VWVortex.com - 2012 GLI manual transmission failed
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 53
    Thread: 2012 GLI manual transmission failed
    1. Junior Member
      Jul 29th, 2012
      2012 GLI Autobahn
      04-16-2013 07:57 PM #1
      So, on my way home from work today, with 11k miles, it suddenly because very difficult to get the car into or out of gear. I drove straight to the dealer. Once in gear, there was no problem- no slipping, etc. It seemed like the clutch wasn't fully engaging when the pedal was depressed. Dealer concluded that the issue was internal, so they are now taking out the transmission. Anyone else have a clutch mechanism failure on a 6 spd manual? Doesn't seem to be a common problem.
      '12 GLI Autobahn
    2. Member 2.SlowDriverFound's Avatar
      Sep 15th, 2005
      Lynchburg, VA
      2012 Jetta GLI, 06 Kawasaki z750s
      04-16-2013 08:03 PM #2
      My clutch is being replaced as we speak with a South Bend stage 3 clutch disc for this very reason. I assumed it was because of my APR stage 1 tune + my a-hole driving. Strange. I was also thinking that this isn't a common problem since I hadn't really seen a post about it before.
      Don't feed the trolls...
      '12 GLI APR II
    3. Awaiting Email Confirmation The_GReekster's Avatar
      Nov 19th, 2012
      Montreal,QC
      2004 Audi A4 avant, 2016 MK7 R
      04-16-2013 08:25 PM #3
      Quote Originally Posted by beanpoppa View Post
      Same here..it feels weird shifting into gears especially noticeable when pushing the car...i thought it was related to my oem short shifter...
    4. Junior Member
      Jul 29th, 2012
      2012 GLI Autobahn
      04-16-2013 09:15 PM #4
      I'm completely stock, and generally take it easy. The issue did start after a spirited launch from a stop-light, but certainly nothing extreme. What part of the clutch going out caused you to replace it? I was figuring something in the linkage or fork mechanism is bent, or maybe the hydraulics. Can't see the clutch going bad so early the way that I drive, but I don't know the mechanics of the pressure plate and flywheel well enough.
      '12 GLI Autobahn
    5. Junior Member guant0n's Avatar
      Dec 23rd, 2012
      Raleigh, NC
      '13 PG GLI MT
      04-16-2013 09:29 PM #5
      I don't know if I'm letting the clutch out a lil too fast or if the sound has always been there, but during low speeds at 1st/2nd gear, I can sometimes hear a "clack" when the clutch comes in contact with the flywheel (it kinda goes away when i'm slower/lighter on the clutch depress). I can also hear some noise/clackiness when the knob goes from 1st to 2nd and sometimes 2nd to 3rd. Is something coming loose in or around my clutch? OP did you ever experience these symptoms leading up to the trans failure?
      APR Stage 1 | Carbonio CAI Stage 1
    6. Junior Member
      Jul 29th, 2012
      2012 GLI Autobahn
      04-16-2013 09:38 PM #6
      Absolutely no symptoms until it happened. Even the shift into first at the stop-light was uneventful, but the shift into 2nd or 3rd (not sure which) as I was accelerating was suddenly very difficult, and each shift was from that point on. I could manage a little better with double clutching and rev matching, but it was never easy all the way to the dealer. Sitting at a stop light in 2nd gear and the clutch engaged (I kept in 2nd all the way from the highway exit to the dealer to minimize any wear on the synchros) the idle was a little low and rough- possibly because the plate was making contact with the flywheel) and when I was in the parking lot at the dealer, I put the car in reverse, and started it again, and it would creep a little with the clutch engaged. No problem shifting gears with the car off.
      '12 GLI Autobahn
    7. Junior Member
      Jul 29th, 2012
      2012 GLI Autobahn
      04-17-2013 04:36 PM #7
      First off, big props to Gensinger VW in Clifton, NJ. I called them from the road yesterday when the hard-shifting started asking if I could bring it straight in rather than stopping, and not being able to get it into gear again. They said no problem, and quickly got me a loaner Passat. They got to work on it right away, and by 2pm today, my car was ready for me to pick it up.
