Page 7 of 7 FirstFirst ... 3 4 5 6 7
Results 211 to 244 of 244
Thread: Post your verified spring rates here
  1. Member bmxracerx's Avatar
    Aug 28th, 2006
    York, PA
    2002.5 Jetta GLI 24v
    02-18-2007 12:30 AM #211
    This is great info but is it still current? This post was from 02.
    I'm just trying to get a feel for if I change my H&R Sport's out for the Neuspeed Sport's, will the ride be the same? I love the H&R's but hate the rake. 1.5 F-1.4 R. The Neuspeed Sports are 1.5 F&R. BTW, I have Koni shocks.
    Quote, originally posted by darrenewest »
    MK IV VR6 Neuspeed Sport: 220(5) Front and 160 Rear
    MK IV VR6 H+R Sport are 228 Front and 160 Rear
    I did a Little research and a whole lot of E-mailing. RPI Said there's were almost identical too Neuspeed's, although 10lb stiffer rear. I Emailed Neuspeed and they emailed the rates back too me the same day. H+R's I got from Denon, and are almost identical too Neuspeed's because they (H+R) use to Manufacture for them, but no longer. Neuspeed used their rates and found another manufacture .... If not totally correct let me know and I'll edit them, though I'm 98% Sure. Happy hunting, The Shine's are PERFECTLY matched to Bilstein damper's valving from what I can gather. I need a life. - Darren
    For the comparison of the H&R Sport rears and the Neuspeed Sport rears, can someone verify is these are still correct?
    Modified by bmxracerx at 12:50 AM 2-18-2007
  2. Member bmxracerx's Avatar
    Aug 28th, 2006
    York, PA
    02-18-2007 02:42 PM #212
    bump for input
  3. 02-21-2007 01:26 PM #213
    anyone know the rates for the weitec TX coilovers rapid parts sells for the mk3 vr6?
  4. 02-21-2007 08:18 PM #214
    Quote, originally posted by bmxracerx »
    I've never seen any hard data to contradict it, and pyce measured the H&R OE Sport to have a working front rate in the 210-220 range, so IMHO the rates are reasonable.
  5. Member VWn00b's Avatar
    Mar 4th, 2005
    Dallas, Tx
    1997 Jetta
    02-23-2007 12:21 AM #215
    Just read through the whole thread, but might have missed it. Anyone have the rates for the H&R RSS mk3 coilovers? Also, does anyone here have good experience with this kit?
  6. 03-29-2007 10:01 AM #216
    bump
    us mk5 gti, 133/189 f/r measured by shine
  7. Member sprocket007's Avatar
    Oct 14th, 2002
    Alberta, Canada
    '92Passat G60 Syncro, '90 G60 Corrado, '89 Cabriolet, '86 Jetta Coupe, '81 Rabbit LS '74 Westfalia.
    05-07-2007 04:30 AM #217
    hmm, did not see it in there...lots of info tho...pages
    Wade
    BSc.N, EMS/FIRE
  8. Member G60ING's Avatar
    Jun 27th, 2000
    Northern MX
    TDI Corrado & Honda Refrig
    05-07-2007 11:42 AM #218
    I was looking for the spring rates on my Corrado VR6 H&R coilovers. It looks like they have.
    Fronts: 48 03 452-2/1 180lb springs
    Rears: 48 53 452-2/1 300lb springs
    here is a PDF if people want to know where I got the specs:
    http://www.h-r.com/katalog_download_de/VW.pdf
  9. 06-17-2007 04:41 PM #219
    Would be nice to know if Shine also measured theeuropean spec mk5 GTI springs !
  10. 08-01-2007 12:47 PM #220
    bump
  11. 08-24-2007 02:55 PM #221
    Anybody knows what the rates are for the Koni coilover springs?
    They have some documentation online but is in freaking german. Can anyone translate it?
    http://88.198.54.215/pdf/1150-5009-tuv.pdf
    It's at about the midle. Thanks a lot.
    Aka Doc_Oc on tdiclub.com
  12. 08-25-2007 05:09 PM #222
    don't think it says anything about rates just max loads
    http://www.google.com/translate_t
    good luck
    Modified by tojones at 4:18 PM 8-25-2007
    1.8T/VR6 Oxygen Sensor FOR SALE
    The Elite 24v VR6 Club: Member #225
    www.1100thismonth.com Call & Learn How
  13. 08-25-2007 10:10 PM #223
    Quote, originally posted by ovlaicu »
    Koni CO 1150-5048 (4-cyl MkIV)
    174lb/in Front
    214-236lb/in Rear (progressive)
    Koni CO 1150-5048-1 (VR6 MkIV)
    280lb/in Front
    Number came from the beginning of this very thread
    Modified by wolfpuppy at 10:11 PM 8-25-2007
    Modified by wolfpuppy at 10:12 PM 8-25-2007
  14. 08-25-2007 11:27 PM #224
    Quote, originally posted by G60ING »
    The way H&R lists springs is "length-rate"
    The 180-070 in the front is the length of the spring in milimeters, 180 and the rate 070. The 300-050 for the rear is the spring lenght in milimeters, 300, and the rate 050.
