VWVortex.com - Golf GTI Mk4 1.8T engine not starting, only cranking
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 32
    Thread: Golf GTI Mk4 1.8T engine not starting, only cranking
    1. Semi-n00b
      Jun 4th, 2013
      Golf GTI Mk4 (2000)
      06-04-2013 07:11 PM #1
      Hi,
      I have a Mk4 Golf GTI, 1.8T engine. A few days back, I had this issue where my engine did not start. After ignition, as I tried to fire the engine, it kept cranking but did not fire the engine at all. This happened about two weeks ago, after which I left the car alone for 15 minutes. When I tried again, the engine fired and everything was normal again. Following that the car has been running OK, sometimes I do feel something is different while starting the engine. Now, today the same problem came up, where the engine kept cranking, but did not fire. I was almost going to give up, when I tried again and there, it fired!
      I'm a bit worried about what the issue could be. I've been trying to do some reading on similar issues faced by others, but I'm getting conflicting ideas.
      Could someone please help out?
      Thanks
    2. Member mk320valve's Avatar
      Jun 21st, 2005
      LEVITTOWN PA
      JAZZ BLUE CORRADO ON TTS YELLOW CORRADOMK2 SLAMMED ON VETTS VR MK3 JETTA M35X AUDI A4 MK3 SURF GREEN
      06-04-2013 08:35 PM #2
      do u want to sell it
    3. Junior Member air.carter.15's Avatar
      May 7th, 2012
      Toronto
      2004 Jetta GLS 1.8T
      06-04-2013 10:06 PM #3
      Engine Speed Sensor aka Crankshaft Sensor
      Very common issue with 1.8t engines .... had this happen to me last month and couldn't figure out what it was since it didn't throw any codes.
    4. Semi-n00b
      Jun 4th, 2013
      Golf GTI Mk4 (2000)
      06-05-2013 04:31 AM #4
      Quote Originally Posted by air.carter.15 View Post
      Hi,
      I have done a diagnostic check using a VAG-COM kit about 10-15 times. Most of the times it came up with zero faults. Once it came up with a 'Engine Speed Sensor (G28)' code (P0322 - 35-10) and 'Engine Blocked by immobilser' code(P0322 - 35-10), BUT since the ignition wasn't on at that time, I ignored it, cleared DTCs and did it again, and then there were zero faults. Another time it came up with an 'Internal Control Module' code (P1640 - 35-10). Again I cleared it and it's fine since, except yesterday when it didn't start properly.
      So, how did you find out it was the crankshaft sensor? I spoke to a VW dealer and he said that if the fault is intermittent even they would have an issue in identifying it.
      Thanks for your help!
    5. Member jrdnlc's Avatar
      Oct 5th, 2012
      SoCal
      08' Audi RS4, 86' Golf MK2 4Dr
      06-05-2013 01:49 PM #5
      Im having the same problem my car wont start and not power to the fuel pump or even the fuse.
      After reading im guessing it might be my Engine speed sensor aka Crankshaft sensor too.
      Are you getting power to the fuel pump? Do you hear it prime?
    6. Junior Member air.carter.15's Avatar
      May 7th, 2012
      Toronto
      2004 Jetta GLS 1.8T
      06-05-2013 02:47 PM #6
      75% of the time it will throw a code which you had gotten there, and the odd chance like myself it didn't throw a code.
      At first I had no clue what was going on since the car would start/run then die then start up for 10 minutes and die again it made no sense. I brought it to the Volkswagen Dealership and they told me it was the Alternator which made no sense since my Battery and Alternator levels check out. So then I took it to a Volkswagen specialist in my area and he checked everything from Scanning for codes ..... checking ground wires .... fuel pump .... ignition .... they all worked and since the car would start the odd time it wouldn't make sense for any of those to be the problem.
      From his experience he told me it was the Engine Speed Sensor/Crankshaft Sensor. I searched myself around here and found it was a very common problem. Only reason why I didn't think of it before cause it didn't throw any codes when they usually do.
      Changed out the Sensor 3 months ago and haven't had any issue since!
      By the way, when you car dies and you try to start up the car it will crank but won't catch .....