      According to them, the root cause was the slave cylinder failed, and on the GLI, the slave cylinder is inside the transmission connected to the throwout bearing. The combined failure of the throwout bearing and slave cylinder also caused damage to the pressure plate and clutch plate. They replaced all four parts, and I'm not having any problem shifting. One thing I did notice, however, is the clutch is much stiffer. Not sure if this is because it's brand new (not that 11k miles should have been much wear on the old one) or if the slave cylinder has been failing for a while.
      '12 GLI Autobahn
    8. Member mattng06's Avatar
      Jan 20th, 2012
      Lake St Louis, MO
      2012 VW GLI DSG/ Tornado Red 2002 BMW 530I Sport
      04-17-2013 04:40 PM #8
      I love manuals and had it them for years. I'm just super glad i got a DSG in this car, you manual guys are having so many problems.
      2012 GLI DSG- Neuspeed P-flow intake- H&R sport- BSH Torque Mount Insert- USP Traction Switch
      14.40@96.19
    9. Junior Member pmo's Avatar
      Feb 13th, 2013
      Texas
      2013 Platinum Gray Jetta GLI Autobahn 6MT
      04-17-2013 05:08 PM #9
      Quote Originally Posted by mattng06 View Post
      Problems will arise with anything mechanical. I'm sure there are some issues reported with DSG transmission. It's not a normal thing for a slave to fail so early. I had a master and slave fail on manual Hyundai at 75k miles, I thought that was early at the time. Had them both replaced for $1k at a local shop. I can't imagine any automatic transmission work to be less than $1k.
      So far the main issue I have read with the 6MT is the clutch doesn't provide enough pressure once you start modifying the car with ECU tunes and whatnot. Haven't read about clutches slipping on cars that are not modified yet.
    10. 04-17-2013 05:19 PM #10
      15K miles with APR Stage I. No problems with my manual.
      Sorry to hear about your prob's though.
    11. Junior Member
      Jul 29th, 2012
      2012 GLI Autobahn
      04-17-2013 05:24 PM #11
      Exactly. This does appear to be an unusual incident. Usually, when something goes wrong on my car, I can always find reports of similar issues on the Internet. I found nothing similar in my searches. When I was researching whether to get the DSG or not, I did find plenty of DSG failure complaints. Not to mention, if the DSG does fail, it's going to cost a lot more.
      Until I see evidence otherwise, I will chalk this up to a faulty part, and the dealer/VW made good by quickly replacing all parts affected.
      Quote Originally Posted by pmo View Post
      '12 GLI Autobahn
    12. Member mattng06's Avatar
      Jan 20th, 2012
      Lake St Louis, MO
      04-17-2013 05:42 PM #12
      Of course there's always going to be issues with DSG, but i haven't seen as many reports of failed ones compared to the manual with the MKVI GLI. I feel like VW has been getting their **** together with these new DSG's.
      14.40@96.19
    13. Member
      Jan 29th, 2012
      D F Dub
      2012 GLI Autobahn
      04-18-2013 12:53 AM #13
      I believe I am experiencing the same issues as you. My car is almost 15 months old with only 8000 miles. Just started to occur yesterday. Thanks for posting your experience.
    14. Member
      Oct 1st, 2007
      Atlanta
      '13 GLI Autobahn
      04-18-2013 01:11 AM #14
      Most definitely. Anecdotally, they seem to have far fewer problems. You'd expect the opposite, but it really is an impressive piece of engineering.
    15. Member
      Dec 8th, 2012
      Ohio, USA
      2013 Jetta GLI DSG
      04-18-2013 10:34 AM #15
      Quote Originally Posted by erick295 View Post
      And if you are concerned, there's always warranty (or extended warranty). And then what I'm doing: Putting a small bit of money away every month for the eventual (expensive) clutchpack replacement. (In addition to what I'm putting away to pay for tires/etc.)
    16. Member
      Oct 1st, 2007
      Atlanta
      '13 GLI Autobahn
      04-18-2013 12:56 PM #16
      Quote Originally Posted by araemo View Post
      Theoretically the clutches aren't wear items since they're wet. The chances of you having to replace them are probably pretty low.
    17. Member mattng06's Avatar
      Jan 20th, 2012
      Lake St Louis, MO
      04-18-2013 01:07 PM #17
      Lets hope so.. Im not going to get a tune ever, so i should be fine as long as i keep up on the DSG maintenance. Knock on wood!!
