    Page 1 of 16 1234511 ... LastLast
    Results 1 to 35 of 538
    Thread: Twin VRT Drag Car Build
    1. 06-08-2013 11:48 PM #1
      Hi, I am building a new drag car. I have been hesitant to start a thread on vortex, but what the hell. I am going to need some help from you expert's so I think its worth all the flaming. I have been out of the vw racing mix for about 5 years. I have been itching to build another race car, this time I am going BIG. My goal is to join the 8 second club With 1600+ AWD HP I dont think that is too lofty of a goal.
      So here is some info:
      Looking to build a twin engine drag car with 12V vrt's
      Engine:
      SP stage 3 short block
      SCCH ported 12V heads
      TT big valves upgrade
      titanium retainers
      Solid lifters
      TT 288 solid cams
      SP intake
      3" throttle body
      AFI twinn Scroll turbo mani
      Precision pt 1000 AWIC
      Garrett GTX-4294R turbo
      Transmission/Drive terrain
      02M FSR case
      SQS custom gear kit (see photo for ratios)
      Peloquin diffs
      SQS SEQ-E shifters
      Clutch Masters 850 twin disc Race
      Drive shaft shop custom stage 5 axles
      SDezego hybrid mounts
      going to run wilwood pedals with twin masters to operate the dual clutches. And 2 seq-e shifters that can operate the trannys separately to do both front and rear burnouts separately.
      TIG welded chromolly roll cage and chassis
      Car is at the Hanksville hotrods in denver, They are doing the chassis and roll cage, this is what is done so far..
    2. 06-09-2013 12:14 AM #3
      These are the gear kits I have. They are being installed at SP right now, waiting on the peloquins..
      Turbo manifolds Im going to use, Should be ready this week...
    3. 06-09-2013 12:29 AM #4
      So, the first thing I am going to need help with is, What A/R housing should I use?
      I am ordering a turbo's next week, as the chassis shop needs it for mock up.
      I am going to need a wide power band to accommodate the super tall gears.
      RPM drop of 2350 looking for a good powerband from 4650 to 7000 RPM
      This is a DYNO sheet of a 12V Vr that I found on the net. It looks like It would work for my gearing, but I would like to do much better.
      Plan to run on E85 with lugtronics.
      Also anyone know what throttle bodies are an easy bolt up to the SP intake? 3"
      Im going to be making some custom rear control arms. Anyone know if I should lose the rear sway bar or keep it?
    4. Member 24vGTiVR6's Avatar
      Sep 13th, 2010
      the track
      24v VRT
      06-09-2013 12:34 AM #5
      subscribed! looks like fun
    5. 06-09-2013 01:50 AM #6
      cool
    6. 06-09-2013 02:37 AM #7
      H
    7. Member AJmustDIE's Avatar
      Dec 22nd, 2010
      Ocala, Florida
      97 Black GLX, RIP 97 White 8vT Jetta Trek
      06-09-2013 01:06 PM #8
      Looks insane.
      It's Timmy with mmmmMojo, i have returned
      8VALVETURBO - RIP White Jetta
    8. Member Slayer's Avatar
      Aug 8th, 2000
      Windham CT
      2008.5 GTI w/TSI motor, 1995 GTI Vr6
      06-09-2013 04:03 PM #9
      This should be awesome
      Check out my Garage build thread 2008.5 GTI 2.0 TSI 6MT / APR K04 V3.1, APR IC, CTS 3" turbo back, Carbonio full intake, GFB DV+, BSH TB pipe, SB Stg2 Endurance clutch, BSH mounts, DG Shortshifter, FFM bracket bushings, Forge big knob, Koni coils, Coolingmist CMGS Meth injection, USRT spacer (DO3 & Snow 100 nozzles), 19" Miro stp3's, Centric rotors, Stoptech pads and TyrolSport bushings
      Mar 20th, 2009
      Rochester, NY
      95 urS6, 92 golf, 84 rabbit, 09 hypermotard, corrados
      06-10-2013 10:51 AM #10
      Cleary Coachworks
      I hate red cars
    10. Member sdezego's Avatar
      Apr 23rd, 2004
      Hurricane Central FL
      '90 Corrado | '62 Harley Panhead
      06-10-2013 11:01 AM #11
      Very nice start!
      Build: Project sc2020
      My G60 now on MS3 | 4Cyl Torque Plate Rental | 02M Mounts
    11. 06-10-2013 01:41 PM #12
      pretty crazy..i like it
      R36T AWD 1100HP
      www.ktech.dk
    12. 06-10-2013 02:35 PM #13
      Somebody on here is craizier than me!! I like it!! subscribed!! Mike
    13. Banned the mad conductor's Avatar
      Nov 11th, 2009
      mesa az
      corrado
      06-10-2013 05:10 PM #14
      surf green
    14. 06-10-2013 06:38 PM #15
      you should start a thread on motorgeek for this. lots of great minds and projects over there, should be able to help with a lot of issues you'll encounter
    15. Member Norwegian-VR6's Avatar
      Feb 6th, 2002
      Norway
      96 Golf VRT, 12 Skoda Superb 2,0 TDI
      06-12-2013 03:45 PM #16
      Hohoho... What havent been done to a Golf before ? You sure use proper parts and think way out of the box
      2012 Skoda Superb 2.0 TDI avant: Daily family car
      1996 Golf MK3 12V 02M Turbo.
    16. Member AJmustDIE's Avatar
      Dec 22nd, 2010
      Ocala, Florida
      06-13-2013 08:14 PM #18
      There is no word for the amount of legitimacy that is this build.