    7. Junior Member air.carter.15's Avatar
      May 7th, 2012
      Toronto
      2004 Jetta GLS 1.8T
      06-05-2013 02:50 PM #7
      Has the car ever just died while you were driving?
    8. Member jrdnlc's Avatar
      Oct 5th, 2012
      SoCal
      06-05-2013 06:36 PM #8
      Mine started the day after it left me stranded at my job but then shut off on me after like 5 secs.
      Ever since that day it wont even start.
    9. Semi-n00b
      Jun 4th, 2013
      Golf GTI Mk4 (2000)
      06-11-2013 11:39 AM #9
      No, it hasn't died while driving. Only when its parked/off for sometime, does this happen. Also another thing I've noticed nowdays is that the engine idles at around 1200 rpm when I start everyday. It comes back to 800 rpm after a while, but in the beginning it just seems a bit high.
      Adding to this, I've now got an Airbag fault too, so I'm quite confused. Some forums I've read seem to suggest it could be an ignition coil issue, which doesn't let the engine fire (apparently Mk4s have this issue), does anyone think it could be that?
      Thanks
    10. Semi-n00b
      Jun 4th, 2013
      Golf GTI Mk4 (2000)
      06-11-2013 11:51 AM #10
      Quote Originally Posted by jrdnlc View Post
      I'm not sure how to check that. I haven't exactly done too much work on cars before. Can you tell me how to check that?
      Thanks
    11. Member jrdnlc's Avatar
      Oct 5th, 2012
      SoCal
      06-11-2013 03:51 PM #11
      Quote Originally Posted by gti_enthu286 View Post
      Thanks
      When you open the drivers door u hear like long buzz in the rear of the car and when u put the key and turn it u should hear it again.
      Thats the fuel pump priming.
    12. Semi-n00b
      Jun 4th, 2013
      Golf GTI Mk4 (2000)
      06-14-2013 04:12 AM #12
      Yes, I can hear it priming. So that is definitely ok then. Someone suggested it could be the crank speed sensor, so I'm trying to figure that out now. Any hints on how I could check that without going to a mechanic?
    13. Member jrdnlc's Avatar
      Oct 5th, 2012
      SoCal
      06-14-2013 11:53 AM #13
      I just changed that on my car last week it took 30min and it didnt even fix my problem.
      Send me a message and ill guide you through it.
    14. Semi-n00b
      Jun 4th, 2013
      Golf GTI Mk4 (2000)
      06-20-2013 08:09 AM #14
      I've sent you a message. Waiting for your reply, thanks.
    15. Member
      Jun 16th, 2009
      NW 'burbs of Chicago
      '15 FiST, '13 Quest
      06-20-2013 08:30 AM #15
      just swap it out for a new one, you can pick em up for $20 and they're held on with a single bolt. They're down between the oil filter and the starter, on the block. It's cheap and easy to rule out. After that it could be dirty injectors, failing relays, weak grounds, weak fuel pump, etc etc.
    16. Semi-n00b
      Jun 4th, 2013
      Golf GTI Mk4 (2000)
      06-21-2013 12:13 PM #16
      Any further hints/tips of what it could be based on what I wrote back? So today again the problem has repeated after many days, where the car is not starting, but has been running normally last few days. I'm pretty sure it will start after sometime. Your thoughts?
      Thanks again.
    17. Member BassNotes's Avatar
      Mar 15th, 2005
      Costa Mesa, Calif., USA
      2002 VW GTI 1.8t
      06-21-2013 02:08 PM #17
      Sometimes a crank position sensor might fail in a way that won't show up in any stored ECU faults that VAG-COM can read.
      I'll have to look it up to be sure, but I believe the CPS is a variable-reluctance type sensor with an internal ferrite core and a coil around it. If the coil breaks continuity or shorts out or something, the ECU would see that as a fault. But if for some reason the ferrite cracked or managed to shift position, the CPS could lose its ability to read the teeth on the crankshaft and yet because it wouldn't be an electrical failure, the ECU wouldn't detect it as a fault.
