VWVortex.com - a3 abs coding login help
    Results 1 to 16 of 16
    Thread: a3 abs coding login help
    1. n00b
      Jul 15th, 2013
      uk
      07-15-2013 11:49 AM #1
      hi guys,
      I have a 2010 a3 2.0tdi and I am trying to put the longing coding into the abs but I am unable to login. can anyone help me with this.
      below is a full vcds scan. after is the option codes
      Wednesday,10,July,2013,18:12:01:24293
      VCDS Version: Release 11.11.6
      Data version: 20121223
      Chassis Type: 7N0
      Scan: 01 03 08 09 10 14 15 16 17 19 25 42 44 46 52 55 56 61 62 72
      77
      VIN: WAUZZZ8P6AA129100 Mileage: 26320km/16354miles
      01-Engine -- Status: Malfunction 0010
      03-ABS Brakes -- Status: Malfunction 0010
      04-Steering Angle -- Status: OK 0000
      08-Auto HVAC -- Status: OK 0000
      09-Cent. Elect. -- Status: OK 0000
      10-Park/Steer Assist -- Status: OK 0000
      14-Susp. Elect. -- Status: Malfunction 0010
      15-Airbags -- Status: OK 0000
      19-CAN Gateway -- Status: OK 0000
      42-Door Elect, Driver -- Status: OK 0000
      46-Central Conv. -- Status: OK 0000
      52-Door Elect, Pass. -- Status: OK 0000
      55-Xenon Range -- Status: OK 0000
      56-Radio -- Status: OK 0000
      61-Battery Regul. -- Status: OK 0000
      62-Door, Rear Left -- Status: OK 0000
      77-Telephone -- Status: OK 0000
      Address 01: Engine (J623-CFFB) Labels: 03L-906-018-CFF.clb
      Part No SW: 03L 906 018 AB HW: 03L 906 018 AG
      Component: R4 2,0L EDC H25 9041
      Revision: 41H25--- Serial number: AUX7Z0L1FNA0AV
      Coding: 00190032042501080000
      Shop #: WSC 12345 123 45725
      ASAM Dataset: EV_ECM20TDI01103L906018AB 003008
      ROD: EV_ECM20TDI01103L906018AB.rod
      VCID: 6AD015FF8D210C489EF
      1 Fault Found:
      5250 - Function Restriction due to Received Malfunction Value
      U1113 00 [039] - -
      Not Confirmed - Tested Since Memory Clear
      Freeze Frame:
      Fault Status: 00000001
      Fault Priority: 6
      Fault Frequency: 1
      Mileage: 26326 km
      Date: 2013.07.10
      Time: 18:33:51
      Readiness: 0 0 0 0 1
      Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
      Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
      Component: ESP MK60EC1 H31 0121
      Revision: 00H31001
      Coding: 00000000000000000000000000000000000000
      Shop #: WSC 06314 000 00000
      VCID: 7BFE20BBFABB85C0759
      1 Fault Found:
      01042 - Control Module; Not Coded
      000 - -
      Freeze Frame:
      Fault Status: 01100000
      Fault Priority: 2
      Fault Frequency: 1
      Reset counter: 223
      Mileage: 1048575 km
      Time Indication: 0
      Date: 2013.07.11
      Time: 09:28:35
      Freeze Frame:
      Count: 3
      Count: 0
      Count: 20992
      Count: 195
      Count: 44032
      Count: 0
      Count: 0
      Count: 0
      Address 08: Auto HVAC Labels: 8P0-820-043.lbl
      Part No SW: 8P0 820 043 BM HW: 8P0 820 043 BM
      Component: KlimavollautomatH09 0180
      Revision: 000681 Serial number: 8P0820043BM
      Shop #: WSC 00000 000 00000
      VCID: 78F43FB70B8DAED818B
      No fault code found.
