VWVortex.com - Volvo 850/V70 (P80 Chassis) Learn me!
    The Car Lounge
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 69
    Thread: Volvo 850/V70 (P80 Chassis) Learn me!
    1. Member Provocyclist's Avatar
      Dec 16th, 2004
      Salt Lake City, UT
      2004 Volvo XC70, 1998 VW Jetta K2, 1999 Passat 1.8t Wagon (sold), 1985 Vanagon SVX (sold)
      10-14-2013 09:17 PM #1
      So i've searched on here and on swedespeed for a buyers guide for the 1993-2000 volvo wagons, and really haven't come up with anything concrete. Whats the reason for staying away from the AWD systems? Theres a couple non-XC cars with AWD. I know about getting the car Stage 0.
      Turbo vs non-turbo? Any special needs there apart from regular turbo stuff?
      All i'm seeing transmission-wise is autos, I know manuals are out there, but rare as hens teeth. What should I look for with the trans?
      Im handy with a toolset, so I'm not afraid of getting dirty with my cars. How do parts costs compare with a B5 Passat (my current car)? Are they similarly easy to work on? Ill probably have about $3500 to spend.
      Thanks all!
      The horn is there to honk. Why wouldn't I honk it? I honk for lots of things. Honk at me? You bet i'll honk back. Honk honk mother****er i'm a Tacoma driver and you better get the **** out of my way.
    2. Member Fettes Brot's Avatar
      May 25th, 2001
      Calgary, AB
      2017 VW Golf R 6spd, 2017 Honda Pilot Touring
      10-14-2013 10:16 PM #2
      My 98 V70 T5 5-speed
      Ok, where do I start.
      Overall, these are fantastic cars. I prefer the P80(X70) cars to the 850, simply because I think they look nicer, & have a more comfortable interior. Material quality is very good. Other than puckering leather on the door cards, most interiors look great, even after all these years. Nearly everything I'm about to go over applies to both the 850 & X70.
      1998 is the best year in most opinions, as it was pre CAN-Bus network, & therefore simpler overall. 1999 & 2000 gained coil on plug ignition, variable valve timing & electronic throttle (ETM). The ETM is a known trouble spot on these cars. There are suppliers of aftermarket alternatives, but I don't have any first hand knowledge of how those are - supposedly very good.
      All cars by this age need to have the PCV system checked out. A clogged system will set you back a few hundred bucks in parts & labour. Run the car at idle & pull the dipstick out - if you see smoke, it's clogged. The next question is how bad! Most cars just need the oil trap & hoses replaced, but some neglected cars will need to have the oil pan dropped to clean the internal passages correctly. Change the oil on time, & keep the short trips to a minimum, & the PCV system should stay healthy for a long time.
      Most cars will have tired suspension, watch for torn upper strut mounts, worn ball joints, tie rods, etc.
      AWD - there are some trouble spots to watch out for, but I've been working on these cars for over seven years now, & haven't seen what all the fuss is about.
      -Watch for Angle Gear/Bevel Gear leaks - there is a reseal procedure if it needs to be addressed.
      -Listen for banging, or vibrations while driving under your seat. That may indicate a bad propellor shaft joint. It isn't serviceable, so you'll have to either buy a new shaft (>$1k) or get a rebuilt unit.
      -Viscous Coupler: This is the part most people will moan about, but I've only seen one failure in all my years with Volvo. Failure will be noticed with a jerking feeling when making tight turns, & may be accompanied by a banging/clunking noise.
      Turbo cars don't seem any less reliable than the non-turbo cars, but are way more fun. I've never seen a bad turbo on one of these cars.
      Transmissions - manuals are way more fun & reliable, but yes, very hard to find. I was lucky I got mine! The automatics aren't the most stout out there, but failures are few and far between in my experience. It's more common to have a failure of the PNP switch than anything else. Just make sure the fluid is clean & doesn't smell burnt.
      If the ABS/TRACS warning is on, I can 99% guarantee the ABS module is faulty. You can replace it with a new one ($$$$), find a rebuilt ($$), or rebuild it yourself with a soldering iron (free!). There are instructions online.
