VWVortex.com - Temperature gauge reads hot when the engine is not overheating
    Results 1 to 7 of 7
    Thread: Temperature gauge reads hot when the engine is not overheating
    1. Member tg442's Avatar
      Jul 13th, 2010
      emkaytree 2.turbo
      07-27-2013 04:47 PM #1
      I have a obd1 aba engine that says its overheating when it is not. I changed the waterpump a month/500 miles ago and did a full coolant flush. I already changed the coolant temp sensor but I feel like that has only made it worse. The temp gauge will rise as the engine warms up sometimes it stops at 190 and slowly rises to 230 sometimes it goes straight to 230. After warming up for a little bit I check the hoses and the thermostat hasn't even opened because the hose before it is hot and after is cold. When the thermostat opens the gauge either goes back to 190 only to rise to 230 again or just stays at 230. I know for sure the engine isn't overheating because the gauge will say its well past 230 but the engine is barely even warm and there's no other signs of overheating. Is it possible that another faulty coolant temp sensor could be doing this?
      Whenever i see another VW I follow them home, wait untill they are asleep, sneak in, lay next to them and wake them up while tounging their ear and whisper I have a VW too.
      Then I rape them then leave.
      Mar 6th, 2002
      Morris Plains, NJ
      1998 GTI 2.0T
      07-27-2013 06:27 PM #2
      Do you have good heat? Does temp go down when heat is put on full blast?
      Use an IR temp gun to verify actual temps. Could be a sticky thermostat and the engine is actually running hot but lower hose is still cold.
      2012 Corolla
      1998 GTI 2.0T
      World Automotive
    3. Member tg442's Avatar
      Jul 13th, 2010
      emkaytree 2.turbo
      07-27-2013 06:43 PM #3
      The heat works perfectly. When I turn the heat on all the way it has no effect on the temperature. Also I can feel when the thermostat opens because the hose will get warm but the temperature gauge stays wherever it was pegged to.
    4. Member
      Mar 23rd, 2008
      N/A
      N/A
      07-28-2013 01:36 PM #4
      Have you tried replacing the temperature sensor?
    5. Member tg442's Avatar
      Jul 13th, 2010
      emkaytree 2.turbo
      07-28-2013 06:43 PM #5
      Yeah that was the first thing I replaced. I think it might me the thermostat now so I'm trying to replace that but it's such a pain in the ass.
    6. Member tg442's Avatar
      Jul 13th, 2010
      emkaytree 2.turbo
      07-29-2013 07:45 PM #6
      Took the thermostat out and tested it in boiling water and its fine. I just changed my waterpump a month ago but my car still overheats. The fan doesn't come on when the car warms up so I used a paper clip to jump the fan at the thermoswitch by the radiator and it turned on. Can an air bubble in my cooling system be causing this? I tried to get all the air out do I just have to leave the cap off over night and hope for the best?
      Mar 6th, 2002
      Morris Plains, NJ
      1998 GTI 2.0T
      07-30-2013 09:47 AM #7
      Quote Originally Posted by tg442 View Post
      Yes an air pocket certainly could cause it. Sometimes these cars are a real pain to burp.
      Leaving the cap off overnight is a good idea.
      2012 Corolla
      1998 GTI 2.0T
      World Automotive