      Address 09: Cent. Elect. (J519) Labels: 8P0-907-063.clb
      Part No SW: 8P0 907 063 N HW: 8P0 907 063 N
      Component: BCM PQ35 M 110 0667
      Revision: AJ110667
      Coding: 4E000A2FA005F0C0207041E00100095C427E2BAA206DD12AE4 008F840041
      VCID: 3F8694ABAE2359E0191
      Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
      Component: Wischer AU350 H11 0050
      Coding: 00DD13
      Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 A Labels: 8K0-955-559.CLB
      Component: REGENLICHTSEN H04 0003
      Coding: 024C2D
      Subsystem 3 - Part No: 8P0 951 177
      Component: Innenraumuebe H04 0020
      Subsystem 4 - Part No: 1K0 951 605 C
      Component: LIN BACKUP HO H05 1501
      Subsystem 5 - Part No: 1K0 907 719 C
      Component: Neigungssenso 005 0003
      Address 10: Park/Steer Assist (J446) Labels: 8P0-919-475-7X1.clb
      Part No SW: 8P0 919 475 M HW: 8P0 919 475 M
      Component: PARKHILFE 4K H01 0140
      Revision: 11001001 Serial number: 36861203601279
      Coding: 000003
      VCID: 48948F77FBED1E58A8B
      Address 14: Susp. Elect. Labels: 8P0-907-376.lbl
      Part No SW: 8P0 907 376 A HW: 8P0 907 376 A
      Component: J250 Raddaempfung 0060
      Revision: --H04--- Serial number: 190DPH 1294127
      Coding: 0000141
      VCID: 3972FAB3700777D0275
      1 Fault Found:
      01316 - ABS Control Module
      013 - Check DTC Memory - MIL ON
      Freeze Frame:
      Fault Status: 11101101
      Fault Priority: 2
      Fault Frequency: 1
      Reset counter: 223
      Mileage: 26326 km
      Time Indication: 0
      Date: 2013.07.10
      Time: 18:52:01
      Freeze Frame:
      Voltage: 12.48 V
      Speed: 0.0 km/h
      Voltage: 4.99 V
      Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
      Part No SW: 8P0 959 655 S HW: 8P0 959 655 S
      Component: Airbag AU1042 H10 0250
      Revision: -------- Serial number: 003JU0062DPC
      Coding: 30314238303830303037554A305238503053
      ASAM Dataset: EV_Airba10AURB4 001001
      ROD: EV_Airba10AURB4.rod
      VCID: 52A0AD1F05B1A488C6F
      Crash sensor for side airbag; driver side:
      Serial number: 3572DRB40000E720698W
      Crash sensor for side airbag; passenger side:
      Serial number: 3582DRB40000E71451FY
      Crash sensor for side airbag; rear driver side:
      Serial number: 35128RB4000068AC637R
      Crash sensor for side airbag; rear passenger side:
      Serial number: 35228RB4000069611EER
      Crash sensor for front airbag; driver side:
      Serial number: 35547RB400006909ED7
      Crash sensor for front airbag; passenger side:
      Serial number: 35647RB400006909EDE3
      Address 16: Steering wheel Labels: 8P0-953-549.lbl
      Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
      Component: J0527 H38 0070
      Coding: 0004042
      VCID: 4688814F31F908285A7
      Part No: XXXXXXXXXXX
      Component: E0221 H06 0030
      Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
      Part No SW: 8P0 920 983 HW: 8P0 920 983
      Component: KOMBIINSTR. VDO H03 0150
      Revision: D0H03002 Serial number: 2241L002017419
      Coding: 0324428
      VCID: F7F6BC8B869321A0911
      Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
      Part No SW: 7N0 907 530 N HW: 1K0 907 951
      Component: J533 Gateway H43 1623
      Revision: H43 Serial number: 280112F2001805
      Coding: 352103
      VCID: 3B7EE0BBBA3B45C0359
      Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
      Revision: D0H03002 Serial number: AUX7Z0L1FNA0AV
      Shop #: WSC 00137 211 56823
      Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
      Part No SW: 8P0 959 801 P HW: 8P0 959 801 P