      The drivers window switch pack is common failure. You'll know its bad when a window won't respond from it, but can be controlled at that door.
      Overall, these are very easy to work on, & don't require too many special tools, unless you're getting into something deep (headgasket, AWD repairs).
      Wheel options are good, within the Volvo brand. Anything FWD/AWD from 1994 - 2007 850/X70/S60/V70/S80 will fit.
      One thing I cannot stress enough, is use OEM parts. The quality of most aftermarket replacement parts in very, very poor. I've seen strut mounts fail within months from an aftermarket supplier. Some aftermarket performance stuff is good though. Do your research and you'll be fine.
      $3,500 should get you a good daily driver that should need minimal work.
      I'm sure I've forgotten something, so feel free to ask more questions.
    3. Member MAGICGTI's Avatar
      Jul 2nd, 2003
      Atlanta, GA
      10-14-2013 10:59 PM #3
      What he said.
      Good online communities. Matthew's Volvo Site is very informative, Volvospeed is like the MKIV forum but some good stuff, Swedespeed is dead for the 850 but good classifieds, and there are a few other forums. Lots of good UK forums too.
      FCP Groton and IPD are good for parts. Tasca Volvo in RI is good for OEM.
      Time has been very kind to these cars. I'd echo the '98 V70/S70 comment but I couldn't help myself and did an 850R for the cool factor. I love my Volvo, and choose to drive it daily.
      While it might not be a priority, Lucky is a software "tuner" in OR and has reasonably-priced software upgrades for these cars. The issue is, and Fettes Brot got most of it, is that your turbo Volvo needs to be at Stage 0 to start with. There is a lot of rubber vacuum lines, as well as radiator and intercooler hoses, to crack and leak boost.
      Any car you look at will need a suspension refresh and PCV system. The good news is it's less than $1k in parts.
      The bodies are incredibly rust-resistant. The upholstery can wear but there is a guy who makes quality leather covers.
      It's hard to emphasize enough how different '98 vs. '99-'00 are.
      In summary, go for it. In a used-car market with some wildly overvalued junk, the FWD Volvos are generally nicely priced. There's a 98 V70 T5 auto with 180k that looks great for $1500 on my CL.
      I've done some suspension work on my 850, did the Eibach Pro-Kit and Koni FSD with great results. I'm chancing it with Meyle HD components along with some Volvo OEM but he's right, lots of Chinese junk on the market.
      Oh, pics
      When I got my 850R:
      Now, still lots to do:
      2016 Passion Red/Off-black S60 T5 R-Design
      2006 Ice White/Oak XC70
      1996 Polar White/Charcoal 854R
    4. Member Norrlands Turk's Avatar
      Feb 16th, 2013
      Midwest
      '06 SAAB 9-3 2.0T
      10-14-2013 11:19 PM #4
      My craigslist over here is full of extremely low priced '97 to '00 XC70s. Many of them seem to have transmission issues. Owners do not want to pay big bucks at the shop and dump them for cheap. Any XC70 owners here?
      How would you compare working on these cars to working on a Corolla or Civic? Easier/ more difficult?
    5. Member MAGICGTI's Avatar
      Jul 2nd, 2003
      Atlanta, GA
      10-14-2013 11:49 PM #5
      Quote Originally Posted by Norrlands Turk View Post
      '00 seems to be a sucky year. See lots of trans issues with the 5-speed automatics for whatever reason.
      I'd stick to '98 or if you find a decent '99 and are ok with CAN-BUS. You can always remove the rear driveshaft and make it FWD. I'd also say a lot of owners are spooked by high repair estimates but don't DIY or have a good shop.
      Never worked on a Civic or Corolla but they're is good room in the engine bay and quality parts. There are service manuals and an online DIY for every job just about.
    6. 10-15-2013 12:08 AM #6
      had a 98 S70 GLT (turbo)
      A/C failed, auto locks failed, it burned oil, ABS failed...
      On the plus side, loved the turbo sound, it was comfortable, and for some odd reason mine had 2 rear fog lights. Still not worth keeping, most unreliable car I've had.
