VWVortex.com - Going 1+ how long the clutch will last?
    Page 2 of 2 FirstFirst 12
    Results 26 to 50 of 50
    Thread: Going 1+ how long the clutch will last?
    1. Banner Advertiser Jamie@APR's Avatar
      Sep 11th, 2013
      10-15-2013 02:19 PM #26
      All clutches are torque rated, not HP rated. The holding capacity is force derived.
      Calibrator...not sales...not tech support...not for rent lol
      GoAPR.com | Facebook | YouTube | Twitter
      Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
      Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    2. Member ecirwin's Avatar
      Feb 27th, 2009
      Lakewood, CO
      '12 Golf R 2Dr Black
      10-15-2013 02:34 PM #27
      Quote Originally Posted by BC R View Post
      I was obviously talking about kinetic friction not static friction.
      Static friction is higher than kinetic friction, so when the engine overcomes the static friction, you get kinetic friction which leads to heat. The second you see kinetic friction (without pushing on the clutch pedal) you have slip. In other words, you get slip before you get heat.
      2012 Golf R 2Dr Loaded DBP - Diesel Geek, Badgeless Grille & Fill, Delete R Badges, 42DD Downpipe, Autotech HPFP, UM Stg2, Huper Optik Tint, HPA Dogbone mount, Rebadge.com, BSH PR CAI, Twintercooler, LED Tails, TSW Interlaggos 19X8, CTS TOP & TP, Xpel Ultimate, DXD Stg2 Daily, USRT W/M
    3. Junior Member CH47AV8R's Avatar
      Jun 6th, 2011
      Pittsford, NY
      '77 Beetle (sold) '84 GTI (sold) '88 Scirocco 16V (sold) 2006 VW Rabbit (sold) '12 Golf R CSG 4dr
      10-15-2013 02:36 PM #28
      Current: '12 CSG Golf R 4dr
      Former: '06 RSM Rabbit 4dr
      Former: '88 Wht Scirocco 16V
      Former: '84 Blk GTI
      Former: '77 Metalic Blue Beetle
    4. Member CALICSGR's Avatar
      Jan 24th, 2012
      Bay Area, CA
      2012 Golf R 4 door CSG
      10-15-2013 05:49 PM #29
      I'm at almost 18k miles at 1+ and my clutch has been slipping in 4th - 6th for a while. Will replace soon.
    5. Member balesm01's Avatar
      Mar 7th, 2003
      NY
      82 Renault 5 Alpine, 84 Lancia HF, 93 Jeep, 96 Passat , 97 S4, 03 TT , 11 GTI, 13 Golf R
      10-15-2013 06:03 PM #30
      Jaime, is the R clutch different from the GTI (2012-13)?
      2016 Golf R MT LSG w/ DCC/NAV //Burger JB1, SPULEN Pipes, APR Turbo Muffler Delete, Modified OEM Air box w/ aFe Dry Filter, S3 OEM Short Shifter, ECS Clutch Bleeder, Flaps delete, Soundaktor delete // V1 hard-wired, Euro Aluminum Mirror Caps, Euro Blind Spot Mirrors, Winter Tronic 17' w/ Pirelli SottoZero 3, Mojo R carpets, Phone Holder ProClip USA, Interior LED, Xtra Bright H7 Turning Lights, VAGCOM tweaks, Playing lots of Prog rock full volume
    6. Member GTIVRon's Avatar
      Jul 24th, 2009
      Hurst, Texas
      92 Corrado SLC, '12 Golf R
      10-15-2013 06:28 PM #31
      Found something interesting about my stock clutch (intake, hpfp, tune... call it whatever stage you want) today on my way home from work.
      Noticed pretty hard slip in 4th getting on the highway. It's about 58°F and raining. Curious about what "fixed" it first time I noticed slip (about 8K miles ago) I played with it for a bit. While in 6th, I'd give it go pedal to see how far it would slip. About 1500 RPM, damn, but was it trying to bite again? Cruised for about 2 miles, and pushed it again. Slightly less slip, and it grabbed and started pulling! Each time I did this the slip was less and less severe. Now out of highway, (exit came up) I downshift to 5th as I exit and lay into it. No slip!? WTF?
