Page 4 of 9 FirstFirst 1 2 3 4 5 6 7 8 ... LastLast
Results 106 to 140 of 283
Thread: 16v FAQ: if you are new to the 16v forum, this is the thread for you
  1. Geriatric Member VDub2625's Avatar
    Jan 3rd, 2003
    Fall River, MA
    90 Jetta GLI 16v, 99.5 Cabrio Highline
    01-09-2006 09:27 PM #106
    They are the same if worked a bit. otherwise, one or the other has MINOR flow imporvements on the intake or exhaust valves. But just grab any ol' head and have it ported and such. They will both come out the same.
    A2Resource
  2. Member Motorwerks's Avatar
    Nov 6th, 2002
    Roseville, CA
    07 F150
    01-15-2006 01:14 PM #107
    Im sure its been asked a dozen times but what the hell is the thing that goes around my plug wire looks like some kind of pick up or something
    Maybe we should chug on over to mamby pamby land where maybe we can find some self confidence for you, you jack wagon!- R. Lee Ermey
  3. Geriatric Member VDub2625's Avatar
    Jan 3rd, 2003
    Fall River, MA
    01-15-2006 08:11 PM #108
    it's so you can pull it out easily
    A2Resource
  4. Geriatric Member VDub2625's Avatar
    Jan 3rd, 2003
    Fall River, MA
    01-16-2006 01:13 AM #109
    Pic?
    Never heard of that. It sounds like it could be some sort of RF blocker, if it goes to ground...
    A2Resource
  5. Member Motorwerks's Avatar
    Nov 6th, 2002
    Roseville, CA
    07 F150
    01-16-2006 05:56 AM #110
    Found it in bently FINALLY, its an igniton firing point reference sender
  6. 01-23-2006 01:22 PM #111
    Hi there
    i had a problem today and the speedo and the water temp gauge just died on the motorway and ever since that the water temp guage keeps going up and down
    it is a 1.6 16V golf mk4 engin code AZD
    what could be the problem?????????
    ANDY
  7. 01-24-2006 10:20 AM #112
    Hey, are any of you guys replacing your 9a rods when your building boosted motors?
  8. Member vee_dubb_gti's Avatar
    Nov 17th, 2004
    Chicago, IL.
    90 Jetta Coupe 1.8t
    01-24-2006 09:30 PM #113
    Quote, originally posted by Jett’in »
    A G60 downpipe will fit a 16v.
    I bought one and it bolts up just the same.
    I am adding this b/c if you have a cracked and/or leaking downpipe, the G60 ones you will find for sale have lower mileage on them and are usually in much better condition than the used 16v ones.
    Good luck!
    you sure about that? i thought that the G60 was an 8v head and the exhaust studs were stright up and down? the 16v are angled.
    16v(they might angle the other way)
    G60(like 8v but has the 4-2-1)
    Modified by vee_dubb_gti at 6:31 PM 1-24-2006
    ........... \_________
    ..... ,___/ /___l ___\\_____
    ...... l________l____/_____l
    .......\__( o )_______( o )__/
  9. Member Motorwerks's Avatar
    Nov 6th, 2002
    Roseville, CA
    07 F150
    01-24-2006 10:53 PM #114
    Quote, originally posted by vee_dubb_gti »
    G60=8v head, to the power of 16v down pipe will not work.
  10. Geriatric Member VDub2625's Avatar
    Jan 3rd, 2003
    Fall River, MA
    01-25-2006 08:53 AM #115
    He said downpipe, not exhaust manifold
    A2Resource
  11. 03-12-2006 09:24 PM #116
    i am replacing my head and there is a plug in one of the holes i was transfering the sensers to a was woundering what i would do if i left it out. i beleave it is the thurmo time switch from the earler pictures.
  12. Member KingofNod's Avatar
    Jun 28th, 2003
    Baltimore
    1986 Toyota Corolla
    05-03-2006 04:56 PM #117
    Can someone tell me if a 9A tranny (I think stock 8v tranny) will bolt up to the 9A motor? If not, how can it be made to fit? Aren't the clutches different? How is the gearing on the 9A compare to the gearing on the 2Y?