      Component: Tuer-SG H04 0101
      Coding: 0131764
      VCID: 48948F773BED1E58A8B
      Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
      Part No: 1K0 909 144 P
      Component: EPS_ZFLS Kl. 232 3305
      Revision: 00H22000
      Shop #: WSC 02069 000 90108
      VCID: 3776FC8B461361A0D11
      Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
      Part No SW: 8P0 959 802 P HW: 8P0 959 802 P
      Coding: 0131764
      VCID: 49928A7320E7E750B75
      Address 55: Xenon Range (J431) Labels: None
      Part No SW: 8X0 907 357 C HW: 8X0 907 357 B
      Component: ****LWR12**** H02 0012
      Serial number: 120125-0002-101
      Coding: 11635F1010002100
      ASAM Dataset: EV_HeadlRegulBasic 005001
      ROD: EV_HeadlRegulBasic_AU35.rod
      VCID: 42809D5FD5D1340876F
      Address 56: Radio Labels: 8J0-035-1xx-56.clb
      Part No SW: 8P0 035 186 AB HW: 8P0 035 186 AB
      Component: R Concert2+ H05 0293
      Revision: 00H05000 Serial number: AUZ1Z3M3009800
      Coding: 0710101
      VCID: 72E00D9F6DF1C48826F
      Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
      Part No SW: 7N0 907 534 HW: 1K0 907 951
      Component: Batt.regelung H43 1623
      Coding: F30F185A
      VCID: F1E2829328F77F905F5
      Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
      Component: J367-BDM H07 0180
      Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
      Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
      Component: Tuer-SG H04 0050
      Coding: 0131216
      Shop #: WSC 06314 000 1012544
      VCID: 42809D5F1DD1340876F
      Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
      Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
      Coding: 0131216
      VCID: 438E985B02CB3D007D9
      Address 77: Telephone Labels: 8P0-862-335.lbl
      Part No SW: 8P1 862 335 A HW: 8P1 862 335
      Component: FSE_256x BT H44 0660
      Revision: 00000000 Serial number: 00000005498830
      Coding: 0001222
      VCID: 356AF6835C1F93B0C3D
      End ---------------------------------------------------------------------
      list of option codes:-
      eoa 7a0 4uf 6xj 5sj 5ru 1kd j2d 1ze 1at 3fa ua6 g28 5tl 7x1 4r4 foa 8gu oye l55 tl4 3nz 8bp u1b x2b 1n3 2pf 8q3 9q7 8z5 d91 7q0 c1b 7k0 4x3 3l3 vw1 3y6 4k4 5d1 1sa ug3 7mg qg1 4gp
      thanks in advance guys
    2. 07-15-2013 12:13 PM #2
    3. n00b
      Jul 15th, 2013
      uk
      07-15-2013 12:45 PM #3
      far from that......
      lost key, made new key with avdi (genuine not cheap clone). long coding zero'd .
      I have coding just don't have login code so I can input it.
      regards
    4. 07-15-2013 12:51 PM #4
    5. n00b
      Jul 15th, 2013
      uk
      07-15-2013 01:40 PM #5
    6. 07-15-2013 01:53 PM #6
    7. n00b
      Jul 15th, 2013
      uk
      07-15-2013 02:28 PM #7
    8. 07-15-2013 02:37 PM #8
    9. n00b
      Jul 15th, 2013
      uk
      07-15-2013 03:09 PM #9
    10. 07-15-2013 03:14 PM #10
    11. n00b
      Jul 15th, 2013
      uk
      07-15-2013 07:04 PM #11
    12. 07-15-2013 09:40 PM #12
    13. Member
      Apr 12th, 2010
      Lodz, Poland
      2011/Skoda/Superb 2 Combi 2.0 TDI 170
      07-18-2013 04:04 PM #13
    14. 07-18-2013 04:33 PM #14
    15. Member
      Feb 11th, 2004
      Magdeburg, Germany
      '67 Ford Mustang Conv.
      07-18-2013 05:05 PM #15
      @sg33, we've received your email though we have not had the time to look into it closer. Please give us some more time to respond.
    16. 07-18-2013 05:11 PM #16
      This thread seems to have run its course.
      I think this forum needs need a "No Bickering" rule.
    « Back
