VWVortex.com - B5.5 front end conversion
    Results 1 to 16 of 16
    Thread: B5.5 front end conversion
    1. Member riceslayer's Avatar
      Feb 15th, 2012
      17202 PA
      soot machine
      05-21-2013 09:50 AM #1
      I'm looking into getting my first passat which is an 98 wagon. My question is, is it possible to do the b5.5 front end on these?
      I apologize if this is a redundant question, I'm trying to learn the world of passats
      Also I did search and found very little helpful info.
      Quote Originally Posted by 90dub View Post
      these pics make me wanna punch baby monkeys
    2. Member dublax44's Avatar
      Jul 30th, 2011
      Lancaster, PA
      W124
      05-21-2013 01:12 PM #2
      Yes it has been done before, but I only know of one. I can't find any pictures of it but I believe the owner called it a b5.25. I do not know what all it consists of but im sure its a matter of brackets and mounting points.
      W124
      @derekmaplesyrup
    3. Member scotts13's Avatar
      Feb 15th, 2007
      Lehigh County, Pa.
      2004 GLS 1.8T
      05-21-2013 02:57 PM #3
      You have to swap the front bumper, upper and lower grilles, headlights, fenders, hood, and radiator support. A few brackets and such, and modify some wiring. I think you may have to do something with the hood latch, too. Also, when you're done, the rub strip on the front bumper won't match the rest of the car. It's been done more than once.
      Personally, I like the older B5 front end; looks trimmer and sleeker. The integral fog lights on the B5 work better than the separate B5.5 ones. But to each his own.
    4. Member EuroLuvMk2's Avatar
      Aug 30th, 2012
      Knoxville, Tn
      Current: B5.5 Passat Wagon, Past: mk2 golf vr6 helios recaro. mk2 gli 16v helios recaro. b5.5 sedan
      05-22-2013 01:54 AM #4
      I also think you should stick with the b5 front end and refresh it with some headlight lens correction etc. I like the b5 look a lot, at least as much as the b5.5, maybe a tad more. Very sleek.
      It's a pain in the ass you switch all that stuff. It's not as easy as some cars, say a honda accord, where all you had to do was change front bumpers and maybe a bumper support.
      Current:
      B5.5 Passat Wagon 30v A/T, Mk2 Vr helios recaro
      Previous:
      1989 VW Mk2 Jetta gli clone helios recaro
    5. 05-25-2013 09:13 AM #5
      Its been done.
      B5 to B5.5 with W8 headlights, Rieger lip and smoothed and painted euro rubstrips. Pics show unpainted still.
    6. Member
      Mar 4th, 2012
      Arizona
      03 Passat AWM, previous B4 Passat, previous Mk3 GTI
      05-25-2013 11:30 AM #6
      Why not just buy a B5.5?
      "My timing belt is like all shredded on the edges...is that normal?"
    7. 05-25-2013 08:20 PM #7
      Quote Originally Posted by IanInOhio View Post
      Black on black manual. Couldn't find a b5.5 with the same options close enough. after all i spent I'm still under ab5.5 price.
    8. 05-25-2013 08:48 PM #8
      Dbl. Post
      Mar 4th, 2012
      Arizona
      05-25-2013 09:36 PM #9
    10. Member EuroLuvMk2's Avatar
      Aug 30th, 2012
      Knoxville, Tn
      05-26-2013 12:17 AM #10
      Quote Originally Posted by 59eurobug View Post
      Its been done.
      OMGOMGOMGOMGOMGOMGOMGOMGOMGOMGOMGOMG
      Current:
      Previous:
    11. Member Steve in Chicago's Avatar
      Dec 13th, 2008
      Chicago, Illinois
      1999 Volkswagen Passat GLS
      05-26-2013 09:31 AM #11
      I like the B5 front end better. Personal opinion and bias.
      A science of vague assumptions based on debatable figures taken from inconclusive experiments and performed with instruments of problematic accuracy by persons of doubtful reliability and questionable mentality
    12. Member riceslayer's Avatar
      Feb 15th, 2012
      17202 PA
      soot machine
      05-27-2013 01:28 PM #12
      I appreciate the replies! I've just been a little torn between the front ends but have always liked the b5.5 better. I've done a bit more research on the passat world forum and they do call it a b5.25. I may just be on the fence because I haven't seen as many well done b5 front ends (as I'm new to passats) but if I could see some examples you all may convince me to stay b5.
      I'm looking to do something badgeless with some sort of simple valance like the Reiger one above. I've been searching and learning a lot so I feel that I'm on the right track here. Feel free to post some front end shots!
    13. Member
      Aug 11th, 2010
      upstate ny
      B4 Passat Tdi Wagon, b6 passat tsi 6m (for sale), R32 GT-R
      12-18-2013 12:56 PM #13
      Thought this was an appropriate thread to bump...i have a b5 wagon and need a new rear bumper..
      .theres a b5.5 rear available...will they swap simply?
    14. Member
      Feb 9th, 2003
      pottsville, PA
      2004 passat 1.8t manual 4motion wagn,83 rabbit convertable,81 pickup,80 vanagon,95 90 quattro sport,
      04-19-2015 09:18 AM #14
      i love that black wagon , with any luck ill be doing the same
    15. 09-20-2016 11:13 PM #15
      Does core support have to be switched out
      Sent from my SGH-M919 using Tapatalk
    16. 09-22-2016 12:46 AM #16
      passatworld.com has a decent amount of info on swaps as well, if you can't find what you need here.
