VWVortex.com - Location of squeaks–––>Post to be of help to all!
    Page 1 of 8 12345 ... LastLast
    Results 1 to 25 of 197
    Thread: Location of squeaks–––>Post to be of help to all!
    1. 11-30-2002 02:45 AM #1
      Please post the locations of confirmed squeaks, rattles, and rubbin' noises, so that we can all get in together on tryin to get 'em worked out.
      Please, just confirmed...i.e. you know it's "coming from the bottom right side of the driver's door"...not, "I think it's coming from somewhere inside the car..."
      If fixable post that in the poll choice and then a full response to tell what you did to eliminate it...
      Let's take car of this crap and get on with drivin our rides...
    2. 11-30-2002 02:52 AM #2
      For Rear Trunk Cover Hatch Squeaks when cornering
      Symptom
      You hear a squeaking sound coming from the rear interior of the car (both sides) when cornering or making any movement of the vehicle which would cause the body to flex.
      Inspection
      Look at underside of trunk cover. At the back of the cover (rearward facing side-nearest the hatch) look at the underside , on the left and right edges.
      You will most likely see 2 spots where your trunk cover is rubbing against the plastic trim, and is matted down and slightly white.
      Fix
      Go to the local crafts or fabric store and get some velcro strips, that are sticky on one side. Get black so that it will blend in. Then take the soft side and stick it on where you saw the white spots on the fabric. You can throw out the scratchy side of the velcro or save it for another project.
      [Modified by TA373, 1:54 AM 11-30-2002]
    3. 11-30-2002 06:29 PM #3
      Symptom
      Passenger side door rattles when playing bassy music
      Inspection
      When playing bassy music I've noticed a rattle coming from the passenger side door only this does not seem to be coming from the driver's side door...only from the passenger side door.
      Attempted fix
      Some people have been told the replacing the window regs will take car of it. But that doesn't seem to work. Nor does a simple adj. of the door. I have noticed that if you grab the map well (the little cubby to put maps in) and pull it slightly towards the driver's side door, the sound goes away for a few...
      [Modified by TA373, 2:30 PM 11-30-2002]
    4. Member
      Feb 16th, 1999
      Miami, FL
      2011.75 BMW E90 M3 6MT, 2014 Lexus RX 350
      11-30-2002 08:27 PM #4
      Check the little light that's on the lower part of the door panel. That rattle was driving me nuts with even moderate volume on the radio, but pushing on that light made it go away...for now.
    5. 11-30-2002 09:32 PM #5
      My driver side door pops after a swift pop or going up drive ways. Anyone have this problem?
    6. 12-01-2002 01:54 AM #6
      quote:
      Symptom
      Inspection
      Attempted fix
      To solve this problem, pull the door panel just enough to slide the soft side of velcro between door panel and door around the speaker and map pocket on the bottom.
    7. 12-01-2002 02:03 AM #7
      Passenger Seat Squeak
      Symptom
      Passenger side seat will squeak when driving (with passenger in it)
      Inspection
      Get a buddy to sit in seat. Drive. Listen. May notice squeaks coming from passenger seat.
      Attempeted Fix
      Some have had the seat channels lubed.
    8. 12-01-2002 05:29 AM #8
      For any door creaks, pops, squeaks, or rattles, I've got two words--Gummi-Pflege. Worked great on my SVTF as well.
      [Modified by SpeedieVR6, 3:30 AM 12-1-2002]
    9. Member keifa9's Avatar
      Jun 3rd, 2002
      Dudley, MA
      337, B7 TDI
      12-02-2002 12:20 PM #9
      i got that buzzing sound behind the dash. it's only audible at 2800 rpm. Not 3k or 2500 only at 2800. Any fix for this. Could it be the rear hatch? Only since I am driving up front, it sounds like it is in the dash
    10. 12-03-2002 12:20 AM #10
      I have it at exactly 2800 rpm as well!
      PROBLEM
      Vibration/buzzing noise behind firewall at right about 2800rpm
      SOLUTION
      I have heard its the heat sheilding thats near the exhaust. Just wait till its cool to the touch and give it a slight bend where the rattle is occuring.
    11. 12-03-2002 09:38 AM #11
      Great Post idea!
      I just hope the trolls don't get to your unlocked poll. I clicked on the first one and realized I needed to start a new one. Mine would be: All of the above.