    7. Member MAGICGTI's Avatar
      Jul 2nd, 2003
      Atlanta, GA
      10-15-2013 12:12 AM #7
      Quote Originally Posted by I_like_waffles View Post
      You man you needed an evaporator, door lock actuator (would be my guess), PCV replacement (or valve stem seals, unlikely), and the ABS module resoldered?
      $1500 parts and labor for all of it. This is why these cars get a bad rap.
      Mar 5th, 2004
      WI
      S80, CRV
      10-15-2013 12:20 AM #8
      Great cars
      They will run with a lot of neglect, so be mindful of inspecting the car thoroughly when you buy one.
      They are easy to work on, much more than VW/Audi IMO, they have great community support.
      They have common problems, but they are well documented by now and DIY friendly for the most part.
      I currently own a awd model and it hasn't given me any problems at all. The bevel gear was replaced about 10k miles ago though(previous owner) so that is a big expense that I didn't have to pay for.
      The trans has been great too, knock on wood.
      Manual transmission swaps are well documented and tuning companies like http://www.ardtuning.com/
      provide software to do a trans swap on the 99-00 cars now also.
      98 tends to be less problematic than the 99-00 cars. Transmission swaps are easier.
      I absolutely love my car. Coming from the vw/audi ownership experience, my v70r is ~75% of what my B5S4 was and ~30% of the maintenance cost.
    9. Member BattleRabbit's Avatar
      Jun 28th, 2007
      Albany, NY
      DKW Munga
      10-15-2013 12:30 AM #9
      Quote Originally Posted by MAGICGTI View Post
      One of my coworkers did this with his. Apparently it saved him a lot of cost and headaches, and the thing still gets him to work.
      He told me doing the fuel pump in his XC was a royal pain in the butt. I'm not sure if that is true of all years though.
      2005 Subaru Forester X/1980 Honda CM400E/1987 Porsche 944S
      BattleRabbit takes Pictures!
    10. Member MagicBus's Avatar
      Oct 3rd, 2003
      Worcester, MA
      1991 VW Vanagon, 1983 Mercedes-Benz 240D, 1998 Volvo S70
      10-15-2013 08:00 AM #10
      I hope these cars are as good as they say...
      I'm picking up a 1998 V70 tonight to replace my wife's rapidly and unexpectedly deteriorating 1995 Legacy.
      Getting the V70 for well under $1000. Needs work (some exhaust, brakes, some suspension, tune up including timing belt, etc), but is a solid runner - test drove it last week.
      The PCV system was entirely replaced last fall and the car comes with 4 separate mounted snow tires. I'll have to put some work into it, but it seems like a pretty good deal. I've test driven a few in the past year and love how they drive.
    11. Member zhenya00's Avatar
      Aug 7th, 2003
      Ithaca, NY
      10-15-2013 08:48 AM #11
      $1500?? I bet it could have been fixed for half that by a mechanic who knew what he was doing.
      Most of the good stuff has been said. I prefer the 850 aesthetic, but that's just personal taste.
      If you get leather, the dark stuff seems to age a lot better.
      Very, very good cars for the dollar. I just sold mine, not one thing wrong with it, no rust, ready to go another 200k for $4500. Was really sad to see it go. It was by far the best highway car in our fleet.
      1987 Mercedes 190E 16v Cosworth
      1997 Volvo 855 T5
      1998 Volvo V70 AWD
      2010 Volvo XC90
      Mar 5th, 2004
      WI
      S80, CRV
      10-15-2013 02:17 PM #12
      Quote Originally Posted by BattleRabbit View Post
      To replace the fuel pump correctly, it is a big job. The entire rear drivetrain needs to be taken out to drop the fuel tank to access the fuel pump on the top. I think it is billed by Volvo as a 10 hour job, it's pretty involved. I don't envy your coworker.
      There is an easier way, which involves cutting an access panel through the sheet metal in the rear hatch area, but it is permanent so there is always that to consider. It take substantially less to replace the fuel pump once doing that though
    13. Member MAGICGTI's Avatar
      Jul 2nd, 2003
      Atlanta, GA
      10-15-2013 02:55 PM #13
      Quote Originally Posted by MagicBus View Post
      You'll love it, it's right up your alley. Surprised it took you so long.