      So, question to all those that had/have slipping stock clutches.. have you tried "burning off the bad spot" and notice anything similar to what I experienced?
      2002.5 Jetta 1.8T - TOTALED (dodging deer)
      2002.5 24v GTI - TOTALED (rear-ended by a Jeep)
      1992 Corrado SLC - Daily Driven (when it's not broken)
      2012 Golf R - Daily Driven (when Corrado's broken)
      Apr 19th, 2013
      Hawaii
      '13 RB Golf R 4D/Nav
      10-15-2013 07:01 PM #32
      Quote Originally Posted by GTIVRon View Post
      It's weird as hell that you posted this. I've had some bad slip the past few hundred miles in 4-6th, but it's practically nonexistent now. Sounds exactly the same as what I experienced.
      2013 Rising Blue Golf R w/ 4 Door & Navigation
      Stage II+ | VWR Intake | 42DD Catless DP / APR RSC | OEM RLS / Dimming Mirror | Southbend Stage II Clutch | DieselGeek SS | Gold BBS LM
    8. Member GTIVRon's Avatar
      Jul 24th, 2009
      Hurst, Texas
      10-15-2013 07:11 PM #33
      Quote Originally Posted by LowBatteryLife View Post
      I'm wondering if we didn't just get a bad batch of clutch discs with the roll-out of the R...
      Apr 19th, 2013
      Hawaii
      10-16-2013 04:16 AM #34
      I dunno man. I was just over at New German Performance over the weekend setting up a clutch appointment for a Southbend Stage 2 Daily, and it just stopped. Now I get to call and sound like an idiot that doesn't know clutch slip symptoms.
    10. Member RBGolfR's Avatar
      Apr 3rd, 2012
      Everywhere
      RB Golf R , MKV GTI
      10-16-2013 08:36 AM #35
      I went from 1+ to 2+ and I am still fine. I know a few others who have had to clutch slip in my neck of the woods. I don't launch mine all the time. I also down gear to pass others. Not sure if that's a factor. But it seems most people who had the issue were passing on the highway in 6th gear in my area. I am also on APR 2 + tune before the last update .
    11. 10-18-2013 01:48 AM #36
      I have verified 300 crank HP at HPA AWD dyno. Been that way for 25k km and not a single hint at a clutch problem so far.
      I take that back. In the last couple days I experienced a new phenomenon- while accelerating with full throttle in 2nd the engine would let go somewhere around 4-4.5K RPM and jolt the car. I assume it is because the clutch lets go. First time this happened I thought I revved up too far but then I was able to reproduce it while watching RPMs which disproved that theory.
      I've had SPEC clutch sitting in the box for a while, guess it will have to go in soon.
    12. 10-18-2013 02:00 AM #37
    13. 10-18-2013 06:15 PM #38
      After further investigation it looks like whatever I experienced is not related to my clutch, so my statement still stands that my clutch is perfect after 25k km.
    14. Member redduc's Avatar
      Jun 17th, 2005
      NOVA
      2012 Golf R
      10-24-2013 05:41 PM #39
      I felt mine slipping for the first time today. Same conditions as everyone else. Colder day, 4th and 5th gear at highway speeds. I'm at stage 1 ready to go to 1+ at 5300 miles. Lots of city driving.
    15. Member TheyCallMeBobv2's Avatar
      Sep 7th, 2012
      Tampa, FL
      2013 Golf R
      10-24-2013 07:01 PM #40
      Yea, very cold morning in the DMV. Barely got on it in fourth and felt the slippage. New clutch for Xmas for me!
    16. Member
      Mar 8th, 2000
      Scottsdale, AZ
      2013 4dr RB .:R
      10-24-2013 09:37 PM #41
      Quote Originally Posted by redduc View Post
      Can you force the slip in stock mod? I'd be at the dealership. Stage one shouldn't be crushing a clutch that fast
      Please excuse the iTypos
      2013 RB .:R || faster stuff.
    17. Member redduc's Avatar
      Jun 17th, 2005
      NOVA
      2012 Golf R
      10-25-2013 10:30 AM #42
      That's a good idea, thanks. I think it's ridiculous that it's letting go already. The car is 18 months old but I've never replaced a clutch with less than 80k miles on it.
