VWVortex.com - red "BRAKE" light blinking and can't figure it out.
    Results 1 to 10 of 10
    Thread: red "BRAKE" light blinking and can't figure it out.
      Oct 17th, 2012
      Findlay, Ohio
      06-12-2013 10:15 PM #1
      I bought a 2001 jetta 1.8t and the red "brake" light is blinking and goes beeeep beeeep beeep whenever the ignition is on.
      to my understanding it's because the e-brake is on while moving (not happening here)
      or
      low brake fluid, just topped it off.
      I swapped the brake fluid level sensor with my other jetta, and still the same thing, so i doubt its the sensor.
      so whats the deal!
    2. Member KG18t's Avatar
      Aug 9th, 2006
      Teh RVA
      1986 Mercedes 300E / 02 1.8T GTI / 12 Golf TDI / 12 Passat 2.5 SEL
      06-13-2013 03:39 PM #2
      there's a switch somewhere in the console on the e-brake handle mechanism. could be that.
      VW Vortex, the perfect place to get your daily dose of
      Oct 17th, 2012
      Findlay, Ohio
      06-13-2013 11:53 PM #3
      i'll check it out. thanks.
    4. Member mk3dream's Avatar
      Oct 11th, 2008
      london, ont
      mkiv: 20v, tdi jetta, tdi golf, 98 tdi jetta (parts)
      06-17-2013 12:05 AM #4
      hmm iv had this but it was break fluid level to low and u say u have toped it off.
      does the light turn on and begin beeping while the car is not in motion ?
      I POLISH INQUIRE
      Quote Originally Posted by .:R Wagon View Post
      Oh and i have a money tree,
      Oct 17th, 2012
      Findlay, Ohio
      06-17-2013 08:56 PM #5
      I checked the ebrake and the switch was fine from what I could see...
      and no you don't even need to be moving, the car doesn't even need to be running.
      key goes in
      turn ignition on
      light immediately blinks and beep beep beep
    6. Member KG18t's Avatar
      Aug 9th, 2006
      Teh RVA
      06-18-2013 12:17 PM #6
      did your check involve any actual diagnostic, or did you just look at it and say "hey, a switch, cool"
      edit: although, if the car is screaming at you without moving, it's not that. have you plugged any diagnostic stuff in? a vagcom will tell you what's going on.
      Oct 17th, 2012
      Findlay, Ohio
      06-18-2013 05:11 PM #7
      checked vag com, nothing....
      I pulled both switches out and checked the voltage reading inside the plugs. Both plugs showed 12 volts, so I know that they're connected with no breaks in the line.
      suck an ohm meter on the brake fluid sensor and played with the plunger and it showed the switch was working.
      On the e-brake. I manually pressed the switch with my finger while it was still in the wiring harness and the headlights did their blinking thing when you operate the ebrake... so I know that works.
      could it be that the gauge cluster is not getting voltage from the switches?
      Aug 10th, 2001
      Long Beach, CA
      17 Golf
      06-18-2013 05:24 PM #8
      Do your pads have sensors in them for wear? Is there a separate light for that?
      Also, I believe the '01's were subject to a recall for faulty ABS controllers. You'd have to have the dealer check that. If that's OK, it might be an ABS sensor even though the ABS light is not on.
      John
      I'd stop drinking beer, but I'm no quitter.
    9. Member VWBugman00's Avatar
      Mar 16th, 2009
      Kennewick Wa
      00 Beetle
      06-20-2013 12:02 PM #9
      Check your fuses. I had this happen too, and it was a fuse.
      2000 Beetle, 1991 CR-X, 2005 Chevy Malibu 3.5 LS, 1988 F-150 (R.I.P)
    10. Member
      Oct 17th, 2012
      Findlay, Ohio
      06-26-2013 06:30 PM #10
      solved the issue.....
      The abs fuze over the battery box was fried.
      and
      the passenger side rear abs sensor was broken
      the driver side rear abs sensor ring was missing...
      I replaced both wheel bearings, sensors, and the fuze...
      runs great!