      ErieVovo is good for quality used parts if you don't have a yard near you. $99/axle used OE with lifetime warranty.
    14. Geriatric Member Aonarch's Avatar
      Dec 4th, 2006
      Atlanta, GA
      ATS-v | All Track CEL
      10-15-2013 04:10 PM #14
      For the money you cannot go wrong.
      I still want one for a DD.
    15. Member mellbergVWfan's Avatar
      Jan 31st, 2008
      Bay Area, CA
      81 Scirocco S, 99 Cobra
      10-15-2013 04:22 PM #15
      My friend picked up an 850 Platinum edition a while back. Then it had some boost leak problems and the title transfer became a mess. He has pretty much everything for a manual swap and the parts to fix the problem. He just lost all motivation for it and wants to get rid of it, but can't because Alabama is still holding the title.
      /csb
      My 16v Swap thread
    16. Member MAGICGTI's Avatar
      Jul 2nd, 2003
      Atlanta, GA
      10-15-2013 10:11 PM #16
      Quote Originally Posted by mellbergVWfan View Post
      /csb
      What a shame, hope he gets it sorted. Tell him not to give up.
    17. Member Provocyclist's Avatar
      Dec 16th, 2004
      Salt Lake City, UT
      10-15-2013 11:15 PM #17
      Wow, thanks so much for the information Fettes Brot, MAGICGTI, and bubbagti! Ive been sitting on the fence for a while, but im pretty much convinced that I need to get a Volvo now.
    18. Member MagicBus's Avatar
      Oct 3rd, 2003
      Worcester, MA
      10-16-2013 01:55 PM #18
      Thanks for the tip.
      Drove the "new' car home last night. Suspension is a bit rougher than I would have liked, but was planning on pretty much totally refreshing that, anyway. Has a cat code and an evap code, but I doubt it'll take much to sort those out.
      Other than that, I loved the way it drove, and it's SO COMFORTABLE!!!!! compared to the Legacy (which, don't get me wrong... I do find comfortable and enjoy driving). Definitely has that couch-on-wheels feel I like so much in Mercedes.
      Providing it stays reliable, I can see myself buying more of these.
    19. Member trigtm's Avatar
      Mar 20th, 2006
      Boston
      2012 XC60, 1991 Miata
      10-16-2013 02:52 PM #19
      Quote Originally Posted by bubbagti View Post
      Even easier way that that. I can do the fuel pump in under an hour without any cutting of the floor or dropping the rear subframe. I have it documented over on volvlspeed.
      Anyway - buy one. Easy and rewarding to work on. No special tools, and super reliable.
      don't buy the AWD model though. Worse gas mileage, more maintenance, less reliable for very little benefit. However, all V70R's in this chassis were AWD.
      Also, only the 5speed auto in the R in 2000 was a problem. No issues with the trans in other cars.
      No 5 speed turbo cars besides the T5's but those are generally hard to find.
      Quote Originally Posted by lago_b View Post
      You don't own a Sawzall? I suppose you don't own a wet/dry vac either, and Friday nights consist of a Sex and the City marathon, Cherry Garcia, and a good douching before bed? You must go get a Sawzall, son.
    20. Member
      Dec 30th, 2006
      1992 Volvo 740 Turbo
      10-16-2013 03:34 PM #20
      I just bought a very similar car and went through the same thing.
      I bought a '99 V70 NA car with a manual for $900. The suspension was toast, tires were shot as a result, and it has 237k miles. I did the suspension using Koni struts and a mix of OEM and Meyle HD components. All in all the suspension was easy though one of the rear shock mount bolts broke off as I was removing it (beware of this, give them a good LONG soak in PB and back it out two turns out, one turn in, two turns out, etc... the lower threads are exposed to the elements and get corroded and seize in the threads as you unthread them). I had to drill out and tap it to the next size.
      I plan to do my first oil change, PCV update, and timing belt in the next 3,000 miles which should be about another $400 in parts. So, all told I'll be in about $2300 for a high-mileage V70 manual with a lot of new components, which is fine by me.