    18. Awaiting Email Confirmation candywhitefingers's Avatar
      Mar 15th, 2010
      New York
      Sepang Blue S3, MK4 DBP .:R32, Mk5 GTi(Sold), Mk4 DBP .:R32 (Sold), Mk6 CSG Golf R (sold :()
      10-25-2013 12:22 PM #43
      I'm stage 1 with the intake file (v3.3) and haven't had any issues. i drive my car every day and i drive aggressively a good amount of time. looking to upgrade my clutch before going stage 2+ however.
    19. 10-25-2013 03:22 PM #44
      My stock R's clutch has slipped once since new (at 10K miles, now). I was leaving a crowded car show this past summer and a traffic backup caused a few miles of slow stop-and-go driving. I was not being hard on the clutch, just pulling away in a normal fashion at like 1200-1400 rpm. When I finally merged onto the freeway, I got some slip when accelerating in fifth gear. I can only assume that the slow going heated up the clutch a bit too much (it was around 80* that day). After a few cool-down miles, I got on it a bit in fifth and sixth and there was no more slip. It also hasn't slipped since.
      '12 Golf R
    20. Member dOwnsizer's Avatar
      May 21st, 2013
      The Great State
      2013 CW Golf R
      10-25-2013 03:38 PM #45
      I am 1+ and preemptively changed my clutch even though I never had slip. I am happy I did. First, I love the feel, and engagement of the new clutch (DXD Stage 2 Endurance). Second, I am going to track the car, and feel more comfort I can push the car hard in any condition and the clutch should hold. Third, I will go stage 2+ in the next year (hopefully) so this would have been done anyway, and now I get the benefits of points 1&2 sooner.
      2013 Golf R 4Dr Loaded CW
      Build Thread
      dubsquared
    21. Member redduc's Avatar
      Jun 17th, 2005
      NOVA
      2012 Golf R
      11-06-2013 02:01 PM #46
      Mine only slips in the 93 octane program but I'm adding an APR hpfp and the 1+ file Friday. My local dealer was 100% sure VW would kick back the claim because of the tune. I was completely upfront about what was done to the car figuring my soul is worth more than $1750. I ordered the HS RSR clutch today. Problem solved.
    22. Member
      May 21st, 2012
      Virgin Galactic
      2012 CW Golf R
      11-06-2013 06:05 PM #47
      I've been Stage 2+ for like 20k miles and now on the revised APR 3.31 revision and I think my clutch will last for a while guys. I don't drive it that hard and if I do I don't launch it or double clutch or anything. I just gun it in the higher gears and so far she's a champ!
      12' CW 4Dr Loaded Golf R
      Never enough power!!!!
    23. Member redduc's Avatar
      Jun 17th, 2005
      NOVA
      2012 Golf R
      11-06-2013 06:42 PM #48
      For the record, I think it's completely absurd that this clutch only made it 5400 miles. I'm an old man and have had manuals since I'm 16. Launching to me is something rockets do. I simply don't have time to screw with it and do have a few extra bucks to make it go away.
    24. Member Spinozaman's Avatar
      Dec 23rd, 2012
      US
      2013 R gone, 2016 R DSG
      11-06-2013 10:46 PM #49
      I have a similar thing happening. Basically what I've surmised is that it's just a very fine line where the torque exceeds the clutch holding capacity. As you know, engine torque and load varies a lot by IAT, road conditions, slope of road, AC on/off, etc, etc. It's just hit or miss for me. But, as it gets colder and the car produces more TQ, slips are much more common. Now, with temps 30F-40F, it pretty much slips all the time in 4-6 anything past half throttle between 2500-4000 ... usually .
    25. Junior Member
      Mar 15th, 2006
      Ottawa Hills Ohio
      2012 Golf R, 2010 Touraeg, 1989 Porsche 951, 2003 porsche 996 TT X50
      11-07-2013 04:12 PM #50
      I've had a revo stage 1 tune for 14000 miles and it just slipped for the first time today in 6th gear (70mph, 39 degrees in 6th gear). I have 17700 total miles on it and never do hard launches.
