VWVortex.com - Found! CIS Brake Booster check valve
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 31
    Thread: Found! CIS Brake Booster check valve
    1. Member teknikALLEN's Avatar
      Jul 14th, 2010
      Ithaca, NY 14850
      2001 VW Jetta; 1985 VW Cabriolet; 1993 VW Cabriolet; 1984 VW Gti.; 1988 VW Golf
      10-01-2013 03:02 PM #1
      I cracked this sucker two years ago and "fixed" it with some silicon. I have had a variable idle ever since...
      I finally found what appears to be an exact replacement with the small port for the HVAC. Even manufactured in Germany.
      AC Delco part # 90304535.
      Quote Originally Posted by briano1234 View Post
      I would rather do a 3 rear cables than a passenger side motor mount.
      020ld for this stuff... a clutch and 5th gear conversation with Broke VW
      My MkI & Cabby WTB Wish List
      Jetta MkIV WTB Wish List
    2. Member rabbitnothopper's Avatar
      Oct 19th, 2009
      D-Town REPRESENT : Texas
      RIP81. 78 VW Rabbit 1.5L EH 4speed 020 GC->GP, 82 Rabbit Pickup 1.6D
      10-01-2013 07:22 PM #2
      yeah strange that VW parts sellers cant figure it out
    3. Member teknikALLEN's Avatar
      Jul 14th, 2010
      Ithaca, NY 14850
      10-01-2013 09:12 PM #3
      It has a GM part # too. Used on some Cadillacs I believe.
      It was crazy no one has posted this before.
    4. Member briano1234's Avatar
      Feb 20th, 2004
      Atlanta Ga
      90, 92, 93 Cabriolet They own you.
      10-01-2013 11:04 PM #4
      Now thanks to you when the CRACK pipe gets broken, we can use a new part to re-make the hose...
      WELL Done.
    5. Member flipty's Avatar
      Mar 5th, 2012
      St. Paul, MN
      88 Cabby daily driver
      10-03-2013 02:05 PM #5
      anyone care to quickly explain what this one does, and why a brake booster would affect idle? Every time I see a cheap part like this I feel like buying it and replacing the one I have because it's sure to eventually fail.
    6. Member Moltenburn's Avatar
      Jun 29th, 2010
      Denver
      2013 Platinum Grey Passat TDI SE 6-spd, 2013 Denim Blue Beetle, 1991 Inka Blue Cabriolet
      10-03-2013 03:33 PM #6
      2nd on Flipty's ??? and Any chance we can have Kam add this to Cabby-info?
    7. Member briano1234's Avatar
      Feb 20th, 2004
      Atlanta Ga
      10-03-2013 06:43 PM #7
      That is the vacuum check valve that in attached to the hard plastic (CRACK) line, the line breaks and leaks vacuum. It powers the brake booster, and remember class Any Vacuum leak on the cabby is a bad thing and causes all kinds of mischief.
      That check valve also contains the 2 vacuum off shoots that get man handled and broken also.
      Having one when you break the line at 2:30 in the morning.... well that is a good thing.
    8. Member Kevin Rowley's Avatar
      Sep 6th, 1999
      Georgia
      1987 Cabriolet
      10-03-2013 07:52 PM #8
      $10 on Rock Auto. Buy 2. Replace the one in the car and keep the other in the box of spares in your garage. (You DO have a box of spares, don't you?)
      2005 MINI Cooper S
      2004 Volvo C70 LPT
      1987 Cabriolet Bestseller
    9. Member flipty's Avatar
      Mar 5th, 2012
      St. Paul, MN
      10-03-2013 11:03 PM #9
      Looking under my hood tonight I saw a valve that looks exactly like that, but it was going into the front of the air intake manifold. Mine is CRUSTY and looks like it's going to turn to dust. Is that the one?
      That one?
    10. Member kamzcab86's Avatar
      Feb 13th, 2002
      Arizona
      1986 Cabriolet Best Seller; 1990 Vanagon Westfalia; 2016 Golf GTI S
      10-03-2013 11:26 PM #10
      Quote Originally Posted by Moltenburn View Post
      Made a note to add it (and Brian's brake clips) info with the next update ... which probably won't be for another 2 weeks 'cuz I'm busy with other stuff.
      Cabby-Info.com -- Your online guide to VW Cabriolets/Rabbit Convertibles
      Old Blue's Blog -- The adventures of a 1990 Westfalia
      "Fashion is a waste of money that could be better spent on, say, maintaining your car." ~James May
    11. Member Moltenburn's Avatar
      Jun 29th, 2010
      Denver
      10-04-2013 10:22 AM #11
      Quote Originally Posted by kamzcab86 View Post
      Cool and thank you. Future parts being categorized to avoid future headaches
    12. Member flipty's Avatar
      Mar 5th, 2012
      St. Paul, MN
      10-10-2013 02:52 PM #12
      I got my new valve in the mail, and I am going to install it, but I figured this would be a good time to ask about the following questions....
      the blue arrow points to..... what IS that thing, and what good can it possibly do sitting there on its own? Does it vent vacuum or something? Is it a sensor of some sort?
