Page 4 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 106 to 140 of 244
Thread: Post your verified spring rates here
  1. 05-21-2003 02:13 PM #106
    The konis are set at 3/5 front and 2/5 rear, and the springs are the vogtland sport springs which can be found earlier in this post. They're 200-300lb./in. front and 170-230lb./in. rear. Assisting them are polyu. LCA bushings and a lower front tie bar.
  2. Member sccaITA16V's Avatar
    Nov 5th, 2002
    Sterling VA
    13 GTi Autobahn, 04 Jetta 1.8t wgn, 88 Scirocco 16v
    05-21-2003 07:48 PM #107
    Ha Ha, I finally won something!! I got you all beat. Shine racing only coilovers with 600 front and 400 rear. And I shamelessly endorse Mr. Shines products, professionalism and knowledge of our endearing VW cars.
    Quote, originally posted by Stephane Trahan »
    All professionnaly race fwd cars in NA usually run a front to rear factor of 2-3 to 2-5 rate factor...my cars use 800f and 1200r...most acuras (realtime and all) range from 750f-1100r to 1000f to 3000r.
    [Modified by Stephane Trahan, 7:07 AM 4-8-2003]
    Also wanted to clarify why this set-up won't work on a VW. Hondas and Acuras have the spring/coil over located only half-way down the length of the rear control arm reducing its "leverage" acting on the rear suspension, therefore it needs almost TWICE the rear spring rate as a VW to achieve about the same effective rate. Make sense to you?
    have fun and play safe
  3. 05-21-2003 09:53 PM #108
    Shine Racing RealStreet
    1988 Jetta GLI 16V
    Linear
    200lbs fr
    120lbs rr
    +Bilstein Sports = perfect for "agressive" street driving.
  4. Member TarmacSpecial's Avatar
    Mar 5th, 2003
    Los Angeles, CA
    2010 VW GTI
    05-22-2003 01:31 AM #109
    So, any A1 spring rates?
    Here's my setup....
    I'm running Ground Control/Eibach at 300F, and 200R, with 22mmF and 28mmR solid sway bars. Bilstein sport dampers (came with the car). The car is setup arms level with a very slight droop in the back. I also "sag balanced" the suspension by taking ride height measurements before and while I was in the car, and then adjusting the perches so that it would sit equally L/R when I was in it. It's crude but better than nothing.
    I am pretty happy with it so far.
    Arik
    2010 Volkswagen GTI - Pic
    2009 Yamaha FZ1 - Pic
    2000 Yamaha YZ426F - Pic
  5. 05-22-2003 01:14 PM #110
    I was a SRSVW this week
    A great atmosphere to hang out and ask alot of questions:
    The front Eibach's pros for 2001 B5 were 290 as measured by Dick
    about 27% stiffer than the stock front springs
    What a difference
    The interesting thing is the previous b5 guy who had a suspension upgrade at Shine
    had much stiffer stock springs to start with. (i think i have this right)
    but his Eibach's were also 290
    good QC from Eibach IMHO
    I can't remember the rear numbers....
    I Also got the Shine Bar -The passat does almost no"plowing" in the turns
  6. 05-26-2003 10:33 AM #111
    KW published front coil over spring rates
    Available rates, first number = rate in N/mm; second number =spring length in mm.
    50-170 =285 lb/inch
    60-170 =342 lb/inch
    70-170 =400 lb/inch these are the ones mine came with for 4cyl mk4 G/J
    80-170 =457 lb/inch
    90-170 =514 lb inch
    100-170 =571 lb/inch
    110-170 =628 lb/inch
    120-170 =685 lb/inch
    What spring number (xx-170)do the ones for the 6cyl mk4 have ?
  7. 06-01-2003 01:56 PM #112
    okay..it is becoming increasingly difficult to decipher posted spring rates in the quagmire of aimless chatting.....so can somebody please delineate these spring rates for me: Neuspeed race springs for mk3 VR6 and the Ground Control basic sleeve-over kit for mk3 VR6?
    Thank you!
    Modified by woodyVR6 at 6:58 PM 6-1-2003
  8. Member melman8r's Avatar
    Mar 18th, 2002
    2011 2dr. GTI Autobahn 6 spd. CSG
    06-01-2003 03:43 PM #113
    alexb,
    Where's the H&R rates??
  9. 06-27-2003 11:52 AM #114
    bringing it back from archives...
  10. Banned
    Nov 30th, 2001
    07-03-2003 02:41 AM #115
  11. 07-03-2003 03:39 AM #116
    Quote, originally posted by melman8r »
    alexb,
    Well, I was away for a month (Europe) and didn't visit Vortex. I've been after getting the H&R rates, but was not successfull so far. I've been told that they're not going to publish their rates so other companies won't copy their rates. I've called and followed at every level. The closest thing I could get was that Nuespeed used to have H&R as supplier and their springs are close to what they had before with H&R. H&R supposed to be a little softer than Nuespeed, so Nuespeed rates give or take a few.
