VWVortex.com - vr6 cylinder 6 misfire
    Results 1 to 6 of 6
    Thread: vr6 cylinder 6 misfire
    1. Member chopper63d's Avatar
      Mar 31st, 2010
      norwalk ca
      1996 vw golf gti vr6
      06-22-2013 06:59 PM #1
      my 96 golf vr6 has a cylinder 6 misfire. Reason i know is because i scan the OBD2 and the cylinder 6 misfire comes out. On the actual car its not extremely noticeable. The CEL doesn't blink, doesnt have a extreme loss of power or doesnt have a extreme bad idle. Everything is mild. At idle u can hear a putt putt every once in awhile. Ive change the spark plugs and the wires. I've went from the OEM ICM to the Ford (taurus) ICM to the Ford (mustang) ICM. yet the code still goes off. Any idle what else it might be?
      MK3 Golf Vr6, autotech cams, giac chip, headers, 3" exhaust, etc..etc...
    2. Angry Turtle Administrator nater's Avatar
      Apr 10th, 2000
      2008 3.6L Passat 4Mo, 98 O2M 3.0L VRT, '04 .:R32, 2010 Routan
      06-22-2013 08:52 PM #2
      How does the #6 plug look?
    3. Member chopper63d's Avatar
      Mar 31st, 2010
      norwalk ca
      09-28-2013 08:27 PM #3
      okay so here the picture of the number 6 spark plug
      here a video to see how it sounds
      http://www.youtube.com/watch?v=yEhEq5JUnqc
      excuse the mild knocking, its the tranmission, im waiting for it to give out. have another one ready to go.
    4. Member
      Feb 13th, 2012
      Ohio
      '96 Golf Harlequin, '90 Corrado G60
      09-29-2013 03:45 AM #4
      Hook a vacuum gauge up to it and see what the vacuum is at idle. Its should be higher than 25" pounds. If not, then you have a vacuum leak, either an intake gasket or a vacuum hose.
      Her name is Skiddles. When you see her, you'll know why
    5. Member chopper63d's Avatar
      Mar 31st, 2010
      norwalk ca
      09-30-2013 09:30 AM #5
      Bump!
      still in the process of checking for vac
    6. Member chopper63d's Avatar
      Mar 31st, 2010
      norwalk ca
      10-01-2013 09:51 AM #6
      Bump for oct 1st
      also this morning i had a mild back fire for the intake... the first ive heard or felt