      The green arrow, I know what that is, but it was already in my image...so never mind that one.
      The RED arrow, that's some sort of a right-angle adapter monstrosity, is it not? that line is a Frankenstein of several different diameters of vacuum line and that thing that looks like a check valve, but is what... just an adapter? If that's just an adapter of some sort I'd love to replace that whole line to the brake booster with just a single brand new vacuum line.
      Any idears?
    13. Member
      Oct 18th, 2002
      Bainbridge Is., WA
      '00 Jetta TDI, '86 Cabby, '95 F150, '98 Outback
      10-10-2013 09:32 PM #13
      Red arrow: yep, a monster of an adapter. The factory piece was a hard, molded plastic pipe that was shrunk over the check valve at one end, and a different plastic nozzle on the other end, which pressed into a grommet on the booster.
    14. Member flipty's Avatar
      Mar 5th, 2012
      St. Paul, MN
      10-11-2013 01:21 PM #14
      Does anyone happen to know the ID on both sides of that hose so I can get the right piece(s)?
    15. Member rabbitnothopper's Avatar
      Oct 19th, 2009
      10-11-2013 07:47 PM #15
      Quote Originally Posted by flipty View Post
      Any idears?
      actually the red arrow device comes on new vacuum assisted brake boosters
      typically your hose goes into the brake booster with a straight valve
      instead remans shove a 90*degree one way valve in there for you
      and it explicitly says on the label "Do not remove"....
      i have seen the blue arrow before
      but i dont know what it is really
      apparently it is an electronic valve that syphons vacuum...probally an idle or wot adjuster
    16. Member flipty's Avatar
      Mar 5th, 2012
      St. Paul, MN
      10-11-2013 09:17 PM #16
      I guess I should ask then... how much stock would I put on "do not remove"? If it's just a passthru elbow, I'm either going to remove it or use two lengths of hose to have that clean 90* turn. I am just very sketchy about the hose sections that are directly connected to other hose sections, and are starting to show signs of cracking.
    17. Member teknikALLEN's Avatar
      Jul 14th, 2010
      Ithaca, NY 14850
      10-13-2013 10:19 PM #17
      I believe the blue arrow is the Up-shift indicator vacuum switch. It relays engine load to the up-shift control unit and is connected to vacuum line to/from distributor usually to the Throttle body. I normally see that closer to the distributer rather than the TB.
      http://www.cabby-info.com/electrical.htm#Sensors
    18. Member flipty's Avatar
      Mar 5th, 2012
      St. Paul, MN
      10-14-2013 01:51 AM #18
      I have an 88... so while my instrument cluster has the shift indicator, I believe it doesn't actually have the hardware. I looked it up in my Bentley and it claimed to be something else but for the life of me I can't remember. Something to do with idle boost or something.
    19. Member phish32786's Avatar
      Nov 18th, 2011
      Detroit, MI
      2012 Golf/1988 Cabby
      10-14-2013 09:38 AM #19
      Blue arrow is the cold enrichment vacuum switch.
      Sent from my SCH-I535 using Tapatalk now Free
      Will Vag for Beer.
    20. Member flipty's Avatar
      Mar 5th, 2012
      St. Paul, MN
      10-15-2013 11:14 AM #20
      I posted this in another related thread but wanted to post it here too just in case...
      anyone know where I can get a replacement for that switch? I'm reasonably certain mine's toast.
    21. 10-17-2014 10:49 AM #21
      I'm fairly certain it was used on some Opels, as they where gm vehicles made in germany.
    22. Member
      Dec 6th, 2004
      San Diego, Ca.
      81 diesel Caddy, 87 16v Scirroco
      04-04-2016 10:10 PM #22
      Does any one have a recent source for the AC Delco # 90304535 check valve?
    23. Member briano1234's Avatar
      Feb 20th, 2004
      Atlanta Ga
      04-04-2016 10:24 PM #23
      Quote Originally Posted by N1ch View Post
      Google?
      https://www.google.com/search?q=9030...utf-8&oe=utf-8
    24. n00b
      Mar 16th, 2006
      Shingletown, CA
      1986 Cabriolet, 1.8, 5speed
      04-04-2016 10:54 PM #24
      Comes up as no parts found for some reason...
    25. Member Kevin Rowley's Avatar
      Sep 6th, 1999
      Georgia
      1987 Cabriolet
      04-05-2016 10:43 AM #25
      Quote Originally Posted by flat4tom View Post
      Try here:
      http://www.wholesalegmpartsonline.co.../90304535.html
      2005 MINI Cooper S
      2004 Volvo C70 LPT
