007407
      Shop #: WSC 00000 785 00200
      VCID: 3851FB3B4B98DFD8D9C
      1 Fault Found:
      01336 - Data Bus for Comfort System
      Freeze Frame:
      Fault Priority: 2
      Fault Frequency: 1
      Reset counter: 142
      Mileage: 106966 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 02:12:23
      Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
      Part No SW: 1K0 907 530 K HW: 1K0 907 951
      Component: J533__Gateway H04 0021
      Revision: H04 02 Serial number: 210107F1001347
      Coding: 3D0F034007000000
      VCID: 2F43C067BED61860886
      1 Fault Found:
      00457 - Control Module for Network (J519)
      Freeze Frame:
      Fault Status: 00110100
      Fault Priority: 2
      Fault Frequency: 1
      Reset counter: 142
      Mileage: 106966 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 02:12:24
      Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
      Component: IMMO VDD 1610
      Shop #: WSC 25038 444 92088
      1 Fault Found:
      01176 - Key
      Freeze Frame:
      Fault Priority: 2
      Fault Frequency: 1
      Mileage: 97169 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 12:51:33
      Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
      Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
      Component: Tuer-SG 005 0983
      Coding: 0001141
      1 Fault Found:
      00120 - Outside Warning Light/Door exit Light Driver Side
      Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
      Part No: 1K1 909 144 L
      Component: EPS_ZFLS Kl.069 H07 1806
      Shop #: WSC 00000 028 00001
      VCID: 3449CF0B57F03BB8F54
      Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
      Part No: 1K0 959 433 CM
      Component: KSG 0401
      Coding: 93C80B483F09058F880A048050CC
      VCID: 7DDF2A2F243A3AF04AA
      Component: Sounder n.mounted
      Component: NGS n.mounted
      Component: IRUE n.mounted
      1 Fault Found:
      Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
      Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
      Coding: 0001140
      VCID: 3957FE3F7092C6D0262
      1 Fault Found:
      00121 - Outside Warning Light/Door exit Light Passenger Side
      Address 56: Radio Labels: 1K0-035-161.lbl
      Part No SW: 1K0 035 161 B HW: 1K0 035 161 B
      Component: Radio DE2 014 0017
      Revision: 00014000 Serial number: VWZ4Z7F6198828
      Coding: 0040401
      VCID: 1E1D0DA3C97C81E8330
      3 Faults Found:
      00856 - Radio Antenna
      00849 - S-contact at Ignition/Starter Switch (D)
      End ---------------------------------------------------------------------
      Checked Brake Light Switch fuses SB22 and SC13. Per google search thought it was a fault in the Brake Light Switch. Bought a new swtich and replaced it today. No change.
      With the battery disconnected for switch install the EPC light was reset but came on.
      Does anyone have any ideas? Am I missing something?
      Mar 15th, 2004
      Houston, TX
      2007 Rabbit
      04-11-2013 07:53 PM #2
      Rechecked wiring to recent installs and everything looks good.
      Any one know the possible causes for brake lights to be stuck on?
      Mar 15th, 2004
      Houston, TX
      2007 Rabbit
      04-16-2013 02:49 PM #3
      Have been told this might have to do with switching to UK coding.
      Can any one confirm? Any info?
    4. Member Bartnik's Avatar
      Oct 26th, 2000
      Brooklyn
      1965 Volkswagen 1500 Variant S; 2000 Kawasaki W650
      04-16-2013 04:00 PM #4
      The first possible cause that comes to my mind based upon your symptoms is an issue with the brake light switch (either switch defect or wiring problem/wiring disconnected).
      The cruise control doesn't work because its controller is getting a signal out of range from the brake light switch and therefore disables cruise control as a safety matter (since the brake light switch is one of the main things used to cancel cruise control while driving).
      EDIT: sorry, just now saw at the bottom of your post where you said you replaced the brake light switch already. Soooo I'm all out of ideas.
      Jun 1st, 2003
      Dearborn Heights, MI
      2005.5 MKV TDI
      04-16-2013 04:10 PM #5
      Triple check your wiring at each Tail Light.
      Sounds like your Tail Light is the BRAKE LIGHT and the Brake Light is the Tail Light.
      Rain Closing Windows, goF raeR, Aspherical Mirrors, Remote Windows, Amber Club
    6. Member
      Mar 15th, 2004
      Houston, TX
      2007 Rabbit
      04-16-2013 06:02 PM #6
      Thanks Tim Birney. I have triple checked the rear wiring and it matches what I found in the DIY (http://forums.vwvortex.com/showthrea...D-Installation):
      LED Left (Driver's side):
      1. Black/white (turn signal)
      2. Black/red (brake light)
      3. New Wire (Parking light)
      4. Brown (common/return)
      LED Right (Passenger side):
      1. Brown (common/return)
      2. New Wire (Parking light)
      3. Black/purple (brake light)
      4. Black/green (turn signal)
      Also, rear LEDs seem to function as others have described:
      • Parking lights = both inner and outer circle
      • Brake lights = inner circle
      • Amber turns = outer circle
      Also the parking lights work normally when the car is completely off. Brake lights are only stuck on when car is in ACC or ON.
    7. Member Vdub_spikes's Avatar
      Mar 8th, 2002
      Waipahu, Hi
      CW MKV Rabbit
      10-07-2014 11:15 PM #7
      ever found the fix for this?
