VWVortex.com - turbo problems! 1.8t
    Results 1 to 3 of 3
    Thread: turbo problems! 1.8t
    1. Junior Member willye_br's Avatar
      Jan 10th, 2012
      Boston, ma
      2001 Jetta GLS Wolfsburg 1.8T
      08-26-2013 10:41 AM #1
      Ok i have a 01 jetta wolfsburg with a AWW engine code.
      i have :
      FMIC
      HKS bov
      turbo inlet
      Unitronic stage 2
      Boost controller
      stage 1 clutch kit from ECS
      So the problem im having is weird. When i take off from a stop sometimes i will hear the turbo spool up loud and the bov does the PSHHHH but i never let go of the gas.I take off and i press the gas slow and even and as the car starts going ONLY SOMETIMES boost will build quick and the bov just randomly opens without me even letting go of the gas. Most will say get rid of the MBC and the HKS .. well guess what with the N75 in place AND the forge DV it does exactly the same thing. so it cant be them. what could it be any ideas?
      Also it was doing it it before i got the chip in!
      maybe a bad wastegate ?
      BoOsT Gets You LaId !
    2. Member Soundwave_vr6's Avatar
      Sep 30th, 2007
      Ontario
      3.6 4mo
      08-26-2013 11:30 AM #2
      maf
      mine did the same. all good with new maf
    3. Junior Member willye_br's Avatar
      Jan 10th, 2012
      Boston, ma
      08-26-2013 12:49 PM #3
      Quote Originally Posted by Soundwave_vr6 View Post
      maf
      weird tho i replaced the maf like 6 months ago and car runs perfect even fuel trims are good. and i check MAF with VCDS and it reads fine.