    12. Banned
      Aug 29th, 2002
      12-03-2002 09:57 AM #12
      My tweeders sound like crap. Especially when someone is talking on the radio, it sounds like there is a Kazoo in there. Whats the fix? It doesn't even look like I can get in there without ripping the car apart.
    13. 12-03-2002 09:34 PM #13
      First i'll list all of the problems that i have had FIXED:
      1) buzzing and banging sound from the trunk when going over bumps----dealership tightened the Monsoon amp.
      2)Popping sound from the front when simultaniously turning and hitting a bump---some bushing on the control arm was loose
      3)rear tweeters buzzing----get aftermarket tweeters
      now for the ones that are driving me absolutely crazy
      1)squeaking recarro seat
      2)squeaking rear end..????
      3)ever single door rattles---i'm gonna try the BMW stuff
      4)sometimes when i come to a stop something behind my left shoulder goes *POP*
      5)when the windows are down, it literally sounds like the car is going to fall apart (window regulator?)
      6)now starting to hear creaks from the dash pannel
      WOW look at that list....this is why i will soon be moving to the audi or nissan family (my dad will now drive the wolfy full time). sorry VW, you've got to get the build quality up. use some bond-o
    14. Member
      Nov 20th, 2002
      Milton, MA
      2012 Golf R, 2012 Tiguan SEL
      12-04-2002 11:47 AM #14
      what about the one where you get in your car and the suspension squeaks? I have that happen to me every now and then. Has anyone fixed that yet?
    15. 12-04-2002 12:12 PM #15
      I don't believe that's the suspention, but rather the rear disc brakes groaning from the parking break being set.
      To test this, hop in the car after it's been siting for a while...whit the ebrake set. It should make the noise.
      Then without moving the car, put it in gear (so it won't move) and release the ebrake. Get out. Get back in. It probably won't make any noise.
      m.
    16. 12-04-2002 12:21 PM #16
      the buzzing sound u hear in the dash area is the rear view mirror... when u hear it, hold the mirror to c if it stops. that's where found mine to be. it does sound like it's com'n form the inside of the dash: right side. but for me it's the rear view mirror. chech it out and see if that helps.
    17. Member keifa9's Avatar
      Jun 3rd, 2002
      Dudley, MA
      337, B7 TDI
      12-04-2002 12:22 PM #17
      anybody's clutch squeak. every time i press and depress. probably just needs some lube
    18. 12-04-2002 03:36 PM #18
      Huh???
      Sprechen sie Douche?
    19. 12-04-2002 07:04 PM #19
      If I am in first gear, and accelerate abruptly, I hear it...... then if I hit the brakes in first gear, I hear it....... its a creak from the right door and its quite loud.
      It also does it sometimes when cornering or if I hit a bump... It has drove me mad!!!! Luckily I wont deal with it 'till spring as the 337 is in hibernation! Any one have a clue?????
    20. Member
      Nov 3rd, 2001
      Bay Area, CA
      2004 Passat W8 6MT
      12-07-2002 02:07 PM #20
      My clutch is squeaky too!
    21. Banned icuravwnut2's Avatar
      May 12th, 2002
      12-07-2002 02:15 PM #21
      Try this.....
      Go get some silicone from Warne in the red and white tube.
      Apply a very thin coat (non visable) to the door seals.....yes this means you will have to open the doors and do the seal on the door and the car.
      This should make that go bye bye! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    22. 12-07-2002 09:26 PM #22
      Ill give that a try.... If it works I will drive my creak free 337 to Toronto and thank you personally! Hey, the big T. O . rocks!!!!! {and I miss the Hockey Hall of Fame!}
    23. Member pheethus's Avatar
      Jul 24th, 2002
      all. bunnies. new. york.
      19th anniversary 6spd sunroofless gti, 2010 jsw deezul junk awaiting buyback, 2017 wolfsburg touareg
      12-08-2002 02:02 PM #23
      rear hatch velcro fix worked awesome, thanks
    24. Member chaugner's Avatar
      Jul 13th, 2002
      Miami
      Audi TTQ, Touraeg, Passat
      12-08-2002 02:46 PM #24
      dashboard between 3200rpm and 3600rpm ... its driving me nuts. I played around with the dashboard while driving (bad idea I know) and I found out its related to the bottom tray where the ashtray is at (the one with the power) .. if you push hard against the top part the ratle will go away
    25. 12-10-2002 01:22 AM #25
      That bitch in the seat next to me! Time to trade her in!
      On a serious note, I got the hatch squeak too. I'm gonna try the velcro tomorrow. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
