I have this 80 Rabbit 1.7 gasser. The other day the fan decided not to kick on and I heated up real quick and was almost bad... anyway..
I've tested the fan and it's good. I have tested the circuit from the thermo rad switch plug by jumping the plug and the fan comes on, indicating that the circuit is good. I just don't understand why the rad switch would be bad. It has less than 5k miles.
So tonight I am planning to replace the thermo rad switch, got a new one today.
Do these really go bad like that? Also only water was ran in the car no coolant. I know I need to get some coolant in it before it freezes.
Could the water pump have gone bad causing the car to get hot fast but not the coolant/water thus causing the switch not to make the fan come on?
Jumping the thermo switch by arcing the 2 external post is just bypassing the thermo switch not testing it to see if it's good.
& yes they go bad like that.
Most likely NOT the water pump. Now the thermostat might be bad & they all have different opening temps. You can test that by sticking it into a boiling pop of water & see if it opens at the temp they water says. Thermostat opening temp is marked on them
Could it be that the water pump isn't moving hot water to the thermo rad switch to turn it on, the water just not moving, and the rad didn't get to cool it?
When you run JUST water in your system, it can do massive damage quickly. Why? The coolant does much more than prevent freezing. It prevents electrolysis in the system. Basically your cooling system acts like a battery. The aluminum reacts with the water, the brass, etc. It eats these things away.
I have seen some WEIRD failures because of just water only. Parts wear out much quicker. And if your grounds are less than perfect, this happens even faster. Putting anti-freeze in there helps control this and prevent the electrolysis.
In fact, I ran my system like this once during middle of summer. I had to replace a thermostat and thermos switch, and didn't have any coolant kicking about so I ran just water. I was all "It will be okay tell next oil change..." In under 3k it had eaten both the new thermostat and thermotime switch failed again, and the system had to be flushed it was so fugly.
or just buy the 50/50 mix stuff. works just fine for me.
Related Threads
Ask a question
Ask a question
VW Vortex - Volkswagen Forum
84.4M posts
1.5M members
Since 2001