  13. Geriatric Member VDub2625's Avatar
    Jan 3rd, 2003
    Fall River, MA
    05-03-2006 06:32 PM #118
    Quote, originally posted by KingofNod »
    I have a 9a on my PL. It will bolt up, but you have to use an 8v clutch (you can keep he 16v pressure plate). THe gearing is identical except for 5th, which is .89 in the 9a and .91 in the 2y (about a 2mph or 100rpm difference at the same speed).
    A2Resource
  14. 05-13-2006 11:31 PM #119
    I am currently in the process of finishing up a rebuild on a 9a 2.0L 16v, and I have run into a sticking issue. I CAN NOT manually crank over the engine when I have a wrench on the crank bolt... Did a COMPLETE rebuild and everything was within specifications.
    If anyone has any information about this I would much appreciate some insight. Is this normal? Or, is this something to worry about?
    - problem is fixed. turned out that the lubrication we used in the head had dried up a little bit...so we disassembled and reassembled the head with new assembly lube.
    Modified by MoGtheMooGle at 7:40 AM 5-15-2006
  15. Member anthegreat1's Avatar
    May 27th, 2004
    huntsville, al
    06-13-2006 09:06 PM #120
    Your car sucks, and we have a team of experts working around he clock to prove it.
  16. 06-18-2006 09:19 AM #121
    Disregard my idiocy....that was an 8valve configuration I mentioned...I'll re-post in the appropriate forum topic.
    Modified by VWplaything at 1:59 PM 6-21-2006
  17. Member MidnightGLI's Avatar
    Dec 15th, 2001
    East Mesa, AZ
    08 GTI
    08-17-2006 12:01 AM #122
    this is my belated contribution to the 16v community of the vortex, nothing scientific but it gives a visual representation of the difference between the stock intake came and the exhaust swapped cam.
  18. Member Dyelon's Avatar
    Jul 31st, 2006
    Port Orchard
    96' GTI VR, 02' GTI 1.8t
    09-01-2006 04:14 AM #123
    Does anyone have any info on building a 16vT?
    And I have a 02A Tranny for my 9A block how do i tell if its from a G60 or not?
    And I would like an opinion on whether or not I should go with a cable clutch or a hydraulic clutch?
    Boats and Hos
  19. 10-22-2006 04:29 PM #124
    I want to replace my spark plugs on my 16v but can't get any socket In there to pull them out......What special tool do I need and where can I get It?
    Thanks
  20. 11-08-2006 01:22 AM #125
    I may not be doing this correctly but I am trying to get this picture to a place where someone looking for it can find it....
    Dear Mr. Moderator....please help me to correctly place this picture of a 16 valve Scirocco vacuum diagram....it is a little dirty but you can tell all of the important connections....Thank you for your help....
  21. 12-19-2006 06:22 AM #126
    does the 16v KR head feet on the 9a engine blok..... ????
    without adittional modofication ????
  22. Geriatric Member VDub2625's Avatar
    Jan 3rd, 2003
    Fall River, MA
    12-19-2006 10:16 AM #127
    1.8 16v airflow routing diagram. Great for checking leaks, not just in vacuum lines
    A2Resource
  23. Member Greengt1's Avatar
    Aug 27th, 2006
    Lansing IL
    92 Monty Green GTi 16vt
    12-22-2006 03:24 PM #128
    Here is an intercooler from a 93 Saab 9000 CD
    Its about the same size as the volvo one but the ends go down.
    You have to remove your brackets that held the condensor in. (couple of 10mm's
    Next is to grind away at some of the cross memeber.
    (Just grind away enough inside for intercooler to sit in)
    Lastly you get this!
    Modified by Greengt1 at 1:29 AM 11-30-2006
    Plenty of parts for sale!
  24. 01-04-2007 11:31 PM #129
    Cleaned this up last time I saw it. Thought I'd post it here as well.
    Still not sure on the "co/ox valve" labeling. Was hard to make out in the original. Can anyone verify? I can correct and reload image.
    Modified by smithma7 at 11:32 PM 1-4-2007
  25. Member Greengt1's Avatar
    Aug 27th, 2006
    Lansing IL
    01-05-2007 10:51 AM #130
    Carbon monoxide, oxygen valve. it looks like a diaphram and has like 2 vacuum lines going to it...........I'll try to find a pic
  26. 01-05-2007 03:22 PM #131
    Quote, originally posted by Greengt1 »
    So, are you saying that I labeled that one correctly? Looking at the original pic, it's really hard to tell what it said.