  12. 07-03-2003 03:27 PM #117
    emailed APR for rates on their RollControl springs.
    35% stiffer than stock 337 springs, they don't release specific rates.
    According to Jeremy, HR springs are slightly stiffer than RollControls. Linear rate for VW applications.
    so far, I'm torn between HR Sport, RollControl, and Vogtland...
    Modified by genxguy at 5:36 PM 7-3-2003
  13. 07-10-2003 08:36 PM #118
    The rates for the Vogtland that you quoted on pg 1, are they for the Competition springs or the Red Violet springs? Thanks.
  14. Member MikekiM's Avatar
    Aug 21st, 2001
    San Diego
    09 Jetta Sportwagon
    07-11-2003 01:30 AM #119
    For the Vogtland Sports. Competitions are about another 10-20% stiffer.
  15. 07-11-2003 02:30 AM #120
    skunk2 coilovers for mk2
    400# all the way around..
    this is the info they gave me on the fone when i called them
  16. 07-11-2003 06:26 PM #121
    Copy H&R spring rates!! That is one of the funniest things I have ever heard!
    The reason they dont quote rates is largely because the salesmen dont know and cant measure them.They dont have an engineer in this country!!! It is a simple thing to measure springs.Even the supposed progressives.It is H&Rs choice to not release the numbers to the consumer. I dont know about everyone else,but I wont do business with a company that wont support their product.You may if you choose,This is America after all. I have most H&R rates because I have taken the time to measure them. None were even close to the claimed rates when I was lucky enough to get them.If you want to know the rates (the real rates) you have to measure and test them.I will test them for you if you want to bring them by or send them.I dont keep my rates secret because you cant make a reasonable decision without the information.We should all put pressure on all these people that think their springs are magic and the rate is as secret as the formula for CocaCola
    This is just an absurd situation!! I can assure you that no racing team buys springs without all the pertinent engineering data.It just isnt done!!Dont settle for this BULL.
    Just my rant (I am worse with age) Dick Shine
  17. 08-02-2003 05:05 PM #122
    Dick's right, most people who sell their products (H+R) have no idea what their doing. They have no idea what their trying to push .... it sayys race so it must handle better .......... I have ridden in a SRS MK IV setup and it was simply awesome. 2x better than my previous Neuspeed sport / Bilstein 28mm RSB setup .... But I couldn't cope with the non-existant drop and yes stiff setup.... So now i'm on PSS 9's and about the same level of the Shine real street with a excessive 1.75" Drop and no RSB .... Just as stiff. Considering adding a Shine rear O bar but that's another subject, Dick ?
    2002.5 24v GTI VR6 HPA FT400 Turbo.(Gone)
    2008 Nissan Rogue SL AWD.(Daily)
    2008 Honda Civic DX-G (Beater)
    1992 GTI VR6, eip turbo, C2.42#, T04 60 Trim .68, Caged. (Play Car)
  18. 08-02-2003 07:13 PM #123
    O man don't dare call Dick Shines rear bar an O bar...they are similar but NOT near the same quality. better delete that part of your post if you. FWIW he's not to fond of the pss-9 as their heighest setting is still 1" drop, and as us Shine disciples know is to low for an mk4...
  19. 08-02-2003 10:57 PM #124
    As I stated, I couldn't live with the non existant drop of the SRS kit, although I could live with the awesome handling of it, Yes my car is a compromise between looks and performance, I'm the first to admit to it. I'm not setup properly ... Im also running a purely asthetitcs wheel tire combo which does not help my handling situation 235/45/17 front and 245/40/17 on 8.5" and 10" Rims. So I'm screwed from the get-go. Sorry about the O bar comment Dick, I will be in touch with you concerning your RSB?, Soon.
  20. 08-03-2003 04:10 PM #125
    Darren You seem like a nice guy so I will let it slide! Just kidding. I get really incensed when I hear my product mentioned in the same sentence as that inferior knockoff. It sounds like you did your homework and ended up with something that meets all of your needs! Great,that is what this is all about! I know that my kit isnt for everyone and talk as many people out of it as ones I sell. Thats OK.
    Dick Shine
  21. Member
    Oct 12th, 2001
    Redmond, WA
    08-04-2003 02:18 AM #126
    Manufacturer: Shine Racing Services (Real Street)
    Vehicle: MKII Golf 4-cylinder models
    Spring Type: Linear
    FT Rate: 300
    RR Rate: 250
    I love my coilovers (for a MKIII VR6 I believe) and my rear bar (with the front removed).