      14.40@96.19
    18. Member
      Dec 8th, 2012
      Ohio, USA
      2013 Jetta GLI DSG
      04-18-2013 04:10 PM #18
      That isn't what I was finding in my pre-purchase investigation, and reading technical info about the DSG seems to back that up - the mechatronics adapts to the amount of slip you're getting, but it'll only adapt so much, and when you hit that point and get more slip, it (the clutchpack) needs to be replaced.
      That's a high-mileage item, definitely, but I kept my previous car 145k miles, so it's a realistic concern.
    19. Member
      Aug 6th, 2004
      Maryland
      2015 S4
      06-28-2013 01:31 PM #19
      I know this post is old, but I am experiencing the same issue with the same symptoms. This happened to me suddenly after I accelerated out of first quickly to merge onto oncoming traffic. I am at 22k miles, 6-spd, '12 model, and the dealer mentions they have seen this on others with the same year.
      They were trying to tell me that warranty will not cover it and they will have to see once they get inside the transmission.
    20. Member
      Jul 25th, 2010
      Atlanta
      13.5 VW GLI DSG, Old Pick-Up, & Old Motorcycle
      06-28-2013 05:10 PM #20
      For what it's worth... Sounds identical to what happened to me. It ended up being a shattered pressure plate.
      http://forums.vwvortex.com/showthrea...tch-Issues-GLI
    21. Member euro2nur's Avatar
      Apr 23rd, 2006
      PINES,FL /QUEENS,NY
      mk3 golf(sold),mk3 vr6 Gti(sold),mk3 vr6 Jetta(sold)mk6 GLI
      06-28-2013 07:18 PM #21
      Quote Originally Posted by sh{}e View Post
      tell them to **** off. this is becoming a common issue. only thing that is not covered under warranty in your transmission is your clutch disk, which should not be the problem. this is mechanical issue in the transmission. call vwoa and let them know about your issue.
      BROWARD COUNTY
    22. Member euro2nur's Avatar
      Apr 23rd, 2006
      PINES,FL /QUEENS,NY
      06-28-2013 07:20 PM #22
      Same thing I noticed
      BROWARD COUNTY
    23. Member
      Jan 30th, 2011
      at a blacksite
      06-28-2013 10:24 PM #23
      Someone else posted on here recently that their clutch failed on them around 17k. I'm curious if he was having the same issue and just drove it a bit too long. I've recently noticed a pulsing in my clutch pedal or maybe it is better described as a rhythmic vibration...
    24. Member goforit2007's Avatar
      Mar 22nd, 2007
      IL (Chicagoland)
      2012 4dr Base Rising Blue Golf R
      05-15-2014 03:50 PM #24
      May 2014 and 13,812 miles on our 2012 GLI and ours is at VW right now getting the upgraded stronger clutch kit (thankfully plenty of warranty left and this is 100% covered under warranty on our 100% stock GLI)
      Our story is much like the OP. A normal drive home from work... at a stoplight and suddenly it just wouldn't go into gear when the light turned green... My husband was able to barely get it into 2nd and then while rolling was able to get into 3rd and was able to nurse it over to our local VW dealer less than a mile away. Its getting the updated clutch installed as I type this and hopefully will be ready to pick up tomorrow so we have the car back before the weekend!
      EDIT: I was told ours was a shattered pressure plate as well FWIW
      -2012 Rising Blue Base 4dr 2012 R (current daily driver!)
      -2012 Jetta GLI (his daily - yes I'm a girl)
      -1994 Sentra SE-R (PTE track beast)
      -1995 Infiniti G20 (NASA PTF/TTF track rat) and 2012 NASA Nationals PTF Champion!
    25. Member REDGLI2012's Avatar
      Mar 25th, 2012
      West Islip,NY
      BAGGED AND TUNED SORORITY GIRLS CAR
      05-15-2014 04:13 PM #25
      My shop has replaced two clutches with both bad pressure plates on a TSI Beetle and a stock 2012 GLI. This is the weak point of these transmissions by far. The flywheel itself can take 300whp+ no problem but the clutch/pressure plate is very weak for even stock power levels. Needless to say i am stage 2 GIAC w/ full bolt ons and i just did a stage 2 daily southbend clutch in april and it was well worth it stock or not. Food for thought for those wondering what is the trouble with these manual gearboxes as far as the clutches go
