VWVortex.com - Arduino digi management!
    Results 1 to 16 of 16
    Thread: Arduino digi management!
    1. Member mveitenheimer's Avatar
      Sep 1st, 2007
      Holland, MA
      80 diesel caddy, 01 2500 ram cummins
      06-21-2013 12:19 AM #1
      Right now running simple code for rise on start and dump on key off.
      Still looking into rheostats for ride height, thought about using acuairs new sensors but I've heard horrible things about them so don't know what sensors ill be using for the active management.
      Will be upgrading to a arduino mega with a 16 relay break out board and ill have it networked with the UNO R3 for display output. This will allow me to use the R3 for a wideband controller and for gauge use. Ill keep you guys updated!
      Sent morse code via Hammer and Nail
      Quote Originally Posted by macleanshaun View Post
      Imagine a really fat girl putting on a big belt around her stomach, but tightening it WAY too tight. Her stomach will push both up and down out of the belt.
      haha
    2. Former Advertiser
      Feb 19th, 2010
      South Burlington, VT
      335i
      06-21-2013 11:26 AM #2
      Quote Originally Posted by mveitenheimer View Post
      VERY COOL!
      I too have spent some time playing with Arduino chips
      Apr 12th, 2007
      Phoenixville PA
      07 baggedwagon, now 12 GLI
      06-21-2013 12:12 PM #3
      Quote Originally Posted by Will@BagRiders View Post
      VERY COOL!
      love the coors light can gauges!!
    4. Member mveitenheimer's Avatar
      Sep 1st, 2007
      Holland, MA
      06-23-2013 12:22 AM #4
      Haha the vei gauges for podi's ASM fit perfect into the top lol!
      Yea I'm really excited about having full open control over my own management. Also not bashing the work of acuair and air lift but I'm also saving ~$1000+ by building my own system
      Also update! Just got my GSM shield in today ill be able to control the airride whenever wherever as long as there's cell service!
      haha
    5. Member treid's Avatar
      Mar 2nd, 2012
      SLC
      2.0l 20v
      06-25-2013 04:52 PM #5
      I'm really interested in this project and have an Arduino Mega sitting here unused, but don't have a lot of time to dedicate to it right now. I've looked online and haven't found many users claiming to use the Arduino for air suspension, but I think it would be a great application.
    6. Former Advertiser
      Feb 19th, 2010
      335i
      06-25-2013 04:54 PM #6
      Awesome. Interesting move going with a GSM shield vs a Wifi shield.. I like it
    7. Member Vee-DubbVR6's Avatar
      Jul 31st, 2007
      .:Kirkland, WA
      04 DBP R32T, 03 BMP 20thAE #0115, 92 GTi VR6, 07 Passat 3.6 4motion Sport Sdn, 11 F150 6.2 Limited
      06-25-2013 07:27 PM #7
    8. Member Niagara_V_Dub's Avatar
      Sep 25th, 2007
      Lemoore, CA
      hoopty on air
      06-26-2013 11:16 PM #8
      I was looking into doing this same thing, would you be able to give more insight or your schematics? I was think of using either LVTD's or maybe an enclosed ultrasonic sensor system. I'd love to hear some of the stuff that your thinking about and what you've done. Great work though, I love seeing geek and gearhead mind coming together as one.
      Insert witty quote
    9. Member treid's Avatar
      Mar 2nd, 2012
      SLC
      2.0l 20v
      06-26-2013 11:55 PM #9
      An ultrasonic sensor would be a poor choice for this application. Ultrasonic sensors really need a large, flat surface perpendicular to the sensor to make accurate meaaurements.
      The reason is the way these sensors work - they send out waves and rely on those waves bouncing back to the sensor. So underneath a car, you would have to find a spot to mount a sensor, a reflector, devise a way to keep them perpendicular to each other through the length of the suspension travel, develop an algorithm to convert measured distance to suspension height, etc. If you happened to accomplish all that, you're entire system would be foiled once brake dust or even water landed on the reflector. Driving in snow would be impossible.
      Stay with mechanical measurements.
      Sent from my PC36100 using Tapatalk 2
    10. Member treid's Avatar
      Mar 2nd, 2012
      SLC
      2.0l 20v
      06-26-2013 11:59 PM #10
      Just noticed you said "enclosed ultrasonic system." I guess if that somehow was implemented it would work, but I can't envision a robust, reliable solution... certainly not as simple as a potentiometer and lever.
    11. Member mveitenheimer's Avatar
      Sep 1st, 2007
      Holland, MA
      06-27-2013 02:45 AM #11
      Ultrasonics are a no, I've seen race teams (f series) try this and there measurements are always augmented some way. The expensive rout is laser. I won't be doing that.. Way to expensive $120+ per sensor. I just can't find a good cheap mech rheostat.
      I'm probably going to end up with Lincoln navigators sensors $60-$80 per. I thought of buying and using accuair's but I don't like their new design.
      Any other geekgearheads feel free to chine in!
      haha
    12. Member mveitenheimer's Avatar
      Sep 1st, 2007
      Holland, MA
      06-27-2013 02:47 AM #12
      Also a nice kickback, I've incorporated into the code do with the right pass code, I can now start the car!
      Possibilities are endless!
      haha
    13. Member rgarjr's Avatar
      May 19th, 2012
      Los Angeles area
      Lexus GS300
      06-27-2013 02:56 AM #13
      Post a YouTube vid of your setup.
      Instagram: @rgarjr
    14. Member mveitenheimer's Avatar
      Sep 1st, 2007
      Holland, MA
      06-27-2013 03:02 AM #14
      Quote Originally Posted by rgarjr View Post
      Right now most everything is still being coded so still beta, but the presets and key on and off work ill post that up by tomorrow,
      I'll post up some of the code too
      haha
    15. Member Niagara_V_Dub's Avatar
      Sep 25th, 2007
      Lemoore, CA
      hoopty on air
      06-27-2013 04:02 AM #15
      Quote Originally Posted by treid View Post
      yeah, the vision I had in my head of it was a cylinder with the sensor hard mounted to the car and the cylinder would move up and down on a suspension point. You could calibrate it from full down to full up and control it based on a percentage map or something.
      But it for now is just a project in my head cause every sensor type has a brutal downfall... wether it be sensitivity, price, ambiant light or road noise...
      But now this thread has inspired me to go buy a raspberry pi and make my own air gauge display. For now the controller aspect of it might be too tall of an order for my skill level.
      But OP, thank you for the inspiration. Keep going with it and keep us posted.
      Insert witty quote
    16. Member
      May 30th, 2010
      Germany
      1980 W126, 1983 MK2, 2010 Passat Wagon
      09-01-2013 06:05 PM #16
      Really like your idea. Thought about it for a few days too.
      Just ordered an Arduino, as I'd like to have V2 Autopilot, but I can't.
      My MK2
      • FVCKD FB | Flickr | IG/
      • IG: @schvmo
