    Results 1 to 3 of 3
    Thread: G60 Idle Stabilizer Valve (ISV) 037906457"A" 037906457"C" vs 037906457"D" vs 037906457"F"
    1. Member petethepug's Avatar
      May 25th, 2001
      So Cal
      Orig Owner 90 G60 & 02 Allroad 6Sp Man w/ 3rd Row Seat
      09-14-2013 02:09 PM #1
      VAG is price gouging on the Idle Stabilizer Valves (ISV) used on almost every VW Audi and Porsche that uses them. The aftermarket Mfg's in China are selling these generically for $35-$75.
      Back in the day when VW, Porsche and Audi used to share part numbers the price jacking wasn't as bad. Audi has completely superseded the 037906457 from it's parts directory. It's notorious for using Audi specific part numbers on the same part. The difference can be 100's $$.
      As long as a dual pin terminal ISV is purchased is will work on the G60. Right now there is a lot of cheap new old stock on these (NOS). Buy em up now G60 owners.
      VAG has a stock replacement listed on the 80/90 Q for over $700. A, C, D & F are all the same except that C has its lateral port located on the top plane of the part instead of the bottom (as seen below).
      Old Skool 035133455"A" in black
      Old Skool 035133455"A" in silver
      Look to buy a new one by the OEM VDO/Siemens part # 408 202 011 002 Z or 408 202 011 003Z
      • HELLA: 6NW009141161
      • OEM: 408202011002 247319
      • STANDARD: AC406
      • VAG: 037906457C
      • VDO: 408202011002Z or 408 202 011 003Z
      Don't forget to search with and without a space every 3rd digit or letter to get more results.
      ¡¡ opɐɹɹoɔ ǝɥʇ!!!ƃuıʇɔǝdsǝɹ !!!
      !! odarroɔ ǝht gnitɔepser !!
      Feb 13th, 2012
      Ohio
      '96 Golf Harlequin, '90 Corrado G60
      09-14-2013 10:28 PM #2
      Where would we search for these? Amazon/ebay, parts stores, online stores?
      Her name is Skiddles. When you see her, you'll know why
    3. Member petethepug's Avatar
      May 25th, 2001
      So Cal
      09-14-2013 11:16 PM #3
      Plugged in 037906457C on eBay to start
      http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
      Googled 408202011002Z
      https://www.google.com/search?q=4082...16%3B575%3B465
      Started clicking on the pics and got it turned out to be a vortex seller .. Sent the link via pm