      Bob Lee
      2002 GTI 1.8t 262,000+ miles
      VCDS 15.7.3 with KEY-USB interface
    18. Semi-n00b
      Jun 4th, 2013
      Golf GTI Mk4 (2000)
      07-03-2013 06:54 AM #18
      Quote Originally Posted by BassNotes View Post
      So I've managed to do a diagnostic test. Here are the results:
      Chassis Type: 1J - VW Golf/Bora IV
      Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
      76
      Mileage: 183450km/113990miles
      --------Address 01: Engine Labels: 06A-906-032-AUM.lbl
      Part No: 06A 906 032 AR
      Component: 1.8L R4/5VT G 0007
      Coding: 05500
      Shop #: WSC 00000
      VCID: 6ED9E25C2A82C968C27
      2 Faults Found:
      16706 - Engine Speed Sensor (G28)
      P0322 - 35-10 - No Signal - Intermittent
      17978 - Engine Start Blocked by Immobilizer
      P1570 - 35-10 - - Intermittent
      Readiness: 0000 0000
      --------Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
      Part No: 6Q0 909 605 A
      Component: 0F AIRBAG VW5 01 0004
      Coding: 12358
      Shop #: WSC 01317
      VCID: 356B0D300F54BAB0C3D
      1 Fault Found:
      01218 - Side Airbag Igniter; Passenger Side (N200)
      32-10 - Resistance too High - Intermittent
      ---------Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
      Part No: 1J0 920 925 A
      Component: KOMBI+WEGFAHRS. BOO V01
      Coding: 05412
      Shop #: WSC 00000
      VCID: 2757D778C5F8D820411
      Subsystem 1 - Part No: Ident
      Component: Nr. WEGFAHRS.:VWZ6Z0Y2084584
      Ident.-Nr. WEGFAHRS.:VWZ6Z0Y2084584
      1 Fault Found:
      01176 - Key
      07-10 - Signal too Low - Intermittent
      For the engine speed sensor fault, I assume it refers to the crank sensor? Would that also be the cause of the engine not starting because of being blocked by the immobiliser?
      Any help/suggestions with the other faults would be great. I have ordered a new battery for the key yesterday.
    19. Member H100VW's Avatar
      May 10th, 2001
      Brisbane
      2006 Polo GTI, 2000 S3, 2001 A4 wagen.
      07-03-2013 07:12 AM #19
      Key signal too low probably caused the blocked start.
      My take the crank sensor is the real fault.
      Immobilisers allow the car to start and run for a couple of seconds before cutting off. So you know the engine is ok.
      Gavin
    20. Member
      Jun 16th, 2009
      '15 FiST, '13 Quest
      07-03-2013 08:49 AM #20
      H100VW
      x2
    21. Semi-n00b
      Jun 4th, 2013
      Golf GTI Mk4 (2000)
      07-03-2013 11:28 AM #21
      Quote Originally Posted by H100VW View Post
      Gavin
      Thanks!
      I've checked on gsfcarparts.com
      For my 1.8T Mk4, these are the two available RPM sensors. Which one do you suggest is the right one:
      http://www.gsfcarparts.com/929vg0330
      http://www.gsfcarparts.com/929vg0040
      Thanks again.
    22. 07-03-2013 01:55 PM #22
      Is there a blinking light on the dash?
      Canadian Immo 2 and 3 defeat service, PM for more information.
      Vag-Com Scanning available in London area, Hex+Can.
    23. Member BassNotes's Avatar
      Mar 15th, 2005
      2002 VW GTI 1.8t
      07-03-2013 02:58 PM #23
      Yes, the engine speed sensor is the same thing as the crank position sensor.
      My usual approach with faults identified as intermittent is to save a record of them and then clear them to see if they come back.
      If you can't start the engine but the fault doesn't come back, then it was unlikely to have been the cause. If the fault does come back, then it's something you'll have to address.
      Bob Lee
    24. Member jrdnlc's Avatar
      Oct 5th, 2012
      SoCal
      07-03-2013 04:00 PM #24
      Also, make sure you go OEM. I learned the hard way.
    25. Semi-n00b
      Jun 4th, 2013
      Golf GTI Mk4 (2000)
      07-03-2013 05:24 PM #25
      Quote Originally Posted by AmIdYfReAk View Post
      No, there isn't. Just the car doesn't start sometimes. Mostly when I've parked and come back after an hour or so.