    The rates are listed in newtons/mm of travel and can be converted to lbs/inch as follows, 1 newton / millimeter = 5.71014715 pounds force / inch.
    So 70N/mm = 399.7 lbf/in
    and 50N/mm = 285.5 lbf/in
  15. 08-31-2007 08:49 AM #225
    Anyone have rates for the GLI mk4 2004.5 springs?
  16. 09-11-2007 08:04 AM #226
    check the faq
  17. Member G60ING's Avatar
    Jun 27th, 2000
    Northern MX
    09-12-2007 05:22 PM #227
    Quote, originally posted by briang »
    Thanks you
  18. Member Top-NouchVR6's Avatar
    Jun 5th, 2007
    NY/ VA
    94 aba sold, 96 12v sold, 04 24v current
    09-23-2007 01:39 PM #228
    does any one know the nuespeed sport and race spring rates for a mrk3 vr6
    and did you guys have the same problem getting nuespeed rates as you did with H&R thanks.
    and are they progressive or linear
    Modified by Top-NouchVR6 at 7:16 PM 9-23-2007
  19. Member Dick Furious's Avatar
    Dec 13th, 2001
    Virginia Beach, VA
    11-20-2007 05:12 PM #229
    Manufacturer: V-Maxx Coilovers
    Vehicle: Mk3 VR6
    Spring Type: Linear
    FT Rate: Main 350, Tender 115
    RR Rate: Main 350, Tender 115
  20. Member NS01GTI's Avatar
    Jan 30th, 2005
    Canada eh
    2012 VW GLI K04
    01-17-2008 09:35 PM #230
    Sorry to bring this back from the dead, and I didn't go through every page, but I thought that Eibach prokit springs were progressive, whereas on the first page it indicates that they're linear.
    Anyone?
    2012 GLI DSG
    APR K04 - Carbonio intake - BB 3" Catted DP - APR FMIC - HPA SHS Coils
  21. Member Serpent7's Avatar
    Dec 24th, 2003
    Temple Hills, MD.
    Horse and saddle
    01-28-2008 07:57 AM #231
    Car: 87 VW Cabriolet w/ 16v conv.
    Manufacture of springs: Ebach coilover springs
    Struts and shocks: Bielstien
    Coilovers: Ground control
    Swaybars: 22mm front, 25mm rear (aftermarket forgot brand "red")
    Spring rate front: 375lbs.
    Spring rate rear: 325lbs.
    Aftermarket wheels Borbet type E wheels with 195-40-16 hit the coilovers so I need wheel spacer for them, so temp. running my factory 13" rims, 175-70-13.
    Rides somewhat bouncy to me, just installed yesterday and its a daily driver. Handles very well, but I don't have much to compare it too.
    Modified by Serpent7 at 10:02 PM 1-29-2008
    The best wife in the world...
    2008 Audi A4. 2000 BMW M5.
    1996 GSX-R 1100. 1979 VW Transporter.
    1979 Kawasaki KZ1000st.
  22. 11-05-2008 05:59 PM #232
    Since I didn't see any off-the-shelf springs for A1's in these 7 pages, I made some phone calls....
    Neuspeed Sport Springs (55.10.01)
    Front = 140 - 200 lbs/in
    Rear = 120 - 150 lbs/in
    Neuspeed Race Springs (55.10.05) <--- No longer produced
    Front = 275 - 300 lbs/in
    Rear = 270 lbs/in
    H&R Sport Springs (54740)
    *Data not released*
    H&R Race Springs (54740-88)
    Front = 400 lbs/in
    Rear = 285 lbs/in
    Modified by DTDSasquatch at 6:06 PM 11-5-2008
  23. 11-09-2008 12:36 AM #233
    Megan Racing Lowering Springs Volkswagen Golf / Golf GTI 1999-2005
    Megan Racing Performance Lowering Spring Feature Summary:
    - Aggressive lowering height designed to provide a lowered racecar look
    - Lower profile for better handling performance
    - Minimal sagging
    - Lowering heights and spring rates matched specifically to each car
    - Made from SAE-9254 cold-wounded steel for better strength and durability.
    Reference: Megan Racing lowering spring, Megan Racing performance springs, Megan race springs
    Product Notes:
    FRONT REAR
    Spring Rate (lbs/inch) 350 250
    Max Lowering Height (inch) 1.75" 1.75"
  24. 09-13-2009 04:49 PM #234
    Hey man u seem to know your stuff really well. I was hoping you could help me w/a question. I have a 2000 GTI (1.8T) that i bought used, already dropped (not sure how much of a drop) on 225/40/18's. I need to get either shocks or both shocks & springs (i think the springs are still good) & i want stiffer than facory (not much room b/w tire & wheel well). What name & shock rate should i look for?
  25. 04-13-2010 02:22 PM #235
    vuu, what do you use for shocks? I am creating a SOLO car and was wondering about spring rate. Most coilovers use a 35-336 F and a 285-280 R spring rate. I thought this would be good with sufficient bar force and less compliant busings.
