VWVortex.com - 99.5 jetta wont start. PLEASE HELP.
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 33
    Thread: 99.5 jetta wont start. PLEASE HELP.
    1. 05-25-2013 11:51 PM #1
      So i have a 99.5 jetta. car was running great. i let my gf borrow the car and she said she add oil to the car. i guess over by 2 quarts. she parked the car and couldnt get it started. some guy helped her get it started and she drove it back to my house. now that car wont start at all. i turn the key and the car revs up and die within a sec. i replaced the coil pack, cps, spark plugs, spark plug wires, cleaned manifold, cleaned throttle body. car still wont start. i hear a back fire everytime i turn the key. when i step on the gas pedal to try and see if it will stay on with gas pedal down... nothing. doesnt respond to the pedal. i am kind of at a lose. really dont know what else to do. maybe a bad fuel pump? fuel filter? fuel injector? fuel relay? car starts everytime for one sec so im kind of guessing it getting gas but idk. im really at a lose. please help.
    2. 05-26-2013 09:13 AM #2
      that sounds like the immobilizer is active. is the light for the security system on the cluster on when this happens?
    3. 05-26-2013 10:46 AM #3
      no light comes on. ive been looking. i dont think my car has one.
    4. Member ps2375's Avatar
      Aug 13th, 2003
      Meridian, ID
      80 Rabbit(DEAD), 94 Golf, '69 Type1 Sedan
      05-26-2013 12:13 PM #4
      Check your fuel pressure and get it scanned for codes. FP won't cause a CEL, but the immo will(along with other things).
    5. 05-26-2013 06:20 PM #5
      Quote Originally Posted by ps2375 View Post
      how do i check fuel pressure? how do i check immo if there is no light for it?
    6. Member ps2375's Avatar
      Aug 13th, 2003
      Meridian, ID
      05-26-2013 08:33 PM #6
      Quote Originally Posted by finsterbusch.1 View Post
      My first thought and answer to this reply is to say,"step away from the car and let someone who knows what they are doing handle it."
      But, if you insist upon trying to fix it, fuel pressure is checked with a pressure gauge temporarily attached to the fuel rail, and the immo will cause a code to be present in the ecu, have it scanned with a proper scan tool that can read all the codes present. I prefer VAG-Com and I have no clue if a generic OBD scan tool will be of any use.
    7. 05-27-2013 02:59 PM #7
      yeah im going to work on it since thats the only option. dont need the comments like that just need a little help. ill have the pressure checked tomorrow and hopefully my scanner will be here this week. do those cheap vag-com scanners from china work?
    8. Member ps2375's Avatar
      Aug 13th, 2003
      Meridian, ID
      05-27-2013 03:51 PM #8
      dunno, I've only ever used the real one.
      And having a good service manual, like the Bently Manual, will help tons. GL
    9. 05-27-2013 09:06 PM #9
      i think i found the problem. fpr... i removed the fpr and gas poured into the lines. i put it back on and the car started for a while till the gas ran out. i think the regulator is stuck closed. or something like that.
    10. 05-28-2013 07:17 AM #10
      well as already suggested you might want to get a gauge on the fuel rail and see exactly whats happening. fpr is a possibility but dont over look a weak pump or clogged fuel filter
    11. Member
      Mar 6th, 2002
      Morris Plains, NJ
      1998 GTI 2.0T
      05-28-2013 04:06 PM #11
      1999.5 cars in North America didn't have immo, hence why you see no light to that effect. The problem lies elsewhere.
      Fuel pressure should be fed into the rail, the regulator should be on the return side. A stuck closed regulator would effectively deadhead the fuel pump, and rail pressure would skyrocket. Was any work done besides adding oil right before this started? Any chance the fuel lines got installed backwards?
      Also, this may sound stupid, but are you 100% sure that there is there gas in the tank (remember, the gauge/sender can break and be wrong).
      Pirated ones, no. They can actually brick control modules.
      However, you can get a cheap China cable and try it with VCDS-Lite. If it works with the shareware VCDS-Lite (shareware is extremely limited), pop the $99 for the full license and you'll have legit full VCDS.
