VWVortex.com - Whining noise. Ideas?
    Results 1 to 13 of 13
    Thread: Whining noise. Ideas?
    1. Junior Member
      Aug 9th, 2008
      South Jersey
      Candy White 08 GTI 2dr 6sp
      07-02-2013 09:11 PM #1
      Here's the deal:
      2008 GTI FSI 6 speed with just over 60k.
      Almost completely stock, just a K&N panel filter. Timing belt, tensioner,& water pump replaced under powertrain warranty at 50k for a ticking tensioner.
      I'm getting a whining noise. Rev dependent, but not speed dependent, so I've narrowed it down to the rotating assembly. Seems to only last for the first few minutes the engine is running, then fades away.
      No knocking, unusual ticking, CELs, or notable loss of performance.
      I'd expect a alternator bearing to continue the whole time while driving. Could be a power steering pump, but no steering performance issues. Noise doesn't change with AC on or off.
      I'm afraid it's a turbo issue(bearing or oiling). The car is paid off, and I'd rather not pick up a new payment. But I'm not planning on dropping major coin to rebuild motors or replace turbos.
      Any thoughts or similar experiences?
    2. Member Tutti57's Avatar
      Jun 20th, 2011
      Rochester, NY
      2006 Passat 2.0T, 2003 Audi A6 3.0
      07-02-2013 10:21 PM #2
      Do you have a boost guage? If so, is it making normal amount of boost?
      Does the noise get louder when you turn the wheel or under load or boost?
      2006 Passat 2.0T Tiptronic | Unitronic Stage 2 | DG Springs | Newsouth Boost Gauge | BFI Tranny Insert | Rev D DV | BSH PCV fix | eBay Downpipe w/cat | Autotech Exhaust | DDM HIDs | Bentley Manual | VCDS - Car for sale! $6,000
      2003 Audi A6 3.0
    3. Junior Member
      Aug 9th, 2008
      South Jersey
      07-02-2013 11:14 PM #3
      No boost gauge.
      Noise does not seem to change when turning.
      Noise changes with rpms, but doesn't seem to get louder as much as higher pitched. Haven't noticed a difference under load.
    4. Banner Advertiser Paul@DeutscheAutoParts's Avatar
      Oct 26th, 2012
      Charlotte NC
      MK7 GTI, 90 Corrado 16vt
      07-05-2013 10:58 AM #4
      Quote Originally Posted by devilfluff View Post
      No boost gauge.
      Sounds like it could be a PCV valve issue
      Has yours been replaced? If yes when and what version is on your car now. These are the 2 most current versions.
      If you dont know which one is correct for your vehicle I can run your vin to check.
      http://www.deutscheautoparts.com/Vie...101-E/0/139939
      http://www.deutscheautoparts.com/Vie...101-L/0/139938
      ShopDAP.com ---------Deutsche (DOY-chuh) Auto Parts----------All VW part numbers are searchable on our site.
      Follow us on Instagram-------- Twitter --------Facebook--------- YouTube
      Oct 19th, 2006
      Coquitlam, BC Canada
      2006 Jetta 2.0T
      07-05-2013 12:11 PM #5
      It's not a power steering pump, your car doesn't have one. Pull the accessory drive belt and run the car briefly. This will confirm or eliminate: alternator bearings, AC ?, and the belt tensioner and pulley. If the problem is sill there. Run the motor with the timing belt inspection cover off, see if it gets noisier, the new parts under the timing belt cover could be the problem too.
    6. Junior Member
      Aug 9th, 2008
      South Jersey
      07-06-2013 11:28 PM #6
      Quote Originally Posted by Paul@DeutscheAutoParts View Post
      The PCV was done under warranty in January of '12. Looks like part# 06F129101P. The repair receipt notes TSB 202745413 and shows 2 valves(PCV & a check valve).
    7. Junior Member
      Aug 9th, 2008
      South Jersey
      07-06-2013 11:32 PM #7
      Quote Originally Posted by cameron2pt5 View Post
      Thanks. I should have thought to give it a quick run with the belt off. I'll give that a go on my day off.
    8. Junior Member
      May 26th, 2010
      Miami, FL
      07-09-2013 10:41 AM #8
      I'm currently having a similar issue with my car. When I start up the car while the engine is cool, I get squeaking for a little bit until the engine warms up, then it fades away. I am convinced it's my timing belt tensioner since I'm at 69k now and is a common issue around that mileage.
    9. Banner Advertiser Paul@DeutscheAutoParts's Avatar
      Oct 26th, 2012
      Charlotte NC
      07-09-2013 10:55 AM #9
      Quote Originally Posted by adg968 View Post
      Could be you would have to take it apart to check. This would help you diagnose where the noise is coming from http://www.amazon.com/TEKTON-5888-Me...ve+stethoscope
      Here is an OEM Timing belt kit if you are in need.
      http://www.deutscheautoparts.com/Vie...-A/1792/140018
    10. Junior Member
      May 26th, 2010
      Miami, FL
      07-09-2013 11:17 AM #10
      I heard you also have to replace the waterpump when replacing the timing belt. Do you have a kit that includes the waterpump with the timing belt?
    11. Member
      Jun 30th, 2011
      Yorktown, Va.
      2016 TR Golf R 2013 RB Golf R-sold 2004 Blue GLI-sold
      07-12-2013 01:28 PM #11
      Your t-belt is most likely causing the squeak you're experiencing. If you remove the cover and take a small amout of water and drop a small amount on the belt and it will quit till the belt dries.
      2004 GLI
      Euro Pros Auto Repair
      http://europrosautorepair.com
    12. Junior Member
      May 26th, 2010
      Miami, FL
      07-16-2013 02:10 PM #12
      Quote Originally Posted by Jayj View Post
      Thanks. I'm on the mission of finding a reliable belt kit with the waterpump. I've heard it's wise to replace the timing belt and related components with OEM parts rather than aftermarket.
    13. Banner Advertiser Paul@DeutscheAutoParts's Avatar
      Oct 26th, 2012
      Charlotte NC
      07-16-2013 05:40 PM #13
      Here is a Genuine VW Tbelt Kit for 25% off for your 2.0T fsi engine