    The problem is with more force there is more wear...do you have addditional welds for the suspension supports...control arm, strut mount, rear bushing mounts...etc?
  26. Member punchbug's Avatar
    Jul 15th, 2000
    Ontario's deep south
    Assorted German Scrapmetal and a really old aircooled trike project
    06-29-2010 07:49 AM #236
    Is trhere any way this could at least be subdivided by chassis? It's frustrating trying to wade through it in this format. I've got an A1 on H&R sports/Koni yellows and want something that will actually hold the back end up. Problem is I'm TRYING to find out the rate of what I HAVE. FRUSTRATING!!!!
    I cannot believe that there is no exhaustive listing of spring rates for our cars.
  27. 02-04-2011 01:03 AM #237
    does anyone have the rates for MK4 B&G RS2's??
  28. Member spoon!'s Avatar
    Sep 1st, 2005
    Monterey, CA
    '92 Jetta | '69 T3 Squareback
    05-16-2011 03:18 PM #238
    Quote Originally Posted by punchbug View Post
    It's not printed on your spring? That's weird.
  29. Member
    Jan 26th, 2009
    East bound and down
    98Golf4door, 83Rabbit4door
    11-20-2011 10:04 AM #239
    FK-powertech or silverline coilover main rates?? thanks
    Manila Beige mk1
  30. Member
    Nov 13th, 2009
    Current -2002 225 TT, 64 VW Resto-Mod 150hp, Former- 97 & 02 Mustang GT, 93 JDM Engined MX6 LS
    02-24-2012 07:19 PM #240
    Quote Originally Posted by darrenewest View Post
    MK IV VR6 RPI Are 225 Front and 170 Rear
    MK IV VR6 Neuspeed Race 280 Front and 220 Rear
    MK IV H+R Race are the same as Neuspeed Race. +/- 5 pounds.
    MK IV Bilstein PSS9 Coilover 350 Front and 300 rear .... ouch ... (I have these)
    I have the Neuspeeds and they are Progressive rate and you show a Linear number? One thing that is a concern is that just sitting the dead coils are laying on top of each other with no gap. I am assuming they work on rebound and as the spring come down? It just looks as if there is not much left in the range of motion.
  31. Member dainese's Avatar
    Jul 23rd, 2009
    Sydney, Australia
    2004 VW Golf R32
    02-24-2012 08:15 PM #241
    Quote Originally Posted by Arnolds64 View Post
    That's like the konis then. Springs are binder together because of lack of travel from either ride height or design.
    It really means the initial range of progressive rates are not available.
    Harsh ride?
    Sent from my GT-I9100
    2004 MkIV R32 Golf
    APR Tune - Carbonio CAI - HPA SHS - Dieselgeek SS - Custom Catback Exhaust
    http://www.youtube.com/user/dainese01
    FS: NEW Weitec Ultra GT Springs & Shocks for 2002-2009 VW 9N Polo
  32. Member dieselpower04's Avatar
    Jan 12th, 2008
    Mid-cost Maine
    '04 Golf TDI
    08-18-2012 10:24 PM #242
    Quote Originally Posted by 9VW23yrs View Post
    KW published front coil over spring rates
    Available rates, first number = rate in N/mm; second number =spring length in mm.
    50-170 =285 lb/inch
    60-170 =342 lb/inch
    70-170 =400 lb/inch these are the ones mine came with for 4cyl mk4 G/J
    80-170 =457 lb/inch
    90-170 =514 lb inch
    100-170 =571 lb/inch
    110-170 =628 lb/inch
    120-170 =685 lb/inch
    What spring number (xx-170)do the ones for the 6cyl mk4 have ?
    I currently have the 80-170 springs on my KW V2's on my diesel, very stiff. Going to put the 350 lb/in springs from my Racelands in this weekend to see if it rides smoother
    Diesel-Dub Club #36 TDI Build Thread Addicted to ft-lbs
    My Golf TDI
  33. Member J.Owen's Avatar
    May 31st, 2001
    Merica
    '05 A4, '07 Jetta, '02 Outback
    08-20-2012 04:13 PM #243
    Since this is alive again.
    ST Coilovers for b6/b7 Audi A4: 690# f. / Prog. r.
    BlownEuros.com
    Expenses in F1 have gone down since the 1960s because teams don't need an extra pit crew to help the driver carry around his balls when he is not in the car.
  34. 04-20-2013 03:28 PM #244
    Not sure this is really the place for it, but it took me more than 6 hrs to find the right springs for my golf. So if i can save someone else the ball ache thats good for me.
    I have a golf 4, uk spec, 02, PD150, with full GTi level susp as standard.
    this runs the
    1j0 411 105 ce on the front
    (2 blue 3 white, 2B 3W)
    GSF stock an after market at 1/3 of the cost of VW, its a Kilen spring (made by GKN), Pt# 25076
    same spring as the 2.8 V6 4M
    hope this helps someone in cyber land