      2012 Corolla
      1998 GTI 2.0T
      World Automotive
    12. 05-28-2013 08:49 PM #12
      no work was done to the car. it drove fine till parked one day. and yes half a tank of gas is in the car
    13. Member Bx V-dubber's Avatar
      Dec 16th, 2010
      CT
      04 gti 1.8T, 95 Golf 2.0(projekt), 2003 dodge ram, RIP 05' vw gti
      05-28-2013 11:43 PM #13
      ya need a vag scan tool. snap-crap,matcon & mac fool scanners are good but they cannot access all the info you would need from a vag scanner. the knock off vcds are garbage and will tease you by allowing you to use some things but not others from the program besides possible bricking. not sure on vcds lite. pay someone to scan it with a vagcom and work from there.
      Glen Quagmire: Hello, 911? It's Quagmire. Yeah, it's caught in the window this time.
      mk4 1.8t build-thread
      A-Love-Affair-My-MK3-build
    14. Member
      Mar 6th, 2002
      Morris Plains, NJ
      1998 GTI 2.0T
      05-29-2013 08:27 AM #14
      Definitely get an actual fuel pressure reading. And get a good scan of the car.
      Here's a VCDS-Lite vs full VCDS function list:
      http://www.ross-tech.com/vag-com/vag-functions.html
      2012 Corolla
      1998 GTI 2.0T
      World Automotive
    15. 05-29-2013 10:26 PM #15
      hello all thanks for helping me. ok so today i took off the fuel filter. i noticed no fuel came out the end of the fuel filter... well just a couple drops. when i took the end off that goes from the pump into the filter a lot of fuel poured out. i dont know if that means anything. but im with you guys on checking the fuel pressure do you know of any sites that sell cheap pressure gauges? and i also turned on the car just before ignition just to see if my pump was even working and it was pushing out gas. not sure if its enough but it is working. im going to get my scan tool in this week so i can at least read some of the codes. and go from there. any advice you guys can give me on what else to look for? maybe vac hoses? and do i need to adapt my throttle body? i have the throttle body with the cable.
    16. Member Bx V-dubber's Avatar
      Dec 16th, 2010
      CT
      05-29-2013 11:26 PM #16
      usually in the fuel filter you wont see a lot come out til you turn it upside down. ya really need a fuel pressure gauge to see if your getting spec pressure. harbor freight i believe sells one ya could use (don't quote me). don't know if the one autozone lends out will be compatible.
      btw: your first mistake was lending your car to your gf
      sorry couldn't resist that one
    17. 05-30-2013 12:50 AM #17
      Quote Originally Posted by Bx V-dubber View Post
      yeah no joke. ran good... two hours later doesnt run at all. didnt even give any signs before that of any problems
    18. 05-30-2013 11:22 PM #18
      i replaced the fuel filter today. tried to run the car... same problem. i unplugged the throttle body again to see if that would help. car idles good now. but when i step on the gas the car dies. A least i have the car running now. seems like im making some progress.
    19. Member
      Mar 6th, 2002
      Morris Plains, NJ
      1998 GTI 2.0T
      05-31-2013 09:06 AM #19
      Still no codes or fuel pressure readings?
      2012 Corolla
      1998 GTI 2.0T
      World Automotive
    20. Member
      Jan 17th, 2008
      Summerville,SC
      01 VW Jetta GLS 2.Slow
      05-31-2013 09:37 AM #20
      First find someone near you with a vag scanner, use a fp gauge, and don't let a female drive your car, unless she's dropping money on parts. But get the proper tools cause your flying blind right now...hell vag-com will turn you in to a pro lol
      Sent from my PC36100 using Tapatalk 2
      "I'll trade a kidney for an MK4 R32"
    21. 05-31-2013 02:24 PM #21
      tank vent valve short to ground. could this be my problem. i ran my scanner today and this came up
    22. 05-31-2013 04:50 PM #22
      scanner codes-
      17951- P1543- THROTTLE ACTUATION POTENTIOMETER- SIGNAL TOO LOW
      01165- THROTTLE BODY CONTROL MODULE-J338
      17988- P1580- THROTTLE ACTUATOR (B1) FAULT-MAY BE CAUSED BY LOW BATTERY IF FOUND WITH 16487(P0103)
      those are the codes that were on the scanner.
    23. Member
      Jan 17th, 2008
      Summerville,SC
      05-31-2013 05:32 PM #23
      Ok try this disconnect the battery for 3-5mins so the throttle body recalculate. Than see if it stays running.
    24. 05-31-2013 07:29 PM #24
      didnt help
    25. Member
      Jan 17th, 2008
      Summerville,SC
      05-31-2013 07:53 PM #25
      I recommand you check it with a fuel gauge to make sure its getting the proper amount. Check the connector on the throttle body and fuses as well