      The evaporator on mine is toast, maybe I'll deal with that down the road.
      I will say this though, I liked my 940 more. Call me crazy, but the build quality on the 900 cars seems to be of a higher standard than my '99. The car has INSANE interior rattles that I haven't been able to diagnose yet. Granted, it has really high mileage, but my 940 has nearly 300k and is dead quiet on the road. Plus my car hunts for idle while warming up and I suspect I'll need to procure a new throttle body sooner than later. As others have said, if you want the refreshed body work, get a '98 so you don't have to bother with that nonsense.
      Quote Originally Posted by Mach700 View Post
      In the absence of Wars, people become lazy and sex slaves (not everybody).
    21. Member MagicBus's Avatar
      Oct 3rd, 2003
      Worcester, MA
      10-16-2013 03:43 PM #21
      Quote Originally Posted by The Igneous Faction View Post
      Thanks for the heads-up on the shock mount bolts. The car needs suspension, but the seller already put two new front tires on it and the rears still looked OK. Plus, the snow tires look almost new, so I'm all set there.
      I paid $675 for the car, which feels about right, given the laundry list of items the car needs, including, likely, an exhaust from the header back. I keep totaling up what it'll cost, and I think it'll be worth it in the end. Time will tell.
    22. Member sandiegan's Avatar
      May 25th, 2005
      LA Section 8 Housing
      A bicycle.
      10-16-2013 04:00 PM #22
      So many threads on these. I had a 94 850 Turbo wagon (which was auto, as were all USDM 850 Turbo's). As a "manual guy", it was still one of my favorite cars I've ever owned, out of things like S2000, Corvette, blah blah blah. I bought it for $1200 with 280k miles on it. Put 20k miles on it, had it two years, it failed smog, retired it to the state of California for $1k. In two years, as I recall, I bought a battery, replaced the PCV with parts from FCP Groton, and did oil changes. PCV clogged again after having done it (probably needed a ton more work). Not sure I could stomach owning one as a real/only car (used it as a beater).
    23. Member alex_bgnet's Avatar
      Jan 6th, 2004
      DC
      '13 Golf TDI
      10-16-2013 04:15 PM #23
      I am a chassis veteran and can recommend a few things. Find out more about the transmission, when the oil was changed and how well it shifts. One of my wagons started to change shifting behaviors and I changed the oil with the OEM spec, still does it but hasn't gotten worse. My other wagon...the trans is solid, it was shifting smooth and I still replaced the fluid, still strong. I have 5 Volvos. Turbo maintenance is cheap, lots of parts in junkyards. The only difference between the turbos and non turbos is gas consumption and power. I truly enjoy my non-turbo wagon on long journeys - 29mpg regular vs 22mpg with premium.
      Regarding the AWD, a lot has been said but if you want to preserve it just take the driveshaft off and only install in in the winter. It is perfectly fine to do that. My transfer case peed itself to death on my V70R. FWD now.
      Current: 2005 V70, 2006 E350, 2010 535i, 2013 Golf TDI
      Past Volvos: 1996 960, 1998 S70 T5M, 1999 V70R, 2000 V70, 2004 S60R
      Past Audis: B5S4, 1990 90 2.3qm
    24. Member zhenya00's Avatar
      Aug 7th, 2003
      Ithaca, NY
      10-16-2013 04:21 PM #24
      Quote Originally Posted by alex_bgnet View Post
      Are you saying the turbos only get 22mpg highway? My chipped T5 did 26-29mpg highway. Yes, it did like premium.
      1997 Volvo 855 T5
      1998 Volvo V70 AWD
      2010 Volvo XC90
    25. Member Provocyclist's Avatar
      Dec 16th, 2004
      Salt Lake City, UT
      10-16-2013 05:28 PM #25
      I slightly inclined to stay away from AWD, at least for my first volvo, but maintaining that system doesn't down too horrible regardless. Is there that big a difference between the n/a and turbos in gas mileage? My Passat gets 32 highway, but its 5MT.
      If i wanted swap a manual, do any of the transmissions work, or do I have to stay n/a to n/a and turbo to turbo?