    That and the manual steering rack was the best thing I have done to my car (yet).
    Thank you Dick!!!!!
  22. 08-04-2003 11:10 AM #127
    Quote, originally posted by alexb75 »
    Maybe I'm just a bit naive but that doesn't make any sense to me. Couldn't competitors interested in copying their setup simply measure the springs themselves...?
  23. 08-04-2003 06:31 PM #128
    Exactly!!!
    Dick Shine
  24. 08-04-2003 09:11 PM #129
    -I've been after getting the H&R rates, but was not successfull so far. I've been told that they're not going to publish their rates so other companies won't copy their rates. -
    I purchased H&R O.E. sports along with Koni yellows for my A2 jetta. I really liked the improved ride, but when I wanted to start to "fine tune" the set up, I tried to get the rates from H&R and they told me flat out that they don't release that information because it's proprietary. I could've sent the springs out to be "dyno-ed", but that would've left the car not running for 2 weeks, plus it would've cost $$ for shipping and testing. I got so dissapointed, I just sold the entire set-up. I'll probably attempt another suspension for my ' 92 jetta, but I can assure you that H&R WON'T be getting any more of my $$.
  25. 08-04-2003 09:29 PM #130
    This is way too funny Like someone sells you a tire, but does not tell you what is the max load and how are they rated and what's the max PSI, the tread ware and traction ......... just tells you this is 205-16 tire, go use it, it will fit your rims....... And do not dare to ask for any data, because it is proprietary!
    I actually almost can't believe all this, because H&R is so famous and old company, started by these two (pretty old now) gentlemen, who look like people who would know that publishing their spring rates would not harm in any way their established business.
  26. Banned
    Aug 29th, 2001
    08-11-2003 01:59 PM #131
    Neuspeed Sofsport/Softsport for MkIV
    Golf/GTI 1.8T/VR6:
    - Front: 200 lbs/inch, linear
    - Rear: 160 lbs/inch, linear
    Jetta and 2.0L are probably the same rates, but this is unconfirmed.
    According to Neuspeed, the front springs are longer on the VR6 to account for the extra engine weight, but the spring rates are the same.
    These springs appear to be "progressive" in the box, but when installed, the "progressive" coils bind up to a solid block under the weight of the car. They are there to prevent the spring from falling out of the perch at full suspension droop.
  27. 08-11-2003 04:40 PM #132
    Quote, originally posted by phatvw »
    Golf/GTI 1.8T/VR6:
    Shouldn't that be 220 lbs for the fronts?
  28. Banned
    Aug 29th, 2001
    08-13-2003 12:53 AM #133
    Quote, originally posted by dmkozak »
    According to Greg at Neuspeed, it is 200lbs not 220.
  29. 08-13-2003 01:41 AM #134
    Sorry, that's got to be a typo on Greg's part. I've exchanged lots of e-mails with Greg, and both he and all of Neuspeed's literature say SofSports fronts are 220 lb rated springs.
    P.S. 220/160 retains the Factory fr/rr spring rate ratio. Neuspeed is not known for changing these ratios. Otherwise, Neuspeed would be stiffening the rear proportionately more than the fronts, a la Shine.
    Modified by dmkozak at 6:43 AM 8-13-2003
  30. Banned
    Aug 29th, 2001
    08-13-2003 05:06 AM #135
    Oh yeah thats right, he did mention preserving the front/rear ratio so it probably was a typo.
  31. 08-13-2003 12:15 PM #136
    any confirmed spring rated for an A2 16v gti. (some companies offer diff. springs for 8 vs 16v)
    I would be interested in:
    H&R Sports
    H&R Race
    NSpd Sports
    NSpd Race
    RPI (by susp. tech.)
    RPI (by H&R)
    Eibach
    Shines varieties
    Bilstein BTS kit springs
    Weitec
    Apex
    thanks
  32. 08-26-2003 05:48 PM #137
    Bump
  33. 08-27-2003 07:35 AM #138
    bump..very interesting stuff!
    i wonder why weitec wont give out spring rates
  34. Member
    Aug 9th, 2001
    3rd gen milk carton
    08-27-2003 05:03 PM #139
    if anyone has KW var2 rates for mark3's id like that too. ive heard wietec and kw are one in the same, so for either, thanks in advance
  35. Member
    Jan 3rd, 2000
    Oakland, CA
    2012 c350, 2007 LBP S2000, 96 gti vr6 turbo
    08-28-2003 02:20 AM #140
    My new H&R RSS ClubSport coils : 800#f 400#r
    Should be interesting when they go in this weekend.