  27. Member Greengt1's Avatar
    Aug 27th, 2006
    Lansing IL
    01-07-2007 12:38 AM #132
    Quote, originally posted by smithma7 »
    Yes
  28. 01-19-2007 10:26 PM #133
    Does enyone knows or has informations about polished head... soon i'l be replace'in my valves so if i am taking of the head i was thinking maybe polish'it to gain some power...so any advice is welcome...thx
  29. Member Jankenstein's Avatar
    Aug 1st, 2002
    03 JETTA 1.8T, 90 JETTA 16V
    01-31-2007 04:21 PM #134
    Did a DIGI 2 16V Swap into my 90 jetta daily driver .........result....works great!
    good strong pull. little headaches, fairly cost effective.
    it never lets me down. never had any intentions of running a turbo or heavy modifications (as its still a daily). but i do know that it is far more reliable than my motronic 16v passat.
    just my 2 cents.....thanks for reading
  30. Geriatric Member VDub2625's Avatar
    Jan 3rd, 2003
    Fall River, MA
    01-31-2007 06:06 PM #135
    How does it feel compared to the Passat? is the Digi 2 a 1.8 or 2.0?
    A2Resource
  31. 02-01-2007 04:07 PM #136
    Quote, originally posted by rebel_eye »
    what mouts do i need for a 2.0L 16v block to fit in a mk1 ?
    I thought i bolted rigt up .
    I will try and get some pics of this later, but here is what you need to know.
    There are 4 engine mounts: rear passenger side motor mount, rear transmission motor mount, front transmission motor mount, and a front starter motor mount.
    The rear passenger motor mount takes 5 bolts (4 on the motor itself, and one through the mount to the chassis).
    The rear transmission motor mount is a rubber piece that bolts below the steering rack, two bolts through the transmission mount bracket, and then bolts onto the transmission with 3 nuts (note, the transmission must be a mk1 or mk1/2 transmission). See this page for more information on which transmissions will work for a mk1 applciation: http://www.brokevw.com/020mount.html.
    The front transmission motor mount is much like the mk2 transmission motor mount, except it mounts to the chassis in the front, not the rear. Two long bolts go through the mounting bracket and the transmission, and one bolt goes through the mount itself intot he chassis.
    The front starter motor mount is exactly like the mk2 starter mount, except that it has two pieces and a different rubber mount. One piece is a metal "bucket" that bolts to the bottom of the radiator support in the engine bay. The other piece is the bracket that the starter bolts into and has the rubber mount that you have to push onto the end of the bracket. You have to wedge this piece in there to get it to fit correctly, and then bolt up to the starter as normal.
  32. 02-01-2007 04:54 PM #137
    I need some help, i've been looking for some help but no one seems to have it.. so if some one here can help i'd love it.. i bought a 89 helio that had a dead motor.. so i bought another motor from another 89.. i bolted the motor in but i have no idea where all the wires go.. i'm pretty good with the mk4 but have no idea about mk2's.. what type of motor do i have? i know it's a 16v 1.8 but what type of system is it? i'd be real thankful to some help.. i dont want the project to die..
    Modified by Sid-Rage at 4:56 PM 2-1-2007
  33. Geriatric Member VDub2625's Avatar
    Jan 3rd, 2003
    Fall River, MA
    02-01-2007 05:02 PM #138
    CIS-E. The sensor wires should be in the same places, it should be fairly similar... there aren't that may wires
    A2Resource
  34. 02-01-2007 05:14 PM #139
    Quote, originally posted by VDub2625 »
    not similar, the same...the only difference could be knock-sense ignition, and that would only be a single plug.
    to the guy that needs help: re-read this thread and look for the picture of all the sensors. that will tell you what wires go where. if you don't know what they look like on the engine harness, better find out.
  35. Member veedubpickup's Avatar
    Aug 20th, 2006
    7 Cities, VA
    '81 caddy r.i.p. 01 audi s4
    02-06-2007 05:04 PM #140
    where can i find/read info. on swapping a 2.0l 16v into a mk1?
    thanks