    17. Member AceWaters's Avatar
      Sep 1st, 2008
      Front Royale with Cheese
      92 Corrado VRT
      06-14-2013 12:45 PM #19
      four wheel steering too eh? neat.
      "The purpose of life is a life with a purpose, so i'd rather die for a cause than live a life that is worthless."
      - Immortal Technique
    18. Member BR_337's Avatar
      Sep 3rd, 2011
      ATL ,GA
      91 Mk2 /337 engine/6 spd
      06-15-2013 06:47 PM #20
      insane
      Mk2 GTI TRACKCAR----> 1.8T (Awp) /" 6 speed (O2M)" Holset HX27w Turbo / Stainless Log manifold / Tial WG / TurboSmart / 630cc / 034 fuelRail / Aeromotive fpr / Wavetrac LSD/ CM fx400 /USP steel shift forks / Kirk Rollcage /Wilwood 4 Pot Calipers / Zimmerman Rotors / T4 EuroVan Master Cly / Tuned BY REY (elRey )
    19. 06-16-2013 08:18 PM #21
      Quote Originally Posted by AceWaters View Post
      Yep, the 4ws and the rear sway bar will def come in handy keeping me straight down the track.
    20. 06-17-2013 10:01 PM #22
      Seat pedals and steering are next on the list..
    21. 06-18-2013 11:18 AM #23
      Looks like I got burned by Brad Ratliff from AFI turbo. Just realized they are out of business and JDL is the new company making manifolds. Had to file paypal claims
    22. Member fouckhest's Avatar
      May 22nd, 2003
      Up on the Mtn
      Danger Ranger
      06-18-2013 12:40 PM #24
      Quote Originally Posted by MK123GTi View Post
      bummer to hear man....Ronnie @ JDL will take care of you! they are jam up guys!
    23. Member Yareka's Avatar
      Mar 4th, 2002
      GLi 5857 SLC 6262
      06-18-2013 10:19 PM #25
      Quote Originally Posted by fouckhest View Post
      They most definitely will take care of you
      In for this build, the fab work is already killing it
      apex-tuning.com
      NC's premiere watercooled parts and performance
      Ipanemarado
    24. 06-25-2013 09:30 PM #26
    25. Member AJmustDIE's Avatar
      Dec 22nd, 2010
      Ocala, Florida
      06-25-2013 10:12 PM #27
      That blows.. but like mentioned above, the guys at JDL are
    26. 06-26-2013 01:39 AM #28
      Quote Originally Posted by AJmustDIE View Post
      Well, brad finaly emailed me back the other day and assured me I was getting the manifolds soon. But he has been telling me that for weeks, we'll see, I really hope AFI comes through..
    27. Member
      Oct 26th, 2010
      Little ol UK
      Snailed Vee
      06-26-2013 07:39 AM #29
      This is taking FI to the max.
      I hope you dont put wings on this beast..it will fly..
      In for the haul.
      Steve
    28. 06-27-2013 11:27 AM #30
      Steering and pedals.
    29. Member derekb727's Avatar
      Dec 22nd, 2007
      Central Ky
      2001 Audi A4 2.0Tqm
      06-29-2013 12:23 PM #31
      Awesome
      2001 Audi A4 1.8t Quattro 6spd Click for Part Out!!! Black on Black
      2L • Bullseye S259 • AEB Head • ST Valves/Springs • IECVA1 Race Cams • JE Pistons 8.8:1 • ID1000s • Bosch 044 • Custom Tubular Mani • Apexi Intercooler w/ 3" piping • 80mm Hemi TB • HKS SSQV BOV • Custom Big Plenum NubWorks IM • TiAL Vband 38mm WG • Eurodyne Maestro • FX 850 SS • 01E Swap •
    30. Member sp_golf's Avatar
      Nov 28th, 2007
      Toronto
      88 Golf 16vT
      06-29-2013 05:24 PM #32
      Nice.
      SP Solutions
      Tuning - Electrical/Wiring - Diagnostics
    31. 07-04-2013 09:33 AM #34
    32. Banner Advertiser SALES@RSW's Avatar
      Jun 28th, 2009
      Central NJ
      '13 Audi TTRS, '12 Q7 TDI, '04 MK4 R32
      07-10-2013 02:05 PM #35
      badass
